I've created a tunnel to hurricane electric. Most of things seem to be working correctly. M6y LAN devices get proper ipv6 and can connect to most ipv6 servers on the internet. However, not all.
From lan device (windows):
Pinging game.flyingpenguintech.org [2600e001:600::1] with 32 bytes of data:
Reply from 2600e001:600::1: time=98ms
That works great. However:
Pinging 2a05:XXXX:XXXX:XXXX:5400:4ff:fe05:4b52 with 32 bytes of data:
Request timed out.
If I try pinging my lan device from that other computer it works great:
PING 2001:XXXX:XXXX:XXXX:f0e9:8eff:fe33:2b46 56 data bytes
64 bytes from 2001:XXXX:XXXX:XXXX:f0e9:8eff:fe33 icmp_seq=1 ttl=57 time=3.50 ms
but not the other way around.
PING from mikrotik to 2a05:XXXX:XXXX:XXXX:5400:4ff:fe05:4b52 works fine, just not from the lan device.
