haris013
Hotspot default config doesn't work with iOS devices
Thu Jun 02, 2022 7:28 pm
at default hotspot setup, the captive portal doesn't work on iOS devices. When I config the hotspot and try to connect with an iphone, it doesn't pop up the login page, the user has to manually open a web browser in order to see the login page.
at android devices i don't have this kind of problem, when i connect at the hotspot wifi, the login page pop-up automatically.
Is there any setup that works the auto pop up page with iOS devices?
ingdaka
Trainer
Trainer
Re: Hotspot default config doesn't work with iOS devices
Fri Jun 03, 2022 3:08 pm
Please check domain name that you have set at "DNS Name" IOS devices have problems redirecting non "normal" domains. Example all domain with .local will not work on IOS
haris013
Fri Jun 03, 2022 4:47 pm
Hello ,
I have already checked that. It is a valid domain with an existing tld
Users browsing this forum: mstanciu and 39 guests
