emils
Forum Veteran
Forum Veteran
WinBox v3.36 released!
Fri Jun 03, 2022 12:53 pm
What's new in v3.36:
*) do not set hidden field values as empty when adding new item;
*) fixed Graphing and Quickset graphs;
*) fixed default value for disabled wireless EAP methods field;
*) fixed issue with showing non-existing values;
*) fixed managed list category grouping when value is IP with port;
*) fixed missing icon for submenus that are hidden by skin;
*) fixed neighbour table filter "all" storage;
*) fixed saving and restoring of filter comboboxes;
*) fixed skin behavior for "Add" buttons with dropdown;
*) fixed value updating when it is changed and disabled;
*) fixed values with required "&" prefix;
*) fixed wifiwave2 frequency field;
*) show error when not enough space to complete file upload;
If you experience version related issues, then please report them to support@mikrotik.com.
Both Winbox 32-bit and 64-bit versions are available here:
https://www.mikrotik.com/download
cdemers
Re: WinBox v3.36 released!
Fri Jun 03, 2022 3:53 pm
Strange issue, connecting to test APs, wAP ac's tested running 7.3rc1 and 7.3rc2, very slow winbox. Running on wine 7.9 on Ubuntu 20.04
Connecting to any other v6 routers is fast like normal. Anyone else seeing this?
holvoetn
Fri Jun 03, 2022 4:03 pm
Running on Win11, no problems connecting to 7.3rc1, 7.3rc2, 7.2, 7.2.3.
Various ROS6 devices (mostly 6.49.5), no problems either.
cdemers
Fri Jun 03, 2022 4:35 pm
@holvoetn thanks for feedback.
Humm, ok so it's probably something on my end. I will have time later to test on other systems/software combinations to see what's causing it. Last version (3.35) works fine.
JJT211
Fri Jun 03, 2022 9:34 pm
Oh nice
infabo
Long time Member
Long time Member
Fri Jun 03, 2022 10:26 pm
Awesome!
anav
Sun Jun 05, 2022 4:36 am
Dont forget to update smartphone MT apps too please!!
jimmyz
Mon Jun 06, 2022 1:37 am
I keep having issues with the position of *some* windows inside winbox. They tend to move to the upper left corner of the enlarged window. Sometimes its only the pppoe-out1 or lte1 and sometimes its all of the opened windows, they get all mixed up, one on top of the other. It happens on my ubuntu2204 with wine 5.0.3 and I thought it was just me. But I tried it on w10, too.
strods
Mon Jun 06, 2022 8:17 am
Thank you for your report. The issue has been reproduced and we will try to resolve it in the upcoming WinBox/RouterOS releases.
ErfanDL
Mon Jun 06, 2022 9:26 am
And still does not have Dark Mode capability :)
jimmyz
Mon Jun 06, 2022 11:43 am
You are very welcome!
As a native linux user, believe me, no bug or lack of anything in winbox bothers me, but only one little thing: I am used (addicted) to the very fast copy-paste function of linux apps. Just selecting any text and middle-clicking is enough. Ctrl+c or Crtl+Ins and after Ctrl+v or Shift+Ins is killing me. Not to mention Select > right click > select "copy" > click elsewhere > right click > select "paste" and so on...
I know, this is up to the wine developers, not you. But I had to tell it somewhere! :=)
Last thought: well, you could compile winbox for linux!
vitaly2016
Mon Jun 06, 2022 12:06 pm
Is it possible to make filtering by COMMENT case insensitive?
I often search some thing by comment. But if comment is, for example, "Printer", but I try to filter "printer", nothing will be found.
I guess filtering by comment must be case insensitive.
nithinkumar2000
Mon Jun 06, 2022 10:06 pm
Same issue
Jotne
Mon Jun 06, 2022 11:29 pm
Its not an issue, its an feature request.
sinisa
Mon Jun 06, 2022 11:40 pm
- not fixed: open in new window :(
Can you pleeeease at least return the functionality we used to have?
Please?
rextended
Tue Jun 07, 2022 12:09 am
@sinisa, what not work? For me on both 32 and 64 versions "Open In New Window" work without any problem.
cbrown
Trainer
Trainer
Tue Jun 07, 2022 2:37 pm
Please?
