How are things connected together as ether1 is usually the WAN connection?I configure 2406:xxx::1/64 to ethernet1 and 2406:xxx::2/64 to a laptop. When I try to traceroute to Internet, it doesn't go beyond 2406:xxx::1. Please help.
Unlikely. add-default-route=yes is OK on point-to-point connections such as PPPoE, the usual misconfiguration is to also enable add-default-route in the IPv6 DHCP client.if using ppp then you maybe need to "interface/pppoe-client/set add-default-route=no ..."
you're right, i pasted the wrong path.Unlikely. add-default-route=yes is OK on point-to-point connections such as PPPoE, the usual misconfiguration is to also enable add-default-route in the IPv6 DHCP client.if using ppp then you maybe need to "interface/pppoe-client/set add-default-route=no ..."
