DonPablo
OpenVPN Client2Site - TLS Fail
Mon Jun 06, 2022 5:22 pm
I'm trying to use OpenVPN config file, which worked just fine when used in pc app, but I dont know why I'm getting
ovpn-out1: terminating... - TLS failed
in logs
dev tun
persist-tun
persist-key
cipher AES-128-CBC
ncp-ciphers AES-128-GCM
auth SHA256
tls-client
client
resolv-retry infinite
remote XXX.XX.XXX.XXX 1194 udp
verify-x509-name "THE_NAME" name
auth-user-pass
remote-cert-tls server
<ca>
-----BEGIN CERTIFICATE-----
-----END CERTIFICATE-----
</ca>
<cert>
</cert>
<key>
-----BEGIN PRIVATE KEY-----
-----END PRIVATE KEY-----
</key>
key-direction 1
<tls-auth>
# 2048 bit OpenVPN static key
-----BEGIN OpenVPN Static key V1-----
-----END OpenVPN Static key V1-----
</tls-auth>
I Imported ovpn file as certificates, and i got Trusted certificate, and Trusted Key,
But I think the problem is in
becase I didn't use it in any way.
Can I get any advice?
I red earlier that TLS doesn't work on RouterOS, but that can refer to different case.
I'm on RouterOS 7.2.3
Sob
Re: OpenVPN Client2Site - TLS Fail  [SOLVED]
Tue Jun 07, 2022 3:03 am
Unfortunately for you, even latest RouterOS doesn't support tls-auth.
DonPablo
Tue Jun 07, 2022 10:29 am
OK, Thank You For your answer.
Have a nice day : - )
Edit:
Do we know, when tls-auth support can be expected?
rndm
Tue Nov 29, 2022 12:43 pm
Any updates on this from Mikrotik team?
mcwnuq
Mon Nov 13, 2023 7:21 pm
It is implemented in 7.12 and it works, thank you MikroTik team!
Users browsing this forum: No registered users and 39 guests