Agreed but I think I read somewhere it’s a wine issue and not a Winbox issue. It does suck without it though.
strods
Wed Jun 08, 2022 7:41 am
For those who experience problems with the new window functionality - it is also working just fine for us. Indeed it seems to be Wine related. Have you tried to upgrade Wine first and then test this functioanliy?
cbrown
Trainer
Trainer
Wed Jun 08, 2022 2:23 pm
I am currently running wine-staging 7.9 with Winbox 3.36. When I try to open with "Open in New Window" selected it initially appears like nothing happens but then about 30 seconds later a window pops like router has been disconnected.
infabo
Long time Member
Long time Member
Wed Jun 08, 2022 2:28 pm
wine 7.7 here and new window thingy is broken. wine 7.10 has not landed on manjaro linux yet.
PS: what does "open in new window" actually? For me this looks like it forks another winbox process. When I tick the checkbox and hit connect the window flickrs for some 200ms. Nothing happens. Then I exit Winbox. After like 30 - 60sec suddenly another Winbox window appears and telling me it timed out to connect. Like wtf. I would suggest to avoid "cheap tricks".
cdemers
Wed Jun 08, 2022 2:31 pm
Indeed looks like a wine issue. I just wiped my wine prefix for winbox and redid it and it's been fine so far. Some old left over file probably, strange as I haven't had that issue before. Everything was already up to date. I didn't save a copy of the old wine prefix to compare, if it happens again I will. Using wine-7.10 (Staging)
jimmyz
Wed Jun 08, 2022 9:23 pm
Well,
here on wine-5.0.3 (Ubuntu 5.0.3-3ubuntu2) and ubuntu 21.10, "open in new window" starts immediatelly a new winbox window connected to the mt I selected.
Normal.
IntLDaniel
Wed Jun 08, 2022 9:27 pm
Please make DHCP Lease / Address List drop down menu alphabeticaly sorted, the same way like all other places where you can select address lists. Thanks!
rextended
Wed Jun 08, 2022 9:50 pm
@IntLDaniel is already possible, what exactly are you referring to?
sinisa
Wed Jun 08, 2022 9:53 pm
> Open in New Window
It all started months ago, can't really remember the date, I have reported it here but cannot find that post.
If I remember correctly, it started with Wine 6, and is still issue in Wine 7 (today it's 7.10 Staging on openSUSE Tumbleweed), and all versions in between.
This is tcpdump of the connection attempt:
[1|root@r7|~]tcpdump -i eth0 -n host 192.168.11.4
tcpdump: verbose output suppressed, use -v[v]... for full protocol decode
listening on wlan0, link-type EN10MB (Ethernet), snapshot length 262144 bytes
20:35:15.474158 IP 192.168.188.14.53444 > 192.168.11.4.8292: Flags [S], seq 4106296519, win 64860, options [mss 1380,sackOK,TS val 3154152991 ecr 0,nop,wscale 7], length 0
20:35:15.488577 IP 192.168.11.4.8292 > 192.168.188.14.53444: Flags [S.], seq 587906557, ack 4106296520, win 65084, options [mss 1240,sackOK,TS val 772457344 ecr 3154152991,nop,wscale 4], length 0
20:35:15.488629 IP 192.168.188.14.53444 > 192.168.11.4.8292: Flags [.], ack 1, win 507, options [nop,nop,TS val 3154153006 ecr 772457344], length 0
20:35:15.497415 IP 192.168.188.14.53444 > 192.168.11.4.8292: Flags [P.], seq 1:42, ack 1, win 507, options [nop,nop,TS val 3154153015 ecr 772457344], length 41
20:35:15.516603 IP 192.168.11.4.8292 > 192.168.188.14.53444: Flags [.], ack 42, win 4066, options [nop,nop,TS val 772457368 ecr 3154153015], length 0
20:35:15.532489 IP 192.168.11.4.8292 > 192.168.188.14.53444: Flags [P.], seq 1:52, ack 42, win 4066, options [nop,nop,TS val 772457387 ecr 3154153015], length 51
20:35:15.532517 IP 192.168.188.14.53444 > 192.168.11.4.8292: Flags [.], ack 52, win 507, options [nop,nop,TS val 3154153050 ecr 772457387], length 0
