I do not think this has been 100% fixed, I still have VLAN tagging issues and wireless clients get no IP connectionRouterOS version 7.3 has been released in the "v7 stable" channel!
*) wifiwave2 - fixed VLAN tag handling;
> /system/routerboard/print
routerboard: yes
model: CRS328-24P-4S+
revision: r2
firmware-type: dx3230L
factory-firmware: 6.47.9
current-firmware: 7.3
upgrade-firmware: 7.3
Huh... It's sortable for me in 7.2.3... What exactly was changed?*) winbox - made "Interface Templates" table sortable under "Routing/OSPF" menu;
I did have VLAN tagging issues when running wifiwave2 on audience in version 7.2.1 and earlier (the config had to be inverse of how it works usually). It was fixed (for my use case at least) in 7.2.3. So I wonder if this indicates yet another fix (versus 7.2.3) or only fix versus 7.2.1 ... mind that 7.2.3 was released after 7.3beta started to roll out so the list of changes may actually show differences from early 7.2 version (when code base forked).I do not think this has been 100% fixed, I still have VLAN tagging issues and wireless clients get no IP connection
on a setup that works on 7.2!
[me@AC3] > log/print
14:11:08 system,info router rebooted
14:11:08 interface,info Home_vlan link up
14:11:14 bridge,info "bridge" mac address changed to XX:XX:XX:XX:XX:XX
14:11:14 system,error,critical error while running customized default configuration script: no such item
the same situationah my routing problem is come back, in ROS 7.2.1 i have mangle rule for routing all ip address outside nice address to wireguard, and some ip on routing rules, for conflicting routing bypass using routing rule solve my problem, and in ROS 7.3 it seem routing ignoring the routing rules ip, it routing mangle route first rather than routing rule ip, i am scratch my head now, is there anyone have tips for this kind problem
Have you tried to upgrade firmware?I've updated both my RB4011 and hap ac3(ww2). all seems fine except the hAPac3 is showing some strange lines each time that it boots:This did not happen on 7.2.3Code: Select all[me@AC3] > log/print 14:11:08 system,info router rebooted 14:11:08 interface,info Home_vlan link up 14:11:14 bridge,info "bridge" mac address changed to XX:XX:XX:XX:XX:XX 14:11:14 system,error,critical error while running customized default configuration script: no such item 14:11:14 system,error,critical ...
Could you share configuration (support/export etc.) with MikroTik support (support@mikrotik.com)?Hello,
After the update of multiple RB3011UiAS-RM devices from v7.2.3 (with Routerboard firmware as well on v7.2.3) to v7.3, the devices went into boot loop and we are unable to get them into Etherboot or Bootloader mode either. My colleague is taking them to Mikrotik office as of this moment (in Riga) for a potential solution. Otherwise we will get 2 new routers and will configure them with configuration backups since the locations need to have access.
On the other side, multiple RB3011UiAS-RM devices have been upgraded from 7.2.3 to 7.3 successfully as well. We suspect that the devices that went into boot loop had some kind of configuration detail that might not be fully compatible with v7.3. Unfortunately not able to diagnose what detail that could be.
For your information.
Andaç
...but had been there in 7.2.1I've updated both my RB4011 and hap ac3(ww2). all seems fine except the hAPac3 is showing some strange lines each time that it boots:This did not happen on 7.2.3Code: Select all[me@AC3] > log/print 14:11:08 system,info router rebooted 14:11:08 interface,info Home_vlan link up 14:11:14 bridge,info "bridge" mac address changed to XX:XX:XX:XX:XX:XX 14:11:14 system,error,critical error while running customized default configuration script: no such item 14:11:14 system,error,critical ...
