lashguti
ROUTEROS 7 IPSEC NAT problem
Fri Jun 03, 2022 8:17 am
Upgraded CCR1036 v6.48.6 to v7.2.3 , ipsec tunnel was established, but incoming packets were not matching against DST_NAT rule. So the traffic was not able to pass the tunnel.
Rolled back to v6 and all is good.
Is it going to be fixed in next v7 release ?
Sob
Re: ROUTEROS 7 IPSEC NAT problem
Fri Jun 03, 2022 6:40 pm
So something with IPSec and dstnat works for you in v6 and not in v7. You didn't share any details beyond that, so nobody can really know what's happening. And you'd like to know if it's going it change. I don't think we can tell you without knowing what exactly it is.
lashguti
Fri Jun 03, 2022 6:45 pm
I have shared enough details to see, that problem is in v7. DST-NAT stops working as soon as upgraded to v7, when back to v6, it works fine with ipsec.
If you need something else, please ask
Sob
Fri Jun 03, 2022 7:20 pm
No, you didn't share any details. You just wrote that some dstnat rule supposedly broke in v7 and it's probably somehow related to IPSec tunnel, because you mentioned it. That's all. You didn't share the dstnat rule, didn't explain how it's related to IPSec tunnel, nothing.
As far as I can tell, dstnat in v7 works just fine, exactly the same way it worked in v6. So if you were unlucky to discover some corner case where it doesn't, and you want some help with that, you should provide some actual details. For example, posting exported config and explaining important parts often leads to great success.
lashguti
Fri Jun 03, 2022 7:28 pm
Dst-nat rule contains ipsec tunnel far-end server address as src and ipsec tunnel peer ip address as dat address, then it makes dst-nat to my interneal host.
As soon as I upgrade to v7, matching to that rule dissapears, no matter I set incoming interface or not.
Sob
Fri Jun 03, 2022 10:13 pm
I can tell you that
add src-address=X dst-address=Y action=dst-nat to-addresses=Z
is simple rule that definitely works in v7. If yours doesn't, then it's probably caused by something else in your config, but since nobody else has any idea what you might have there...
lashguti
Sat Jun 04, 2022 8:08 am
I can tell you that
simple ipsec with 3des, which is established and this dst-nat rule. that's all.
I saw another post where the same v7 problem is described [ somehow related to nat ]
just imagine, something works good on v6 for years and after upgrade rule stops matching, back and that's good. exactly the same thing other users are reporting
lashguti
Sat Jun 04, 2022 8:26 am
/ip ipsec policy group
add name=group2
/ip ipsec profile
add enc-algorithm=3des name=profile_1
/ip ipsec peer
add address=remote_peer_public_ip/32 local-address=local_peer_public_ip name=to_company_x profile=profile_1
/ip ipsec proposal
set [ find default=yes ] disabled=yes enc-algorithms=aes-128-cbc
add enc-algorithms=3des name=to_company_x pfs-group=none
/ip ipsec identity
add peer=to_company_x secret="somesecret"
/ip ipsec policy
set 0 disabled=yes
add dst-address=remote_server_ip/32 level=unique peer=to_company_x proposal=to_company_x src-address=local_public_ip/32 tunnel=yes
add action=dst-nat chain=dstnat comment="" dst-address=local_public_ip src-address=remote_server_ip to-addresses=local_server_ip
Requests are coming from remote server, to local server
pe1chl
Sat Jun 04, 2022 11:38 am
That sure is a strange setup, probably not many users have that.
But probably it should work...
Anyway, it would be better to study and understand the concept of a tunnel. Then you do not need the NAT.
lashguti
Sat Jun 04, 2022 3:24 pm
I know the purpose of the tunnels.
This tunnel is peering a bank, which needs public Ip on my side as a service dest., that's why dst nat is needed as intrernal server of the company sits in private pool.
It worked fine for 8 years till v7 and it's very usual practice in such scenarios. Hope it's clear now
pe1chl
Sat Jun 04, 2022 3:57 pm
I have never seen it before.
Sob
Sat Jun 04, 2022 6:39 pm
Seems clear enough, but I don't see why it shouldn't work. I'll try to test it and I'm pretty sure it will be ok.
lashguti
Sat Jun 04, 2022 8:16 pm
Test it on ccr, as some of the reports say ccr has this problem. Mine also is ccr1036
Sob
Sat Jun 04, 2022 8:35 pm
Sorry, I don't have any. I tried CHR and it works as expected, no problem. But if it should happen only with one architecture, and if you have spare device, then try to reproduce it with minimal config, just tunnel and one dstnat rule. If you succeed (and it won't work), you can report it to MikroTik and they should be able to reproduce it too and fix it. If it will work, then you'll have to find what difference between real and this minimal testing config is responsible for it.
