blekotal
Is the RBLHG-2nD-XL even legal?
Mon Jun 06, 2022 11:49 am
I mean it has an antenna gain of 21dBi. How does that work in a European country (Poland) that has a legal limit of 20dBi max?
mkx
Re: Is the RBLHG-2nD-XL even legal?
Mon Jun 06, 2022 11:59 am
When selecting correct country in wireless settings, ROS will know about maximum allowed EIRP of 20 dBm. Since antenna gain will be set to 21 dBi, ROS will be able to calculate correct maximum allowed Tx power - output from wireless power amplifier (at -1 dBm).
So yes, this unit is legal ... if user sets it up correctly.
rextended
Mon Jun 06, 2022 12:03 pm
Is a outdoor device, and outdoor frequency from 5490 to 5710 is allowed in all E.U. @27dBm (2 stream, or @30dBm 1 stream)
But this can not work as AP, just as CPE/Client or a single-bridge mode... (until you do not buy Level 4+ license)
Then if you want to put it inside the house, go ahead :lol:
Indoor from 5170 to 5250 are allowed @23dBm (2 stream, or @26dBm 1 stream)
Only the limited portion Indoor from 5250 to 5330 is limited to @20dBm (2 stream, or @23dBm 1 stream)
Remember: on outdoor only from 5490 to 5710 are allowed
So, in conclusion, it is always illegal if you use it outside on indoor frequencies, the only allowed go from 5490 to 5710
EDIT: product error...
timotei
Mon Jun 06, 2022 12:27 pm
RBLHG-2nD-XL is 2.4GHz only......
rextended
Mon Jun 06, 2022 1:03 pm
Ops... RBLHG-5HPnD-XL
blekotal
Mon Jun 06, 2022 1:06 pm
-1dBm? So off?
rextended
Re: Is the RBLHG-2nD-XL even legal?  [SOLVED]
Mon Jun 06, 2022 1:08 pm
0dBm = 1mW
-1dBm ~ 795µW = 0,795mW = 0,000795W...
Is a outdoor device, and outdoor frequency from 2402 to 2482 is allowed in all E.U. @20dBm (2 stream, or @23dBm 1 stream)
Indoor from 2402 to 2482 are allowed at the same @20dBm (2 stream, or @23dBm 1 stream)
blekotal
Mon Jun 06, 2022 1:36 pm
1 stream = 20MHz channel width
2 stream = 40MHz channel width
correct?
rextended
Mon Jun 06, 2022 1:47 pm
no... stream = stream, channel = channel...
I do not use "channel" word for not misunderstand channel size...
1 stream = use only vertical or horizonal polarization for transmit (use only one tx chain)
2 stream = use both (default, use both tx chain)
blekotal
Mon Jun 06, 2022 3:54 pm
While I know my setting are correct and within legal limits how do you protect yourself when working around other antennas you don't have access to? I always remember this post from bpwl where he states that at a certain power output you can go blind. Where is the limit after which can the Tx power harm a person working around the antenna?
bpwl
Mon Jun 06, 2022 4:49 pm
Well some of this is old info. Safe distance for 20dBm was documented as about 0.15 meter in EU . It would double for a 6dBm higher power .
Full math is available now: https://educateemf.com/what-is-a-safe-d ... fi-router/
Know your LOG math. 3dB is 0.3Bell or 0.30103 , that is the log10 value of 2. (10**0.30103= 2). (10**0.0=1) (10**2=100)
Notation
** or ^ or exp
0 dBm is 1 milliWatt , 3 dBm is 2 mW, 6dBm is 4 mW, 10 dBm is 10mW, 20 dBm is 100mW, 23 dBm is 200mW, 26dBm is 400 mW, 30 dBm is 1000mW
and then also
-3 dBm is 0.5mW, -10dBm is 0.1 mW or 100µW
So that -1 dBm is far from OFF, it is around 0.8 mW
Received signals are very weak compaired to the transmitted power . e.g. -86dBm ???
There must be a conversion table somewhere, to make it easy: Aargh yes .... https://www.rapidtables.com/convert/pow ... to_mW.html
We also learn from the presentations by Ron Touw, that the MT radio's do not obey settings below 2 dBm (seems to be the minimum level)
Remember in the ETSI/FCC regulations there are frequencies
- that are indoor only (forbidden outdoor, would disturb priority services)
- that are outdoor also (allowed everywhere)
- I don't know of any indoor only frequencies, no one to disturb there but yourselves
Users browsing this forum: No registered users and 25 guests
