k6ccc
VLAN under Bridge
Sun Jun 05, 2022 2:20 am
I will start out by saying that I do NOT use bridges in RouterOS - and therefore do not understand how to make them work. I use a RouterOS ONLY for router functions, and use switches where I need a switch. Just for good measure, the Mikrotik documentation pages were down for maintenance when I was doing most of this (back up now, but did not help)...
What I am trying to accomplish is to take one of my old RB750r2 routers and make it function as a simple VLAN switch, with 1 trunk port containing 4 VLANs, and the other four ports each having one of the VLANs (untagged) - sometimes referred to as a "Router on a Stick". If I was doing this in a SwitchOS devices, I would be done in 30 seconds (or less). This is being done only to avoid having to run four Cat-5 cables to a rack shelf with four Raspberry Pis on it.
I followed pcunite's nice tutorial in: viewtopic.php?t=143620
using the switch example and could not make it work. I poked at it for a while and still does not work. So clearly I don't know what I'm doing.
If the image does not work, here is a direct link to it: http://extraphotos.info/mikrotik/Router-3.png
I have eliminated most of the firewall simply to make sure that was not causing me any problems. Once I get the bridge working the way it should, I can put the security back. This is all on my home LANs behind my RB4011 main router.
BTW, if I should be doing this completely different, let me know...
# jan/02/1970 01:36:13 by RouterOS 6.49.6
# software id = <redacted>
# model = RouterBOARD 750 r2
# serial number = <redacted>
add admin-mac=4C:5E:0C:04:3E:2D auto-mac=no comment=defconf name=BR-1 \
    protocol-mode=none
/interface vlan
add interface=BR-1 name=VALN_006 vlan-id=6
add interface=BR-1 name=VLAN_005 vlan-id=5
add interface=BR-1 name=VLAN_101 vlan-id=101
add interface=BR-1 name=VLAN_201 vlan-id=201
add comment=defconf name=WAN
add comment=defconf name=LAN
add bridge=BR-1 comment=defconf frame-types=\
    admit-only-untagged-and-priority-tagged ingress-filtering=yes interface=\
    ether2 pvid=6
    ether3 pvid=5
    ether4 pvid=201
    ether5 pvid=101
add bridge=BR-1 frame-types=admit-only-vlan-tagged ingress-filtering=yes \
    interface=ether1
/interface bridge vlan
add bridge=BR-1 tagged=ether1 untagged=ether3 vlan-ids=5
add bridge=BR-1 tagged=ether1 untagged=ether2 vlan-ids=6
add bridge=BR-1 tagged=ether1 untagged=ether5 vlan-ids=101
add bridge=BR-1 tagged=ether1 untagged=ether4 vlan-ids=201
add comment=defconf interface=BR-1 list=LAN
add comment=defconf disabled=yes interface=ether1 list=WAN
add address=192.168.201.253/24 interface=ether4 network=192.168.201.0
add address=192.168.101.253/24 interface=ether5 network=192.168.101.0
/ip dhcp-client
# DHCP client can not run on slave interface!
add comment=defconf disabled=no interface=ether1
    192.168.88.1
set allow-remote-requests=yes
/ip dns static
    established,related,untracked
add action=accept chain=input comment=Temp connection-state=""
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
    connection-state=new disabled=yes in-interface-list=WAN
/system identity
set name=RasPi-switch
/tool mac-server
/tool mac-server mac-winbox
anav
Re: VLAN under Bridge
Sun Jun 05, 2022 4:50 am
viewtopic.php?t=182276
Its not a router, so the only thing you need to do is identify the management vlan............
Also you forget to turn vlan filtering on (last step of pcunites setup :-0 )
As for the config, simplify, since you dont state it explicity I have to guess and will use VLAN5 as your trusted subnet ( base or management subnet ). To be clear,
the MT device should get its IP address from this trusted subnet. THis vlan is the only that needs to be identified. ENJOY
    protocol-mode=none  vlan-filtering=yes
/interface vlan
add name=management
    ether2 pvid=6
    ether3 pvid=5
    ether4 pvid=201
    ether5 pvid=101
    interface=ether1
set discover-interface-list=management
add bridge=BR-1 tagged=BR-1,ether1 untagged=ether3 vlan-ids=5
add interface=vlan_005 list=management
add address=192.168.xx.yy/24 interface=vlan_005 network=192.168.xx.0   { address statically set from trusted subnet }
set allow-remote-requests=yes servers=192.168.xx.1 comment="dns through trusted subnet gateway"
add disabled=no dst-address=0.0.0.0/0 gateway=192.168.xx.1 comment="ensures route avail through trusted subnet gateway"
/system identity
/tool mac-server
set allowed-interface-list=NONE
set allowed-interface-list=management
k6ccc
Sun Jun 05, 2022 8:17 am
Thanks anav!
You made a couple of incorrect assumptions on management, but that got me close enough to make it work. Just a little tweeking to do now.
Management will actually (at least for now) be on VLAN 201 via the trunked port - and I have that working.
I'm going to have to stare at it for a while to completely make sense of it, but I think I should eventually be able to figure it out.
As I said in my original post, if I were doing this in SwitchOS, it would have taken just a few seconds...
anav
Sun Jun 05, 2022 1:18 pm
Thanks anav!
Yeah, LOL, it took me a few seconds to put that out........ I find it easier than switchOS LOL.
Users browsing this forum: ShindigNZ and 69 guests