PUDIS
Tue Sep 06, 2022 5:28 pm
I Have the same problem with IPsec after upgrade from V6.49.6 to V7.5 on CCR1016
Znevna
Tue Sep 06, 2022 6:09 pm
I'm sure that it works fine if configured properly.
Jotne
Tue Sep 06, 2022 6:48 pm
How does the v7 configuration looks like? Post an export.
rextended
Tue Sep 06, 2022 6:59 pm
Form release topic:
This is too general, it may depend on how you have configured the device.
There have been many changes from 6.x to 7.x, especially in BGP and Routing,
which probably make the configuration incompatible with what you expect.
rextended
Tue Sep 06, 2022 7:06 pm
Indeed, now I also add:
It is perfectly useless to write like this.
If you do not provide an export before the update, an export after, and you do not create a supout
and do not send everything to support@mikrotik.com accompanied by an adequate description,
it is perfectly useless, it could also be fake, and it could also be a very trivial configuration error.
hats
Wed Sep 07, 2022 12:32 am
I have problems with IPSEC too.
I have simple setup:
server<---lan--->routerboard1(ROS7)<---wireguard-->routerboard2(ROS7)<----l2tp/ipsec---->routerboard3(ROS6)
After upgrading routerboard2 from ROS 6.48.6 lts to ROS 7.5 stable - clients behind routerboard3 lost access to server. If i switch from l2tp/ipsec to simple pptp it works fine. Or i have to downgrade routerboard2 back to ROS6 to make it work again.
Is it a bug or feature?
Jotne
Wed Sep 07, 2022 8:19 am
And where is v7 config. It may be that after an upgrade you have to change some in the config.
You can start over with no config and then add config step by step.
hats
Wed Sep 07, 2022 11:05 am
here it is:
Config is very simple - ipsec default values - nothing changed
EDIT:
Since the forum have the space for post the config, why does it come to mind to use a third party site to host the configuration?
# sep/07/2022 10:58:27 by RouterOS 7.5
# software id = 8Y7Z-MPVF
# model = RB750Gr3
/interface pptp-server
# PPTP connections are considered unsafe, it is suggested to use a more modern VPN protocol instead
add name=pptp-in-komrat user=komrat
add admin-mac=DC:2C:6E:A5:90:D5 auto-mac=no comment=defconf name=bridge \
    protocol-mode=none
set [ find default-name=ether2 ] advertise=\
    10M-half,10M-full,100M-half,100M-full l2mtu=1598 speed=100Mbps
set [ find default-name=ether3 ] advertise=\
set [ find default-name=ether4 ] advertise=\
set [ find default-name=ether5 ] advertise=\
/interface l2tp-server
add name=l2tp-in-b.yurii user=b.yurii
add name=l2tp-in-bend_magazin user=bend_magazin
add name=l2tp-in-bendery user=bendery
add name=l2tp-in-bvp88 user=bvp88
add name=l2tp-in-dimasb user=dimasb
add name=l2tp-in-noodle user=noodle
add name=l2tp-in-oleg user=oleg
add name=l2tp-in-pavel.s user=pavel.s
add name=l2tp-in-rost user=rost
add name=l2tp-in-serghei_sw user=serghei_sw
/interface wireguard
add listen-port=51280 mtu=1420 name=wg-aaa
add listen-port=51281 mtu=1420 name=wg-mgmt
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
add name=default-dhcp ranges=192.168.1.10-192.168.1.99
add name=vpn_pool ranges=10.10.66.10-10.10.66.100
add address-pool=default-dhcp interface=bridge lease-time=1d name=defconf
/port
set 0 name=serial0
/ppp profile
set *0 only-one=yes
add change-tcp-mss=yes local-address=10.10.66.1 name=vpn_profile only-one=yes \
    remote-address=vpn_pool
set *FFFFFFFE only-one=yes
/system logging action
set 1 disk-file-name=log
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
    sword,web,sniff,sensitive,api,romon,dude,rest-api"
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2
/ipv6 settings
/interface l2tp-server server
set default-profile=vpn_profile enabled=yes one-session-per-host=yes \
    use-ipsec=yes
add interface=l2tp-in-bendery list=LAN
add interface=wg-aaa list=LAN
/interface ovpn-server server
set auth=sha1,md5
/interface pptp-server server
set enabled=yes
/interface wireguard peers
