Pigsfoot
RBM33G POE Out
Sun Jun 05, 2022 8:53 pm
Can anyone confirm if the RBM33G is capable of POE Out please. I think i'm right in saying the board can be powered via POE but i need it to provide POE out when the board itself is powered via the DC Jack..
If not is there an alternative? I need a board that is LTE capable via an miniPCI card with a SIM slot and powered via a mains power supply but must have POE out. It also has to be a RB as its part of a bigger solution that goes in a custom made enclosure so can't be something like the SXT.
TIA
krafg
Re: RBM33G POE Out
Tue Jun 07, 2022 11:21 pm
RBM33G only supports PoE IN. So you can not use it to power another devices.
SXT LTE is the only LTE device that can do that you need.
An alternative can be use a PoE router as "switch" like PowerBox Pro for outdoor or hEX PoE for indoor.
Regards.
Users browsing this forum: No registered users and 43 guests
