TroyQ
How to find certain CAPS with FIND WHERE command
Thu Jun 02, 2022 9:47 am
Hi Guys
I need to use the find where command in a script.
I am trying to write a script where I need to turn off a guest wifi in my my CAPS-MAN at certain times.
I have over 90 CAPS and I only need to turn off only the ones where the names start with BTH. (examples: BTH indoor, BTH Outdoor, BTH room1, BTH corner, etc....)
for this example I am using print where just to test it.
this is how far I got but it is not working...
 /caps-man radio> print where REMOTE-CAP-IDENTITY={BTH}
Don't worry about the rest of the script, that part is working when I use the full syntax in the Terminal. I just need to get the FIND WHERE part working
Please assist, I know this forum always comes through.
TroyQ
afuchs
Re: How to find certain CAPS with FIND WHERE command
Thu Jun 02, 2022 11:50 am
For exact match
 /caps-man radio> print where REMOTE-CAP-IDENTITY="BTH"
For regex match
 /caps-man radio> print where REMOTE-CAP-IDENTITY~"BTH"
TroyQ
Thu Jun 02, 2022 4:03 pm
Thank you for the quick response.
It did not work either.
As you can see no results...but print shows all the AP's
Hope this helps.
rextended
Re: How to find certain CAPS with FIND WHERE command  [SOLVED]
Thu Jun 02, 2022 4:28 pm
@TroyQ, @afuchs doesn't bring anything, don't waste your time.
# for print
/caps-man radio print where remote-cap-identity~"^BTH"
# for script simlpy replace "enable" with "disable" when needed
:foreach radio in=[/caps-man radio print as-value where remote-cap-identity~"^BTH"] do={
    :local mac (($radio)->"radio-mac")
    /caps-man interface enable [find where radio-mac=$mac]
But... what you want exactly do?
Disable / Enable all radio that have "BTH" at the start of radio name?
Probably you need ONLY THIS instead, is more simpler and linear:
/caps-man interface disable [find where radio-name~"^BTH"]
/caps-man interface enable [find where radio-name~"^BTH"]
TroyQ
Fri Jun 03, 2022 12:25 pm
Thank you! @rextended
You are a genius! :D
I just needed to turn the students WiFi off at night and leave the Faculty WiFi on.
This is what I ended up with using a script in scheduler:
This turns it off in the evening
/caps-man provisioning
set slave-configurations="" [find where comment~"^BTH"]
/caps-man radio
provision [find where remote-cap-identity~"^BTH"]
and this turns it back on in the morning
set slave-configurations="BTH Leerders" [find where comment~"^BTH"]
/caps-man radio
Thanks again!!! :mrgreen:
Users browsing this forum: wirelesslywired and 15 guests
