ArShuRaZ
My RB4011 with ROS 7.2.3 still consume 100% cpu on only 1 core.
Wed Jun 01, 2022 8:06 pm
Site A (Leased Line)<--- pptp --->(FTTx; PPPoE) Site B
RB 4011 is at site B. The Traffic usage is only about 200Mbps but it consumes 100% on cpu0 and slow down overall traffic.
Any suggestion?
Znevna
Re: My RB4011 with ROS 7.2.3 still consume 100% cpu on only 1 core.
Wed Jun 01, 2022 8:15 pm
yes, right click cpu0, profile, sort, screenshot, upload here.
ArShuRaZ
Wed Jun 01, 2022 9:07 pm
Edit: sorry. profile wrong cpu. will post the right one later when it occurs again.
Kindis
Wed Jun 01, 2022 9:08 pm
I may be wrong here but does pptp spread over cores or is it only one core for all traffic?
memelchenkov
Wed Jun 01, 2022 9:22 pm
I doubt anybody will fix PPTP even if there is some bug.
ArShuRaZ
Wed Jun 01, 2022 9:28 pm
ArShuRaZ
Fri Jun 03, 2022 5:11 pm
ArShuRaZ
Sat Jun 04, 2022 4:21 pm
any suggestion?
Wangz
Wed Jun 08, 2022 7:07 am
Are you natting at your RB4011?
Kindis
Re: My RB4011 with ROS 7.2.3 still consume 100% cpu on only 1 core.  [SOLVED]
Wed Jun 08, 2022 11:42 pm
I assume that this only happens during high traffic over the pptp connection?
I maintain the idea that this is they way pptp works. The interface will only run over one CPU core and that is the effect you see now. I can be wrong but think this is the way it work. So not a bug but by design.
Still think it is wrong then do a supout file during the issue and send to support with a explanation of the issue.
ArShuRaZ
Sun Jun 12, 2022 5:04 pm
Yes. RB4011 dial PPPoE (FTTx) and NAT all client to Internet IP for accessing Internet. But no natting for traffic in vpn tunnel.
ArShuRaZ
Sun Jun 12, 2022 5:05 pm
Thank you. I'm planning to change vpn connection to wireguard ... and will check the result on high traffic again.
Kindis
Tue Jun 14, 2022 11:52 am
Very interested to see the effect of this.
ArShuRaZ
Sun Jun 19, 2022 10:42 am
Wireguard Tunnel between MikroTik must be specific ip (endpoint) on both side?
My situation is
MikroTik at Site A: has fixed public ip address.
MikroTik at Site B: has dynamic public ip address.
Still finding the way to do it without specific Public IP at site B (Treat Site B like road warier).
Znevna
Sun Jun 19, 2022 10:45 am
No, it's not mandatory to specify an endpoint for both sides.
ArShuRaZ
Sun Jun 19, 2022 11:46 am
Thank you. Able to do the tunnel now.
just specific endpoint at site B and leave endpoint blank at site A.
and use persistence handshake at site B.
Will wait to see the CPU usage when high traffic.
ArShuRaZ
Mon Jun 20, 2022 8:24 pm
From Max Bandwidth 190 Mbps with PPTP ... to 490 Mbps with Wireguard.
Znevna
Mon Jun 20, 2022 8:28 pm
Hmm, I think RB4011 can do a little more than that, unless you have a funky config.
What MTU did you set for the Wireguard interfaces?
And what MTU do you have on your WAN at BOTH sides (tested)?
ArShuRaZ
Mon Jun 20, 2022 8:53 pm
I thought so.. My Internet b/w is 1Gbps but can use about 500Mbps with RB4011
I did not set the MTU .. just leave it to default value (1420) for both side on wireguard.
Site A: MikroTik CHR is directed connect to ISP with static IP (Interface MTU is 1500) ... cpu only about 10% on b/w 500Mbps
Site B: RB4011 connect Internet with PPPoE and default MTU (1492) ... firewall was only 2 rows. and no L7 protocol.
Anyway. I'm satisfied with the current result. 500Mbps is better than 200Mbps as before.
Users browsing this forum: MrRey and 94 guests