add allowed-address=10.100.9.2/32,172.16.64.0/24,172.16.48.0/24 interface=\
    wg-aaa persistent-keepalive=1m public-key=\
    "3xHf2EF8FOLsllOj/R5g0WkHKwbuLGU42tIDglyO0kA="
add allowed-address=172.16.100.1/32,172.16.128.240/28 endpoint-address=\
    xx.xx.xx.xx endpoint-port=51281 interface=wg-mgmt persistent-keepalive=\
    1m public-key="+bOAra4X60R6b2rFrU7x2hZKzrwSZpmpWcYB+GfiVj4="
add address=192.168.1.1/24 comment=defconf interface=bridge network=\
    192.168.1.0
add address=xx.xx.xx.xx/30 interface=ether1 network=xx.xx.xx.xx
add address=10.100.9.1/24 interface=wg-aaa network=10.100.9.0
add address=172.16.100.171/24 interface=wg-mgmt network=172.16.100.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf disabled=yes interface=*2
/ip dhcp-server lease
add address=192.168.1.108 client-id=1:d0:50:99:85:31:9e mac-address=\
    D0:50:99:85:31:9E server=defconf
add address=192.168.1.106 client-id=1:e0:d5:5e:27:91:1a mac-address=\
    E0:D5:5E:27:91:1A server=defconf
add address=192.168.1.107 client-id=1:d8:5e:d3:58:6a:84 mac-address=\
    D8:5E:D3:58:6A:84 server=defconf
add address=192.168.1.0/24 comment=defconf dns-server=8.8.8.8,8.8.4.4 \
    gateway=192.168.1.1
set servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.1.1 name=router.lan
/ip firewall address-list
add address=xx.xx.xx.xx list=admin
add address=172.16.128.240/28 list=admin
add address=10.10.66.0/24 list=allow_rdp_apteka
    established,related,untracked
add action=accept chain=input src-address-list=admin
add action=accept chain=input comment="l2tp tunnel" dst-port=500,1701,4500 \
    protocol=udp
    invalid log=yes
add action=accept chain=input dst-port=51280 protocol=udp
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid log=yes
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
add disabled=no dst-address=0.0.0.0/0 gateway=xx.xx.xx.xx
add disabled=no distance=1 dst-address=172.16.64.0/24 gateway=wg-aaa \
    pref-src="" routing-table=main scope=30 suppress-hw-offload=no \
    target-scope=10
add disabled=yes distance=1 dst-address=192.168.101.0/24 gateway=*18 \
    target-scope=10
add disabled=no distance=1 dst-address=172.16.128.240/28 gateway=wg-mgmt \
    target-scope=10
add disabled=no dst-address=172.16.136.0/24 gateway=l2tp-in-bendery
add disabled=no distance=1 dst-address=172.16.48.247/32 gateway=wg-aaa \
    target-scope=10
add disabled=no distance=1 dst-address=172.16.2.0/24 gateway=l2tp-in-bendery \
    target-scope=10
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip smb shares
set [ find default=yes ] directory=/pub
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/ppp secret
add name=rost profile=vpn_profile service=l2tp
add name=komrat profile=vpn_profile service=pptp
add name=noodle profile=vpn_profile service=l2tp
add name=oleg profile=vpn_profile service=l2tp
add name=pavel.s profile=vpn_profile service=l2tp
add local-address=10.10.66.1 name=bendery profile=vpn_profile remote-address=\
    10.10.66.2 service=l2tp
add name=b.yurii profile=vpn_profile service=l2tp
add name=serghei_sw profile=vpn_profile service=l2tp
add name=bvp88 profile=vpn_profile service=l2tp
add name=dimasb profile=vpn_profile service=l2tp
add name=bend_magazin profile=vpn_profile service=l2tp
add name=qd profile=vpn_profile service=l2tp
/system clock
set time-zone-name=Europe/Chisinau
/system identity
set name=rb-core.almdn.ext
/system leds
add interface=*1 leds="" type=wireless-status
/system resource irq rps
set ether5 disabled=no
set ether4 disabled=no
set ether3 disabled=no
set ether2 disabled=no
/tool mac-server
/tool mac-server mac-winbox
/user aaa
set use-radius=yes
Reason: removed 3rd party
PUDIS
Fri Sep 09, 2022 10:07 am
Can someone also test with Device: CCR1016-12G
I have this configuration:
https://help.mikrotik.com/docs/display/ROS/IPsec
#Site to Site IPsec (IKEv1) tunnel
V6.49.6 - All working OK
V7.5 - IPsec connection established - NAT not working!
