mikear
ntp-client status waiting
Mon Jun 06, 2022 5:47 pm
I have an RB3011 (router), a hAP ac lite (bridge) and a cAP (bridge). On the two Mikrotik devices configured as bridge the ntp-client is updated correctly however on the router the status remains 'waiting'.
All devices have the same RouterOS versin (7.2.3) and all three devices work, with exeption of the ntp-client, as expected.
An export of the /system/ntp/client shows:
/system ntp client
set enabled=yes
/system ntp client servers
add address=0.pool.ntp.org
add address=1.pool.ntp.org
add address=2.pool.ntp.org
add address=3.pool.ntp.org
The debug logs show the following.
16:35:31 echo: ntp,debug TMP: Start resolving name: 0.nl.pool.ntp.org
16:35:31 echo: ntp,debug TMP: Start resolving name: 1.nl.pool.ntp.org
16:35:31 echo: ntp,debug TMP: Start resolving name: 2.nl.pool.ntp.org
16:35:31 echo: ntp,debug TMP: Start resolving name: 3.nl.pool.ntp.org
16:35:31 echo: ntp,debug TMP: Resolved address: 0.nl.pool.ntp.org -> 162.159.200.1
16:35:31 echo: ntp,debug TMP: Resolved address: 1.nl.pool.ntp.org -> 212.114.109.139
16:35:31 echo: ntp,debug TMP: Resolved address: 2.nl.pool.ntp.org -> 94.198.159.15
16:35:32 echo: ntp,debug TMP: Resolved address: 3.nl.pool.ntp.org -> 40.119.148.38
16:35:32 echo: ntp,debug TMP: Unreachable and iburst enabled. Send burst
16:35:32 echo: ntp,debug TMP: tx dst-ip:162.159.200.1
16:35:32 echo: ntp,debug TMP: tx dst-ip:212.114.109.139
16:35:33 echo: ntp,debug TMP: tx dst-ip:162.159.200.1
16:35:33 echo: ntp,debug TMP: tx dst-ip:212.114.109.139
16:35:34 echo: ntp,debug TMP: tx dst-ip:162.159.200.1
16:35:34 echo: ntp,debug TMP: tx dst-ip:212.114.109.139
16:35:35 echo: ntp,debug TMP: tx dst-ip:162.159.200.1
16:35:35 echo: ntp,debug TMP: tx dst-ip:212.114.109.139
16:35:36 echo: ntp,debug TMP: tx dst-ip:162.159.200.1
16:35:36 echo: ntp,debug TMP: tx dst-ip:212.114.109.139
16:35:36 echo: ntp,debug TMP: Unreachable and iburst enabled. Send burst
16:35:36 echo: ntp,debug TMP: tx dst-ip:94.198.159.15
16:35:37 echo: ntp,debug TMP: tx dst-ip:162.159.200.1
16:35:37 echo: ntp,debug TMP: tx dst-ip:212.114.109.139
16:35:37 echo: ntp,debug TMP: Unreachable and iburst enabled. Send burst
16:35:37 echo: ntp,debug TMP: tx dst-ip:40.119.148.38
16:35:38 echo: ntp,debug TMP: tx dst-ip:162.159.200.1
16:35:38 echo: ntp,debug TMP: tx dst-ip:212.114.109.139
16:35:38 echo: ntp,debug TMP: tx dst-ip:94.198.159.15
16:35:39 echo: ntp,debug TMP: tx dst-ip:162.159.200.1
16:35:39 echo: ntp,debug TMP: tx dst-ip:212.114.109.139
16:35:39 echo: ntp,debug TMP: tx dst-ip:40.119.148.38
16:35:40 echo: ntp,debug TMP: tx dst-ip:162.159.200.1
16:35:40 echo: ntp,debug TMP: tx dst-ip:212.114.109.139
16:35:40 echo: ntp,debug TMP: tx dst-ip:94.198.159.15
16:35:41 echo: ntp,debug TMP: tx dst-ip:40.119.148.38
16:35:42 echo: ntp,debug TMP: tx dst-ip:94.198.159.15
16:35:43 echo: ntp,debug TMP: tx dst-ip:40.119.148.38
16:35:44 echo: ntp,debug TMP: tx dst-ip:94.198.159.15
Why do I not receive any replies.
k6ccc
Re: ntp-client status waiting
Mon Jun 06, 2022 11:31 pm
Are there devices all at the same location - or more important, using the same internet? Recently someone else here on the forum had their ISP blocking NTP traffic.
kevinds
Long time Member
Long time Member
Tue Jun 07, 2022 1:47 am
Try turning the NTP client off (uncheck Enabled), Hit Ok, then go back and turn it back on...
I had this recently on one of mine and that fixed it.
mikear
Tue Jun 07, 2022 8:57 am
Did not solve it, neither as rebooting the device...
mikear
Tue Jun 07, 2022 9:20 am
Yep, all are at the same locations and using the same internet. The RB3011 is behind the ISP router where the RB3011 is (currently) set as DMZ.
pe1chl
Tue Jun 07, 2022 10:45 am
It could be that the ISP blocks packets with source port 123, and thus the router which sends direct untranslated queries won't get replies.
The other two devices are behind NAT, their port number is translated by the NAT, and they get replies.
It is becoming more or less common to block source port 123 to prevent clients from running NTP servers.
mikear
Tue Jun 07, 2022 9:19 pm
OK, interesting! Would it be possible to NAT the request to the ntp-server from the router internally?
pe1chl
Tue Jun 07, 2022 9:27 pm
Yes. Try that, it should work. When it solves the problem, it is an ISP filter.
Of course you can also (at least with v7) specify the different devices mutually as servers. Then at least you have time sync while you are trying to solve the issue.
mikear
Re: ntp-client status waiting  [SOLVED]
Wed Jun 08, 2022 6:46 pm
OK, recollecting, my router with RouterOS 7.2 could not update the date/time information from NTP servers. Some tests (ping/traceroute) revealed that the IP addresses of the NTP servers were actually resolved but UDP port 123 was blocked, probably by my ISP. Searching and collating some of the forum posts on NTP lead me to the following firewall rule. This solved the problem.
add action=masquerade chain=srcnat comment="NTP NAT masquerade " dst-port=123 protocol=udp to-ports=12300-12390
The ports (12300-12390) can be changed ad lib. It does not matter very much where you put this rule in the NAT-records, but if it does not work out of the box you may need to move it upward. After disabling/enabling the NTP-client, in just a few seconds the time settings are synchronised, of course under the condition that you entered some valid NTP-servers (like 0.pool.ntp.org, ...)
Thanks all for your help!
pe1chl
Wed Jun 08, 2022 8:01 pm
Ok it would be advisable to also include an out-interface matcher e.g. out-interface-list=WAN (assuming you have that list and your internet interface is in it).
klema
Mon Nov 14, 2022 11:36 am
Thank you very much, it works
informiq
Thu Apr 11, 2024 11:43 am
Great!!!
I had this problem for a while and with this it is solved.
Thank you!!!
pe1chl
Thu Apr 11, 2024 5:02 pm
It has been discussed in other topics as well, after some denial the users install such a NAT rule and all starts working.
(even after the ISP has claimed "they do not filter")
Of course it would be best when MikroTik added a new option to NTP client: use random source port number (instead of 123)...
Users browsing this forum: erlinden, hazem and 111 guests
