mercer2
CCR2216-1G-12XS-2XQ constanly reboots!!!!
Tue Jun 07, 2022 5:47 am
Hi
first time user of mikrotik, I was super excited when they announce the router since I was schedule for a 40g internet installed with a 100g LAN.
CCR2216-1G-12XS-2XQ firmware version 7.2.3 and downgraded to 7.1.5 still same issues
unfortunately the router keeps rebooting, and without even pushing it, im a home user and my highest speed in any pc is 10g.
the router reboots with a 2% load cpu and a traffic of 20MB/s
WHAT TO DO??????
thank you very much for any pointers, I have never had such a failure in a unit like this.
very disappointing
nescafe2002
Forum Veteran
Forum Veteran
Re: CCR2216-1G-12XS-2XQ constanly reboots!!!!
Tue Jun 07, 2022 7:02 am
Are there any hints in the log? Kernel panic? Watchdog reboot? Out of memory condition?
Did you submit autosupout.rif to support?
I am experiencing reboots on 7.2.3 on smaller devices and they are gone in 7.3rc2.. not sure why.
mercer2
Tue Jun 07, 2022 7:36 am
I just tried with the 7.2.3 fw as well
same result it did reboot at the 12 minute mark
this is my firt experience with mikrotik, I will submit a ticket with the autosuport.rif
no idea how to vie log before the crash or what causes it
log says the following error
router rebooted without proper shutdown, probably power outage
erlinden
Tue Jun 07, 2022 9:02 am
Did you upgrade both RouterOS and firmware?
Could it be power related? Have you tried with a different power cable?
rextended
Tue Jun 07, 2022 11:47 am
You try to change PSU used or both are powered?
normis
Tue Jun 07, 2022 3:16 pm
Because newer versions usually contains improvements and fixes.
For mercer2, please try latest 7.3 and see if issue is still there.
mercer2
Tue Jun 07, 2022 7:11 pm
both psu are powered in different power strips
with 2 x eaton 9px3000rt online ups
and 2 x eaton epdu g3 managed pdu's
mercer2
Tue Jun 07, 2022 7:12 pm
I have tried:
7.1.5
7.2.3
7.3rc2
only thing left to try is a 7.4beta2
should I try that beta?
mercer2
Tue Jun 07, 2022 8:34 pm
I have tried:
7.1.5
7.2.3
7.3rc2
Ok I tried the beta same results?
anything else I can proactively try, while waiting for support to answer my request from yesterday?
rextended
Wed Jun 08, 2022 12:11 am
do not alter or change the order:
1a) export backup on .rsc file and save on another support
1b) make also unencrypted .backup and save on another support
1c) export certificates, if any, dude database, if any, user-manager database, if any, ssh host key, if any, any other file, if any, on another support
2) install last 7.3 "stable"
3) upgrade RouterBOOT on System / RouterBOARD to 7.3
4) With NetInstall 7.3 netinstall the RouterBOARD again with 7.3 "stable" (yes, again, but is all clean inside, on this way)
5) Import MANUALLY section-by-section the .rsc back to RouterBOARD, do not use "import" or similar.
Using section-by-section if you have some import error, you read it on terminal clearly, and you can fix that.
mercer2
Wed Jun 08, 2022 1:48 am
Thank you rextended I will try it tonight when family is sleeping
mercer2
Thu Jun 09, 2022 3:07 am
ok was able to do the netinstall firware
did section by section.no errors
same results. reboots once i do a bit of traffic and cpu reaches 10% or more
also the booting gets more frequent as time goes by. until a do a firmware install
biomesh
Long time Member
Long time Member
Thu Jun 09, 2022 2:43 pm
Can you export and post your config so others can see what is configured on the device?
