stamatis123
CRS328-24P-4S+RM No PoE tab!!
Fri Jun 03, 2022 8:23 am
Hello everyone, was wondering if anyone came across this and solved it
Yesterday I opened up a box with a CRS328-24P-4S+RM which I was “saving” in case some project came up.
Well, to my surprise the switch does not deliver PoE power, and the PoE tab is missing from the interfaces. I’ve tried updating as well as netinstalling but no luck. I’ve had this happen to me with a PowerBox Pro in the past which was never fixed but I didn’t mind that much, but the CRS is a significantly more expensive piece of equipment and unavailable to purchase right now.
Of course I will send it back to my distributor (don’t remember though how long ago I purchased it though) but was wondering if anyone has a quick fix.
tangent
Re: CRS328-24P-4S+RM No PoE tab!!
Fri Jun 03, 2022 12:07 pm
What OS is it running?
Which WinBox version are you running?
There are three places that Ethernet interfaces are listed in WinBox:
  • Bridge → Ports
  • Switch → Port
  • Interfaces → Interface
Only the last one shows a PoE configuration tab on the individual ports.
What do you get from a "/interface ethernet poe print" command?
gotsprings
Fri Jun 03, 2022 1:45 pm
I have a 328 that is supposed to be delivered today. I will be logging into it ASAP and looking at interfaces.
stamatis123
Mon Jun 06, 2022 7:45 pm
YOU SHOULD!!
stamatis123
Mon Jun 06, 2022 7:49 pm
  • Bridge → Ports
  • Switch → Port
Winbox 3.35, routerOS 6.47.10, of course looking in the interfaces window. As I've mentioned it has happened before with a PoerBox Pro. I've tried upgrading, downgrading as well as netinstall... nothing worked. I guess bad firmware from mamma Mikrotik. It's been RMA'd anyway, since (THANK GOD) was still unter warranty
tangent
Mon Jun 06, 2022 8:01 pm
routerOS 6.47.10
That release is a year old. Shouldn’t you try the current long-term stable version before returning it, at least?
gotsprings
Tue Jun 07, 2022 2:23 am
The unit I have powered up several WAPs right out of the box. Updated to router OS to 7, and one of the WAPs didn't power on. Updated the board... Came up on the next reboot.
ayger
Tue Jun 14, 2022 11:46 am
Just to be on the safe side, did you tried to netinstall it? Otherwise , RMA It and call it a day.
gotsprings
Tue Jun 14, 2022 3:27 pm
That assumes you can actually get a replacement.
Users browsing this forum: GoogleOther [Bot] and 10 guests