20:35:15.536130 IP 192.168.188.14.53444 > 192.168.11.4.8292: Flags [P.], seq 42:76, ack 52, win 507, options [nop,nop,TS val 3154153053 ecr 772457387], length 34
20:35:15.554634 IP 192.168.11.4.8292 > 192.168.188.14.53444: Flags [.], ack 76, win 4064, options [nop,nop,TS val 772457410 ecr 3154153053], length 0
20:35:15.584703 IP 192.168.11.4.8292 > 192.168.188.14.53444: Flags [P.], seq 52:86, ack 76, win 4064, options [nop,nop,TS val 772457438 ecr 3154153053], length 34
20:35:15.584745 IP 192.168.188.14.53444 > 192.168.11.4.8292: Flags [.], ack 86, win 507, options [nop,nop,TS val 3154153102 ecr 772457438], length 0
20:35:15.585012 IP 192.168.188.14.53444 > 192.168.11.4.8292: Flags [P.], seq 76:176, ack 86, win 507, options [nop,nop,TS val 3154153102 ecr 772457438], length 100
20:35:15.605216 IP 192.168.11.4.8292 > 192.168.188.14.53444: Flags [.], ack 176, win 4058, options [nop,nop,TS val 772457460 ecr 3154153102], length 0
20:35:15.608602 IP 192.168.11.4.8292 > 192.168.188.14.53444: Flags [P.], seq 86:282, ack 176, win 4058, options [nop,nop,TS val 772457461 ecr 3154153102], length 196
20:35:15.608643 IP 192.168.188.14.53444 > 192.168.11.4.8292: Flags [.], ack 282, win 506, options [nop,nop,TS val 3154153126 ecr 772457461], length 0
20:35:15.608950 IP 192.168.188.14.53444 > 192.168.11.4.8292: Flags [P.], seq 176:276, ack 282, win 506, options [nop,nop,TS val 3154153126 ecr 772457461], length 100
20:35:15.634706 IP 192.168.11.4.8292 > 192.168.188.14.53444: Flags [P.], seq 282:382, ack 276, win 4052, options [nop,nop,TS val 772457486 ecr 3154153126], length 100
20:35:15.635317 IP 192.168.188.14.53444 > 192.168.11.4.8292: Flags [P.], seq 276:376, ack 382, win 506, options [nop,nop,TS val 3154153153 ecr 772457486], length 100
20:35:15.661293 IP 192.168.11.4.8292 > 192.168.188.14.53444: Flags [P.], seq 382:1514, ack 376, win 4046, options [nop,nop,TS val 772457507 ecr 3154153153], length 1132
20:35:15.664184 IP 192.168.188.14.53444 > 192.168.11.4.8292: Flags [P.], seq 376:492, ack 1514, win 502, options [nop,nop,TS val 3154153181 ecr 772457507], length 116
20:35:15.683116 IP 192.168.11.4.8292 > 192.168.188.14.53444: Flags [P.], seq 1514:1646, ack 492, win 4039, options [nop,nop,TS val 772457538 ecr 3154153181], length 132
20:35:15.726137 IP 192.168.188.14.53444 > 192.168.11.4.8292: Flags [.], ack 1646, win 502, options [nop,nop,TS val 3154153243 ecr 772457538], length 0
So login has passed OK (if I try wirh wrong user/password it immeditely tells me so), and "downloading DLLs" (or something similar, it passes too quickly) also passes (there is nothing to download since I have already connected to this router with this ROS version), and then it stalls
20:35:25.746962 IP 192.168.11.4.8292 > 192.168.188.14.53444: Flags [.], ack 492, win 4039, options [nop,nop,TS val 772467602 ecr 3154153243], length 0
20:35:25.747006 IP 192.168.188.14.53444 > 192.168.11.4.8292: Flags [.], ack 1646, win 502, options [nop,nop,TS val 3154163264 ecr 772457538], length 0
20:35:35.998840 IP 192.168.11.4.8292 > 192.168.188.14.53444: Flags [.], ack 492, win 4039, options [nop,nop,TS val 772477852 ecr 3154163264], length 0
20:35:35.998887 IP 192.168.188.14.53444 > 192.168.11.4.8292: Flags [.], ack 1646, win 502, options [nop,nop,TS val 3154173516 ecr 772457538], length 0
20:35:46.228604 IP 192.168.11.4.8292 > 192.168.188.14.53444: Flags [.], ack 492, win 4039, options [nop,nop,TS val 772488082 ecr 3154173516], length 0
20:35:46.228634 IP 192.168.188.14.53444 > 192.168.11.4.8292: Flags [.], ack 1646, win 502, options [nop,nop,TS val 3154183746 ecr 772457538], length 0
And here Winbox gives up, counts 5 seconds, reconnects and from now on everything works fine.