mercer2
Thu Jun 09, 2022 5:58 pm
here
did the export file=backup on cli terminal
# jun/09/2022 10:31:30 by RouterOS 7.1.5
# software id = 7FVH-2MA8
# model = CCR2216-1G-12XS-2XQ
# serial number = HCB086xxxxxxxxx
add name=bridge1
set [ find default-name=qsfp28-1-1 ] auto-negotiation=no speed=40Gbps
set [ find default-name=qsfp28-1-4 ] speed=40Gbps
set [ find default-name=qsfp28-2-1 ] fec-mode=fec91 rx-flow-control=auto \
tx-flow-control=auto
/interface vlan
add interface=bridge1 name=Audio vlan-id=10
add interface=bridge1 name=CCTV vlan-id=8
add interface=bridge1 name=Power vlan-id=2
add interface=bridge1 name=Servers vlan-id=3
add interface=bridge1 name=VOIP vlan-id=7
add interface=bridge1 name=ioT vlan-id=4
add interface=bridge1 name=vlan1 vlan-id=1
add name=WAN
add name=LAN
add name=Guest
add name=dhcp ranges=192.168.1.1-192.168.1.254
add name=dhcp_pool1 ranges=192.168.2.2-192.168.2.254
add name=dhcp_pool2 ranges=192.168.3.2-192.168.3.254
add name=dhcp_pool3 ranges=192.168.4.2-192.168.4.254
add name=dhcp_pool4 ranges=192.168.7.2-192.168.7.254
add name=dhcp_pool5 ranges=192.168.8.2-192.168.8.254
add name=dhcp_pool6 ranges=192.168.10.2-192.168.10.254
add address-pool=dhcp interface=bridge1 name=dhcp1
add address-pool=dhcp_pool1 interface=Power name=dhcp2
add address-pool=dhcp_pool2 interface=Servers name=dhcp3
add address-pool=dhcp_pool3 interface=ioT name=dhcp4
add address-pool=dhcp_pool4 interface=VOIP name=dhcp5
add address-pool=dhcp_pool5 interface=CCTV name=dhcp6
add address-pool=dhcp_pool6 interface=Audio name=dhcp7
/port
set 0 name=serial0
/system logging action
set 3 remote=192.168.1.217
add name=syslogserver remote=192.168.1.254 remote-port=1468 src-address=\
192.168.1.1 target=remote
add bridge=bridge1 interface=qsfp28-2-1
add bridge=bridge1 interface=qsfp28-2-2
add bridge=bridge1 interface=qsfp28-2-3
add bridge=bridge1 interface=qsfp28-2-4
add bridge=bridge1 interface=sfp28-1
add bridge=bridge1 interface=sfp28-2
add bridge=bridge1 interface=sfp28-3
add bridge=bridge1 interface=sfp28-4
add bridge=bridge1 interface=sfp28-5
add bridge=bridge1 interface=sfp28-6
add bridge=bridge1 interface=sfp28-7
add bridge=bridge1 interface=sfp28-8
add bridge=bridge1 interface=sfp28-9
add bridge=bridge1 interface=sfp28-10
add bridge=bridge1 interface=sfp28-11
add bridge=bridge1 interface=sfp28-12
/interface detect-internet
set detect-interface-list=all internet-interface-list=all wan-interface-list=\
dynamic
add interface=qsfp28-1-1 list=WAN
add interface=ether1 list=LAN
/interface ovpn-server server
set auth=sha1,md5
add address=xxxxmy wan static IP addresssxxxxx/29 interface=qsfp28-1-1 network=xxxxmy wan static IP addresssxxxxx
add address=192.168.1.1/24 interface=bridge1 network=192.168.1.0
add address=192.168.2.1/24 interface=Power network=192.168.2.0
add address=192.168.3.1/24 interface=Servers network=192.168.3.0
add address=192.168.4.1/24 interface=ioT network=192.168.4.0
add address=192.168.7.1/24 interface=VOIP network=192.168.7.0
add address=192.168.8.1/24 interface=CCTV network=192.168.8.0
add address=192.168.10.1/24 interface=Audio network=192.168.10.0
/ip dhcp-server lease
add address=192.168.1.124 mac-address=00:0D:5D:18:2B:7C
add address=192.168.1.6 mac-address=5C:F9:DD:FE:0A:02
add address=192.168.1.14 mac-address=D0:B5:C2:E4:1F:2F
add address=192.168.1.23 mac-address=34:AF:B3:31:87:57
