OlofL
How do I specify the first/second... /64 prefix from a /56 pool. (persistent prefix after boot?)
Thu Jun 02, 2022 9:36 pm
I have a pool of a /56 network.
db8:2001:1128:2400::/56
I want to assign ipv6 addresses from my lan interfaces using only "::1/64" command.
add address=::1 from-pool=TT interface=ether5
add address=::1 from-pool=TT interface=ether6
add address=::1 from-pool=TT interface=ether7
But how do I make sure that ether5 always gets the first prefix from the pool, ether6 the second and so on?
I remember there was something like add address=::1:0:0:0:1/64 from-pool=TT, but then I get error address pool error: bad preferred prefix!
I have seen cases where the interface will get another order from the pool, and thus mismatching client prefix when router reboots.
tdw
Re: How do I specify the first/second... /64 prefix som a /56 pool. (persistent prefix after boot?)
Thu Jun 02, 2022 9:52 pm
Unfortunately you cannot, it is an annoying omission from RouterOS.
OlofL
Thu Jun 02, 2022 9:57 pm
I am pretty sure I have seen a workaround on this before ?
Anyways, if I am remembering wrong, how do you make sure clients removes the ipv6 address in the wrong prefix if this happens after reboot?
Can mikrotik send old RA with a short router lifetime timeout to make sure clients withdraw this address, and only uses new prefix?
Sob
Thu Jun 02, 2022 10:40 pm
Some time ago I made this script. I can't say that I like it very much, but it should be usable until there's some better solution.
Users browsing this forum: Bing [Bot], johnson73, teojurado and 51 guests