The same here, have to stay on 7.2.1 (7.2.3 or 7.3 - the same issue). Not only this, currently when upgraded from 7.2.1 to 7.3 I lost again some parts of configuration (at least all simple queues now), but even though I fix that by restoring saved configuration from 7.2.1, the routing issue still persist. Downgrade to 7.2.1 solve everything again. I have a support ticket SUP-81294 on this since 4.5.2022 but still no relevant solution/help from Mikrotik support :-(ah my routing problem is come back, in ROS 7.2.1 i have mangle rule for routing all ip address outside nice address to wireguard, and some ip on routing rules, for conflicting routing bypass using routing rule solve my problem, and in ROS 7.3 it seem routing ignoring the routing rules ip, it routing mangle route first rather than routing rule ip, i am scratch my head now, is there anyone have tips for this kind problem
What is the config of your router?Upgraded RB3011 with 7.2.3 to 7.3
reboot loop
it was 7.2.3 , now 7.3What is the config of your router?Upgraded RB3011 with 7.2.3 to 7.3
reboot loop
What version was installed prior upgrade?
So it will until you change it to "auto".RB5009UG is still reporting the error "cpu not running at default frequency" after upgrading to v7.3.
Yes, I always do after the updateHave you tried to upgrade firmware?I've updated both my RB4011 and hap ac3(ww2). all seems fine except the hAPac3 is showing some strange lines each time that it
Anyone with this issue?
On such a device (with enough flash), always partition the router with 2 partitions and copy the active to inactive partition before upgrading.it was 7.2.3 , now 7.3
I managed to downgrade, and everything works
Can you give more information how VLAN tagging works on 7.3 (versus 7.2/7.1/7.0)? I migrated from ROS6 to 7.0 and since ever all my VLAN worked...I did have VLAN tagging issues when running wifiwave2 on audience in version 7.2.1 and earlier (the config had to be inverse of how it works usually). It was fixed (for my use case at least) in 7.2.3. So I wonder if this indicates yet another fix (versus 7.2.3) or only fix versus 7.2.1 ... mind that 7.2.3 was released after 7.3beta started to roll out so the list of changes may actually show differences from early 7.2 version (when code base forked).I do not think this has been 100% fixed, I still have VLAN tagging issues and wireless clients get no IP connection
What are conditions to use this feature? I have AES passed to CHR and no HW flag in OVPN server clients. Is there any documentation to this?*) ovpn - fixed hardware offloading support on CHR;
Set your chr vm cpu setting to hostWhat are conditions to use this feature? I have AES passed to CHR and no HW flag in OVPN server clients. Is there any documentation to this?*) ovpn - fixed hardware offloading support on CHR;
Thank you
I have set it, as I write. CHR sees Intel CPU (same as host).Set your chr vm cpu setting to host
Thank you
Same here with RB3011 after upgrade to v7.3. I noticed if I disable PPPoE client (to connect to Internet) the router stops rebooting.Hello,
Andaç
jun/07/2022 15:29:54 system,error,critical kernel failure in previous boot
I also had this problem, and it only happens if you have any module on the SFP port, that is, after updating to version 7.3, every time you put an SFP module, the Routerboard goes into looping, test and remove the modules SFP, here I was forced to downgrade.Hello,
Andaç
We had the same problem. Seems to have something to do with installed SFP or not. When we removed the installed SFP-Module the router bootet fine. As soon as we insterted the module again router made a clicking noise and rebooted. Did a downgrade to 7.2.3 with removed SFP. Inserted the SFP again an everything is fine again. Will stay an 7.2.3 on RB3011UiAS-RM so far.Hello,
Andaç
/system routerboard settings set auto-upgrade=yes
And what about mentioned routing issue SUP-81294 (three people mentioned above)?Everyone...
As also mentioned in previous release topics the error about default configuration when the ww2 package is used is a known issue and will be resolved in the upcoming releases.
ARP ping issue will be fixed in the upcoming releases, however, at the moment there is no ETA for the fix.
Everyone with the RB3011 issues - please, if possible, provide to use supout file from your router if you manage to boot it up and/or serial console output of booting/rebooting process. Our RB3011 devices are running just fine. It must be something specific that triggers this issue and we would like to figure that out as soon as possible.
Everyone who is experiencing problems with ARM devices and wrong default frequency warning. A few versions ago for several ARM devices default value was changed to auto, but we did not touch your configuration. So if the frequency was static in the past and you have not set it to auto or reset configuration since then you will see this warning. Set value to auto, if you really have a problem with this warning.