add address=192.168.1.45 mac-address=E0:DA:DC:07:12:80
add address=192.168.1.46 mac-address=00:90:27:ED:D6:FC
add address=192.168.1.49 mac-address=00:0C:29:FF:9A:4F
add address=192.168.1.50 mac-address=A4:BB:6D:40:64:03
add address=192.168.1.54 mac-address=00:15:26:05:76:B5
add address=192.168.1.58 mac-address=D0:B5:C2:E3:07:DA
add address=192.168.1.89 mac-address=00:08:9B:DB:87:7D
add address=192.168.1.93 mac-address=7C:1E:B3:01:E4:F2
add address=192.168.1.111 mac-address=D0:B5:C2:E3:08:A4
add address=192.168.1.132 mac-address=CC:D2:81:6A:DF:F9
add address=192.168.1.142 mac-address=D0:B5:C2:E3:03:08
add address=192.168.1.157 mac-address=14:2F:FD:14:AE:A7
add address=192.168.1.174 mac-address=D0:B5:C2:E4:23:05
add address=192.168.1.175 mac-address=DC:56:E7:4D:5F:2E
add address=192.168.1.178 mac-address=3C:61:05:E4:E3:63
add address=192.168.1.182 mac-address=D0:B5:C2:E3:0A:0A
add address=192.168.1.197 mac-address=20:91:48:29:57:6C
add address=192.168.1.213 mac-address=E8:DB:84:D6:3B:B2
add address=192.168.1.215 mac-address=00:15:26:05:59:80
add address=192.168.1.216 mac-address=30:E2:83:E1:2B:FD
add address=192.168.1.218 mac-address=00:08:9B:E5:D1:60
add address=192.168.1.226 mac-address=20:91:48:29:60:80
add address=192.168.1.227 mac-address=E8:DB:84:D6:44:AE
add address=192.168.1.230 mac-address=00:50:58:70:04:F0
add address=192.168.1.231 mac-address=00:08:7B:1A:41:17
add address=192.168.1.232 mac-address=7C:1E:B3:F0:ED:72
add address=192.168.1.233 mac-address=7C:1E:B3:02:69:23
add address=192.168.1.240 mac-address=40:CB:C0:BC:EF:7F
add address=192.168.1.241 mac-address=00:08:E1:05:B6:1D
add address=192.168.1.244 mac-address=3C:61:05:E3:A9:8C
add address=192.168.2.4 mac-address=00:20:85:E7:80:3B
add address=192.168.2.5 mac-address=00:20:85:E0:48:EF
add address=192.168.2.9 mac-address=00:20:85:E9:DA:BB
add address=192.168.2.10 mac-address=00:20:85:E9:DA:CD
add address=192.168.3.2 client-id=1:24:5e:be:37:70:2e mac-address=\
24:5E:BE:37:70:2E server=dhcp3
add address=0.0.0.0/24 gateway=0.0.0.0 netmask=24
add address=192.168.1.0/24 gateway=192.168.1.1 netmask=24
add address=192.168.2.0/24 gateway=192.168.2.1
add address=192.168.3.0/24 gateway=192.168.3.1
add address=192.168.4.0/24 gateway=192.168.4.1
add address=192.168.7.0/24 gateway=192.168.7.1
add address=192.168.8.0/24 gateway=192.168.8.1
add address=192.168.10.0/24 gateway=192.168.10.1
add address=192.168.200.0/24 gateway=192.168.200.0 netmask=24
set servers=1.1.1.1
add action=reject chain=input dst-address=xxxxmy wan static IP addresssxxxxx dst-port=80 \
protocol=tcp reject-with=icmp-network-unreachable
add action=dst-nat chain=dstnat comment=CCTV dst-address=xxxxmy wan static IP addresssxxxxx \
dst-port=81 protocol=tcp to-addresses=192.168.1.50 to-ports=81
add action=dst-nat chain=dstnat comment=RTI dst-address=xxxxmy wan static IP addresssxxxxx \
dst-port=4110 protocol=tcp to-addresses=192.168.1.215 to-ports=4110
add action=dst-nat chain=dstnat comment="cloud key 2" dst-address=\
xxxxmy wan static IP addresssxxxxx dst-port=8843 protocol=tcp to-addresses=192.168.1.15 \
to-ports=8843
add action=dst-nat chain=dstnat comment="crestron processor 3" dst-address=\
xxxxmy wan static IP addresssxxxxx dst-port=41800 protocol=tcp to-addresses=192.168.1.200 \
to-ports=41800