Same thing happens when both devices are on same network segment, when using cable or wifi, even via VPN.
Yes, it might be something in newer Wine, but maybe it would be easier for developers of Winbox to communicate with developers of Wine...
IntLDaniel
Thu Jun 09, 2022 12:57 am
I mean this menu under DHCP static lease edit window...this list of address lists is not alphabeticaly sorted (check on your own Mikrotik).
rextended
Thu Jun 09, 2022 1:01 am
Yes @IntLDaniel, now I understand where, and is true: is not alphabetically sorted (tested on 3.36 both 32 and 64, ROS 6.46.8 and 6.48.6)
IntLDaniel
Thu Jun 09, 2022 10:22 am
Yes, very uncomfortable for us. I divide hundreds of our wisp users via DHCP to different groups, sometimes I need to change it and it is very difficult to search the right group in the list :-(
jookraw
Thu Jun 09, 2022 10:56 am
I think that I found a bug with WiFIwave2 on WinBox.
When checking for a WiFi client connected to my hAP ac3, I spotted this:
WinBox is not showing Hours, Minutes or Days.
CLI is fine, like below:
[the-only-user@hAP-ac3] > /interface/wifiwave2/registration-table/print
Flags: A - AUTHORIZED
Columns: INTERFACE, SSID, MAC-ADDRESS, UPTIME, SIGNAL
#   INTERFACE  SSID            MAC-ADDRESS        UPTIME         SIGNAL
0 A wifi-iot   <redacted> IoT  7C:49:EB:XX:XX:XX  23h34m48s90ms  -36
mkx
Thu Jun 09, 2022 2:13 pm
Yup, it's in seconds. And I agree that humanized display would be nicer.
tangent
Thu Jun 09, 2022 5:05 pm
Speaking of time in WinBox, the address list timeout input field in IP filters should allow inputs like “1h” as the CLI does, and it should translate inputs like “01:00:00” to “1h” for the same reason.
jerogabe
Sun Jun 12, 2022 4:43 pm
Bug v3.36?
sidebar bug
TomosRider
Fri Jul 01, 2022 10:05 am
I didnt find any issues with this version. Great job guys!
densenator
Sun Jul 10, 2022 10:24 am
I confirmed that bug with Wireless Interface in hAP lite (smips). Please fix it.
rextended
Sun Jul 10, 2022 1:24 pm
I confirm than with Winbox 3.36 on 6.48.6 can not save wireless settings, like data rates, tx-power, tx-power mode, etc. on mibsbe (i do not check others)
On CLI work correctly as expected, and the changes are reflected on winbox
EDIT: Fixed on 3.37
Reason: Fixed on 3.37
ivicask
Sun Jul 10, 2022 1:43 pm
It's same issue regardless of rotueros or architecture can confirm.
maigonis
Thu Jul 14, 2022 1:57 am
Me too, just opened forum to dig more info about this. Affects v7 also.
Unintentional
Tue Jul 19, 2022 12:30 pm
Is there any word on a macos version? Picking up more and more issues with wine config etc.
emils
Forum Veteran
Forum Veteran
Tue Jul 19, 2022 12:40 pm
WinBox v3.37 is released.
viewtopic.php?t=187734
Users browsing this forum: andrejtom, fredcom, nonolk, pajapatak and 26 guests
