bjoerns
RB941-2nD slow in ROS7
Tue May 31, 2022 5:50 pm
I think this is a known issue but is there already a known workaround for the slowness of management functions when running RB941-2nD on ROS7?
For example, a /export shows 1 line per second, or the webgui only shows content after several seconds...
mrz
Re: RB941-2nD slow in ROS7
Tue May 31, 2022 6:32 pm
That router does not have enough RAM to run v7 smoothly.
bjoerns
Wed Jun 01, 2022 12:50 am
Yes, i understand there are RAM restrictions. But it's not clear for my why this is an issue because there are about 8Megs free on ROS7, and it's the same on ROS6. Is there any way for improvements like disabling services?
bjoerns
Tue Jun 07, 2022 5:26 pm
is it planned to implement a function to disable unneeded functions/packages like in ros6?
normis
Wed Jun 08, 2022 8:46 am
If you don't use a function, it consumes no resources
Users browsing this forum: Amazon [Bot], uxertxo and 75 guests