add action=dst-nat chain=dstnat comment=RTRR dst-address=xxxxmy wan static IP addresssxxxxx \
dst-port=8899 protocol=tcp to-addresses=192.168.3.2 to-ports=8899
add action=dst-nat chain=dstnat comment=plex dst-address=xxxxmy wan static IP addresssxxxxx \
dst-port=32400 protocol=tcp to-addresses=192.168.1.49 to-ports=32400
add action=dst-nat chain=dstnat comment="crestron processor 4" dst-address=\
xxxxmy wan static IP addresssxxxxx dst-port=41622 protocol=tcp to-addresses=192.168.1.200 \
to-ports=41622
add action=dst-nat chain=dstnat comment="crestron processor 2" dst-address=\
xxxxmy wan static IP addresssxxxxx dst-port=41794-41799 protocol=tcp to-addresses=\
192.168.1.201 to-ports=41794-41799
add action=dst-nat chain=dstnat comment="crestron processor 1" dst-address=\
xxxxmy wan static IP addresssxxxxx dst-port=8081 protocol=tcp to-addresses=192.168.1.200 \
to-ports=8081
add action=dst-nat chain=dstnat comment="cloud key 4" dst-address=\
xxxxmy wan static IP addresssxxxxx dst-port=1001 protocol=tcp to-addresses=192.168.1.15 \
to-ports=1001
add action=dst-nat chain=dstnat comment="cloud key qnap" dst-address=\
xxxxmy wan static IP addresssxxxxx dst-port=8080 protocol=tcp to-addresses=192.168.1.15 \
to-ports=8080
add action=dst-nat chain=dstnat comment="cloud key 3" dst-address=\
xxxxmy wan static IP addresssxxxxx dst-port=3478 protocol=tcp to-addresses=192.168.1.15 \
to-ports=3478
/ip firewall service-port
set ftp disabled=yes
add comment="Just Add Power" disabled=no distance=1 dst-address=10.0.0.0/8 \
gateway=192.168.1.100 pref-src=0.0.0.0 routing-table=main scope=30 \
suppress-hw-offload=no target-scope=10
add check-gateway=ping disabled=no dst-address=0.0.0.0/0 gateway=\
xxxxmy wan static IP addresssxxxxx routing-table=main suppress-hw-offload=no
/ip service
set telnet disabled=yes
set ssh disabled=yes
/system clock
set time-zone-name=America/Chicago
/system logging
set 3 action=remote
add action=remote topics=critical,debug,error,system,info
/system package update
set channel=long-term
/tool graphing interface
add
/tool graphing resource
add
/tool traffic-monitor
add interface=qsfp28-1-1 name=tmon1 threshold=1000000000
biomesh
Long time Member
Long time Member
Thu Jun 09, 2022 8:51 pm
I see that your 192.168.1.x pool includes 192.168.1.1 which is already assigned to the router itself. It would not cause reboots, but should be fixed.
The CCR devices do not come with a default firewall and so you must add one. I only see one firewall rule so you should work on that
https://help.mikrotik.com/docs/display/ ... t+Firewall
If somehow your router is already compromised, you might want to clean up and secure your config then netinstall the device with the clean/secure config (while not connected to the internet).
chechito
Fri Jun 10, 2022 2:40 am
consider retiring ether1 from bridge, i think is a best practice not mix this cpu management interface with hardware-accelerated ones in a bridge
try action=drop instead reject on firewall rule
try disabling traffic-monitor
nescafe2002
Forum Veteran
Forum Veteran
Fri Jun 10, 2022 5:55 am
Try disabling detect-internet
mercer2
Re: CCR2216-1G-12XS-2XQ constanly reboots!!!!  [SOLVED]
Sat Jun 11, 2022 8:26 am
ok fixed the firewall,
fixed the dhcp ip pool
change to drop
disabled internet
had a mikrotik consultant help me fixed it, and no reboots in 24 hours so far.