Znevna
Fri Sep 09, 2022 10:19 am
There's no NAT involved in Site-to-Site config, and there shouldn't be any.
Post your anonymized config in here or in another new topic.
hats
Sun Sep 11, 2022 4:44 pm
Looks like there is nobody in mikroitk who is intrested in this issue solving. In my case i have replaced lt2p/isec server and clients with wireguard and all works as expected.
anav
Sun Sep 11, 2022 4:58 pm
Glad you got a working vpn there HATS, I looked at your config and was to complex for me to figure out LOL.
Wireguard is direct and understandable, and probably adequate for any homeowner and small business.
As for the rest, if you don't share your config for FREE assistance, suggest find another forum.
kiragun
Sun Sep 18, 2022 12:27 am
Hello there.
I swap my CHR 7.5 to hEX with 7.5 stable-release firmware, and I have NAT problem with L2TP+ipsec.
NAT with another SSTP tunnels work well.
Networking map:
<host>---[RB-7.5](wireguard)---(wireguard)[RB-7.5_VPN-Server]<l2tp+ipsec>---<l2tp+ipsec>[RB-6.48_VPN-Client]
Maybe, it's trouble with hardware encrypting?
If I start ping, 1 packet per 100 maybe work correctly.
I make 1-to-1 configuration to new board:
set authentication=mschap2 default-profile=l2tp-profile enabled=yes use-ipsec=required
hats
Sun Sep 18, 2022 5:59 pm
Hello there.
Networking map:
I have had exact case. 99% packet loss. 10 days support ignoring my ticket. Switched from l2tp/ipsec to wireguard. I can't wait for ages.
hats
Mon Sep 19, 2022 8:33 pm
At last i have answer from support:
"Thank you for the report. We are currently investigating issues with the crypto driver on MMIPS (including hEX) devices. Hopefully, the issue can be resolved soon."
Znevna
Mon Sep 19, 2022 8:40 pm
That doesn't sound like a NAT issue that everyone was screaming about in this topic..
hats
Tue Sep 20, 2022 3:17 pm
A lot of people complain about IPSEC. You can easily find it even in topic name.
Znevna
Tue Sep 20, 2022 3:46 pm
Yes, with a magic keyword "NAT".
And the intial post was about CCR1036 that's a totally different beast than your tiny hEX.
And recently someone else hijacked this thread with CCR1016, that again is a totally different beast than your hEX.
You found a bug on mmips, congrats, but is it related to whatever else this topic is about? we don't know, because this topic is a pile of different unrelated issues right now thanks to all the hijackers, yourself included.
ssh88
Sat Apr 20, 2024 3:14 pm
I'm loosing my mind over IPSec tunnel. I have three locations; routers on all three were running RouterOS 6. Everything worked flawlessly for years.
Recently we bought new router for one of the locations. This router has version 7 installed. I've made practically identical configuration, but the problem looks very strange.
location A: new router
location B, C: existing infrstructure
- IPSec tunnels are establishet. Routers can ping each other.
- I can connect from computer on location A to router B, winbox opens, but closes imediatelly.
- If i want to log on router B from location A, the winbox hangs on "downloading descriptors",
- I can establish remote desktop connection from location A to computers on location B and vice versa,
- I can access network resources from location B to location A without problem - branch office file server.
- I can access SMB network resources from A to B with IP, but can't access them with fqdn (actually can, but it is really slow), which is strange and i can't understand it, because the network name resolution works and is finished in a fraction of a second,
To me it looks like there are packets lost during the transmission, but i can't figure out how - most of the configuration was copied from the old router.
Fasttrack is turned off.
add action=accept chain=forward comment="FWD :: location A to this main subnet" \
dst-address=10.77.10.0/24 src-address=10.77.20.0/24
add action=accept chain=input comment="IN :: location A to this router" \
add action=accept chain=forward dst-address=10.77.20.0/24 src-address=\
10.77.10.0/24
Has there been some changes between 6.49 and 7.14? Can be there some compatibility issues between versions?
thank you for your help in advance and best regards
Users browsing this forum: alibloke, massinia and 109 guests