The issue with Detect Intenet is reported and we will try to fix it as soon as possible.
About bootloader auto-upgrade. It very very rarely contains fixes for already released products and that is why we do not believe that it is worth forcing this upgrade and making a ROS upgrade much, much slower (if the bootloader would be upgraded at the same time).
agilee, codework, russelld - Does not seem to e a version-related issue, however, still please send supout file from this router to support@mikrotik.com.
templeos - Known issue, will be resolved as soon as possible.
Nothings should have changed, however in versions since 7.1beta to 7.2.1 (those I checked) worked incorrectly. Setup: audience running wifiwave2 drivers, configured something like this:Can you give more information how VLAN tagging works on 7.3 (versus 7.2/7.1/7.0)?
add name=bridge frame-types=admit-only-vlan-tagged vlan-filtering=yes
add bridge=bridge frame-types=admit-only-vlan-tagged interface=ether1
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged interface=wifi1 pvid=42 # the 2GHz radio
/interface bridge vlan
add bridge=bridge tagged=ether1 untagged=wifi1 vlan-ids=42
"Age" shows me (in a quick test lab) the time how long the lease is active. I assume this will simply count up.Two questions,
*) dhcpv4-server - added "age" parameter for dynamic leases; What will I be able to do now that I was not able to before??
*) profile - added "wireguard" process classificator; Same what does this provide?
Upgraded multiple devices inc CCR1009 / CRS317 / RB4011 / RB3011 / wAP AC all OK.
However, I encountered an issue when upgrading my RB5009 from 7.2.3 to 7.3: it has a bonded WAN interface (Ether 2 and 3) connected to a Virgin Media HUB 4 (in modem mode). The bonded WAN interface is configured as a DHCP client and normally gets a 192.168.100.x IP address from the hub with a number of short DHCP lease times, which eventually gets replaced with the public IPv4 address once the cable modem is fully initialised.
However, after upgrading to ROS 7.3 (& firmware 7.3), it gets the initial 192.168.100.x IP addresses via short DHCP leases from the HUB4, but never obtains the final public IPv4 address, even when clicking on the RENEW button in the DHCP client config window.
Support ticket has been raised with Mikrotik.
Can confirm that, both 7.3 and 7.4betaI've updated both my RB4011 and hap ac3(ww2). all seems fine except the hAPac3 is showing some strange lines each time that it boots:This did not happen on 7.2.3Code: Select all[me@AC3] > log/print 14:11:14 system,error,critical error while running customized default configuration script: no such item 14:11:14 system,error,critical
Are you upgrading from 6.x version? did you configure the RIP instance?Upgraded multiple devices inc CCR1009 / CRS317 / RB4011 / RB3011 / wAP AC all OK.
Same here with Movistar Spain and VLAN 3 for getting VoIP service. DHCP client is not even able to get an IP from that VLAN configured in Ether1 (which already have another VLAN configured for internet, delivered vía VLAN6 and PPPoE service). Something weird happening with DHCP Client in that version. I suggest to investigate.
I have also forwarded this vía ticket to Mikrotik support.
I can confirm that in our case the devices that went to boot loop had XSFP-1.25G-SX (850nm) type of SFP module attached to them and as soon as the module was removed, the router could boot normal. FYI.We have managed to reproduce the problem with RB3011 rebooting with this particular version and are working on a fix for it. The issue is somehow related to the particular SFP module presence. If you do not use SFP, then you should be safe.
Hi,in ROS 7.3 it seem routing ignoring the routing rules ip, it routing mangle route first rather than routing rule ip, i am scratch my head now, is there anyone have tips for this kind problem
/routing/rip/instance add afi=ipv4 disabled=no name=rip
/routing rip interface-template add instance=rip interfaces=vlan3-phone,vlan2-iptv mode=passive
Thanks for the clue, i try but still some ip not working, i decided too add ip address in firewall address, this work for some other is not, my goal is like this my ISP have a few CDN like netflix,GGC,facebook,akamai for this CDN i need to route to my ISP other than that routing go too wireguard warp Cloudflare VPN, that why i add mangle in ip firewall address list nice addres, mangle rule is like thisHi,in ROS 7.3 it seem routing ignoring the routing rules ip, it routing mangle route first rather than routing rule ip, i am scratch my head now, is there anyone have tips for this kind problem
Routing marks now have higher priority.