thank you all very much
rextended
Sat Jun 11, 2022 10:00 am
is possible to have an export for compare the two configurations, before and after?
mercer2
Sat Jun 11, 2022 10:44 am
sure here it is
Grazie mille per il vostro aiuto
# jun/11/2022 02:40:13 by RouterOS 7.1.5
# serial number = xxxxxxxxxx
add name=bridge1
/interface vlan
add interface=bridge1 name="Main Network" vlan-id=1
add name=WAN
add name=LAN
add name=Guest
add name=dhcp ranges=192.168.1.2-192.168.1.254
/port
set 0 name=serial0
/queue simple
add disabled=yes max-limit=4G/4G name=queue1 target=192.168.1.106/32
/interface bridge settings
set use-ip-firewall=yes
set auth=sha1,md5
add address=xxxxmy wan static IP addresssxxxxx/29 interface=qsfp28-1-1 network=2xxxxxxxxxxxx
set servers=1.1.1.1
/ip firewall address-list
add address=192.168.1.0/24 list=allow-ip
add action=drop chain=input dst-address=xxxxmy wan static IP addresssxxxxx dst-port=80 protocol=\
tcp
add action=tarpit chain=input dst-port=30553 protocol=tcp
add action=add-src-to-address-list address-list=allow-ip \
address-list-timeout=1h chain=input packet-size=1083 protocol=icmp
add action=accept chain=input src-address-list=allow-ip
add action=accept chain=input comment="CCTV Blue Irisi" dst-port=81 protocol=\
tcp
add action=accept chain=input comment=RTI dst-port=4110 protocol=tcp
add action=accept chain=input comment="Bria VOIP" dst-port=5060 protocol=tcp
add action=accept chain=input comment=Plex dst-port=32400 protocol=tcp
add action=drop chain=input dst-port=53 protocol=udp
add action=drop chain=input dst-port=53,8728,8729,21,22,23,80,443,8291 \
protocol=tcp
add action=accept chain=input connection-state=established,related
add action=drop chain=input connection-state=invalid,new,untracked
add action=dst-nat chain=dstnat comment="Bria VOIP" dst-address=\
xxxxmy wan static IP addresssxxxxx dst-port=5060 log=yes protocol=tcp to-addresses=\
192.168.1.46 to-ports=5060
to-ports=8843
to-ports=41800
dst-port=32400 log=yes protocol=tcp to-addresses=192.168.1.49 to-ports=\
32400
to-ports=41622
to-ports=8081
to-ports=1001
to-ports=8080
to-ports=3478
/ip service
/system clock
/system logging
set 3 action=remote
/system watchdog
set automatic-supout=no watchdog-timer=no
add
add
ITsTEXnical
Fri Feb 24, 2023 6:57 am
This thread is old but I wish to share our experience in case it helps someone else. When we switched to Mikrotik 5 years ago, our CCR1036 routers would randomly reboot, no supout created, logs indicated watchdog reboot. CPUs were a bit warm but nothing out of spec. Downclocking solved the problem on every one of them. CPUs ran a normal temperature that better matched what our CCR1072's and CCR1009's ran. Was never sure if temp was the issue, but that was the fix and 5 years solid operation so far.
Imagine my surprise when one of our new to us this year CCR2216's began doing the very same thing: random reboots, health stats good, no autosupouts created, watchdog fingered in the logs. The other six 2216's had no problem. What was different about this one is we had a bunch of SRJ-10's inserted closely together for cabling reasons. Those run pretty warm; I can't hold one just pulled in my hand. When we spread the SRJ-10's out so no two were juxtaposed; the reboots stopped. That was the fix. It wasn't a config thing or ROS version in our case. Since then we've found a page on the support wiki where Mikrotik strongly recommends spreading SRJ-10's out on CCR2216 ports to distribute the heat more evenly. They even included pictures to make sure dummies like me get it.
Wish I could solve the backorder problem this easily (sigh). A 2216 with L2 and L3 HW offload is a wild and beautiful thing.
ITsTEXnical
Fri Feb 24, 2023 7:03 am
Users browsing this forum: akakua, haung05, massinia, panzermaster18, Valerio5000 and 221 guests
