souljazk
WIreless Station Mode - No internet on LAN side
Wed Jun 01, 2022 11:17 am
Hi there. I've tried to figure my way out of this issue, but no luck.
Desired result - Internet -> Hotel Router (192.168.110.0/24) -> My HAP-Ac2 (172.16.1.0/24) -> my devices (wired) 172.16.1.10-20
WLAN1 = connected to Hotel Wifi in station mode. ***CAN ping internet***
ETH1 = PoE In via injector, LAN side goes to a dumb 8 port switch.
Bridge (172.16.1.1). ***CAN ping internet***
PC - Gets IP (172.16.1.x ; DNS 1.1.1.2 ; 1.0.0.2) but can NOT get internet.
Thank you for your assistance!
Export:
# jun/01/2022 10:05:00 by RouterOS 6.49.6
# software id = removed
# model = RBD52G-5HacD2HnD
# serial number = removed
add name=bridge1
add authentication-types=wpa2-psk,wpa2-eap management-protection=allowed mode=dynamic-keys name=profile1-wifi supplicant-identity="" wpa2-pre-shared-key=removed
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-onlyn country="removed" disabled=no frequency=2442 installation=indoor security-profile=profile1-wifi ssid=3D
set [ find default-name=wlan2 ] band=5ghz-n/ac country="removed" installation=indoor security-profile=profile1-wifi ssid=test
add name=dhcp_pool0 ranges=172.16.1.2-172.16.1.254
add address-pool=dhcp_pool0 disabled=no interface=bridge1 lease-time=1d name=dhcp1
add bridge=bridge1 interface=all
/interface detect-internet
set detect-interface-list=all internet-interface-list=all lan-interface-list=all wan-interface-list=all
add address=172.16.1.1/24 interface=bridge1 network=172.16.1.0
/ip dhcp-client
# DHCP client can not run on slave interface!
add disabled=no interface=wlan1
add address=172.16.1.0/24 dns-server=192.168.110.1,1.1.1.2,1.0.0.2 gateway=172.16.1.1
add action=masquerade chain=srcnat src-address=172.16.1.0/24 src-address-list=""
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=removed
[Principle@MikroTik] >
Ca6ko
Long time Member
Long time Member
Re: WIreless Station Mode - No internet on LAN side  [SOLVED]
Wed Jun 01, 2022 11:59 am
/ip dhcp-client
add bridge=bridge1 interface=wlan2
souljazk
Wed Jun 01, 2022 1:05 pm
Thank you for your assistance Ca6ko.
I've removed all entries under Bridge - ports & ran the commands you provided in the terminal. These are accepted as you can see in the export below.
The bridge can no longer ping 1.1.1.1. As soon as I add the bridge, then the bridge can ping 1.1.1.1.
Export:
# jun/01/2022 12:00:59 by RouterOS 6.49.6
# software id = **Removed**
# serial number = **Removed**
add name=bridge1
add authentication-types=wpa2-psk,wpa2-eap management-protection=allowed mode=dynamic-keys name=profile1-wifi supplicant-identity="" wpa2-pre-shared-key=**Removed**
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-onlyn country="**Removed**" disabled=no frequency=2442 installation=indoor security-profile=profile1-wifi ssid=3D
set [ find default-name=wlan2 ] band=5ghz-n/ac country="**Removed**" installation=indoor security-profile=profile1-wifi ssid=test
/ip dhcp-client
/ip service
/system clock
set time-zone-name=**Removed**
erlinden
Wed Jun 01, 2022 1:23 pm
Do you get an IP address in the DHCP client?
souljazk
Wed Jun 01, 2022 1:47 pm
EDIT: I rebooted my HAP Ac2 and I do have internet on the LAN now :) Thank you @Ca6ko. DESPITE the bridge not being able to ping 1.1.1.1. Is this expected?
HI erlinden
Yes I do (WLAN1 192.168.110.48/24) which is part of the hotels IP range. It displays the following:
IP/ DHCP Server / Networks
Gateway 192.168.110.1
DHCP server 192.168.110.1
Primary DNS 192.168.110.1
Secondary DNS - N/A
On my windows device I get:
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . :
IPv4 Address. . . . . . . . . . . : 172.16.1.254
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 172.16.1.1
erlinden
Wed Jun 01, 2022 2:17 pm
EDIT: I rebooted my HAP Ac2 and I do have internet on the LAN now :) DESPITE the bridge not being able to ping 1.1.1.1. Is this expected?
I think if you want to test ping on your router, you should select the WAN interface. Bridge isn't able to ping 1.1.1.1 on my RB box as well.
souljazk
Thu Jun 02, 2022 2:50 pm
Thank you erlinden for the info & confirming the bring ping "issue'.
Users browsing this forum: phascogale, Rox169 and 81 guests
