nowires
Simple queues don't work with Ares
Fri Sep 21, 2007 12:40 pm
I have attached one rule, but there are many clients like this. No matter the queue, they uses at least 100 kbps of upload.
winxp2000
Re: Simple queues don't work with Ares
Sun Sep 23, 2007 9:57 pm
Could you post you setting detail of the simple queue ?
We can not see any issue about you simple queue from your picture.
maximan
Trainer
Trainer
Mon Sep 24, 2007 10:35 pm
Make a torch to this address
M.
omega-00
Tue Sep 25, 2007 4:00 am
Are you setting both the default AND max value to 32k? (they're on 2 separate tabs)
laze81
Wed Sep 26, 2007 1:59 am
I had the same problem
yesterday I buyed new MT v3.0rc5 for my new sata and just restore backup from 2.9 to 3.0rc5 (but with same problem with p2p)
today made a fully reset and configured it from beginning(without restore)
For now queues working ok but still can't limit Ares traffic
titius
Tue Oct 09, 2007 11:14 pm
You cant limit all encrypted traffic, BUT, make mangle rules, first mangle with connection mark, then make packet mark with firstly created connection mark for IP or range of IP addresses, in that way you can limit every user with rate that you want.
At least it is how I did it, and it works fine.
Users browsing this forum: mikruser and 54 guests
