I wanated to configure a device for manage 3 vlans, I mean ether1 trunk for three VLANs, and 2-3-4 ports for vlans untagged ports.
However it is done and working I have 6 percent of packet loss. Maybe somebody can relaise what mistake i did. (On the other end of the trunk all is fine.)
Code: Select all
add name=Bridge_PCs
add name=Bridge_Prod
add name=Bridge_Trunk
add name=bridge_Management
set [ find default-name=ether1 ] name=ether1_trunk
set [ find default-name=ether2 ] name=ether2_management
set [ find default-name=ether3 ] name=ether3_pcs
set [ find default-name=ether4 ] name=ether4_prod
/interface vlan
add interface=Bridge_Trunk name=vlan_Management vlan-id=21
add interface=Bridge_Trunk name=vlan_PCs vlan-id=26
add interface=Bridge_Trunk name=vlan_prod vlan-id=28
/interface lte apn
add name=DHCP_Pool ranges=192.168.5.1-192.168.5.50
/port
set 0 name=serial0
add bridge=Bridge_Trunk interface=ether1_trunk
add bridge=bridge_Management interface=ether2_management
add bridge=Bridge_PCs interface=ether3_pcs
add bridge=Bridge_Prod interface=ether4_prod
add bridge=bridge_Management interface=vlan_Management
add bridge=Bridge_PCs interface=vlan_PCs
add bridge=Bridge_Prod interface=vlan_prod
/interface bridge settings
set use-ip-firewall=yes
/ipv6 settings
/interface ovpn-server server
set auth=sha1,md5
add address=10.36.8.105/23 interface=Bridge_Prod network=10.36.8.0
set servers=10.36.2.11,10.36.2.12
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=10.36.9.254 pref-src=\
"" routing-table=main scope=30 suppress-hw-offload=no target-scope=10
/system clock
set time-zone-name=Europe/Budapest