One way to make rules work.
Separate the route tables (routing marks) the rules check vs the route tables the rules specify as a lookup.
eg. route mark packets with via-alt table
/routing table
add disabled=no fib name=Rvia-alt
add disabled=no fib name=via-alt
/ip firewall mangle
add action=mark-routing chain=prerouting comment=via-alt new-routing-mark=via-alt passthrough=yes
Rule to select Routing Table (Note lookup table != routing mark)
add action=lookup disabled=no dst-address=0.0.0.0/0 routing-mark=via-alt table=Rvia-alt
In ip route table only have Routing table entries with Rvia-alt (I put in R to indicate goes in routing table)
Do not have entries with via-alt in ip Route Table.
Hopefully that works ok for you.
add action=mark-routing chain=prerouting comment=International \
dst-address-list=!nice new-routing-mark=Cloudflare passthrough=yes \
src-address-list=private-lokal
Presumingly these /32 routes are part of a subnet that is accepted in the input.accept-nlri address list? You can only filter addresses outside that address list, not smaller (e.g. single) addresses inside the listed networks.I using input.accept-* filter. exactly input.accept.NLRI where i have some prefixes in address list. Prefiltering works good but .. in routing table i have still /32 ipv4 routes as FILTERED and can not deny storing it in memory. Is there trick how to prefilter ipv4 /32 routes? Other higher prefixes is prefiltered perfectly.
Unfortunately I tried the upgrade before the warning was released. Had to reset, downgrade then I restored from the backup I made before the upgrade.As a RB3011 user with an SFP for uplink to my RB260GSP I am glad I held off installing yet another 'STABLE' release :(
No, These /32 routes is not parts of accepted nlri addressesPresumingly these /32 routes are part of a subnet that is accepted in the input.accept-nlri address list? You can only filter addresses outside that address list, not smaller (e.g. single) addresses inside the listed networks.I using input.accept-* filter. exactly input.accept.NLRI where i have some prefixes in address list. Prefiltering works good but .. in routing table i have still /32 ipv4 routes as FILTERED and can not deny storing it in memory. Is there trick how to prefilter ipv4 /32 routes? Other higher prefixes is prefiltered perfectly.
/ipv6 address print
Flags: D - DYNAMIC; G, L - LINK-LOCAL
Columns: ADDRESS, INTERFACE, ADVERTISE
# ADDRESS INTERFACE ADVERTISE
0 DL fe80::20c:29ff:fe8b:2fc2/64 ether1 no
1 DL fe80::20c:29ff:fe8b:2fcc/64 vlan20 no
2 DL fe80::20c:29ff:fe8b:2fcc/64 vlan10 no
3 DL fe80::20c:29ff:fe8b:2fcc/64 ether2 no
4 DG xxxx:10d:c089:e002:20c:29ff:fe8b:2fc2/64 ether1 no
[admin@l4stik] > /ipv6/route/print
Flags: D - DYNAMIC; A - ACTIVE; c, s, y - COPY
Columns: DST-ADDRESS, GATEWAY, DISTANCE
# DST-ADDRESS GATEWAY DISTANCE
DAc xxxx:10d:c089:e002::/64 ether1 0
DAc fe80::%ether1/64 ether1 0
DAc fe80::%ether2/64 ether2 0
DAc fe80::%vlan10/64 vlan10 0
DAc fe80::%vlan20/64 vlan20 0
I probably know what it is, and it's not you, it's RouterOS. I now tested it and it happened between 7.2.1 and 7.2.2. Previously if there were multiple routing tables, local destinations (addresses assigned to router) always had priority and used main routing table, but it doesn't happen anymore. Simplified (incomplete, but shows relevant parts) example:Still the same Problems with DualWan Config, on 7.2.1 the Config is running smoothly, upgrade to 7.2.3,
Router not accessible through IP only MAC, upgrade to 7.3 is the same behaviour.
If i contact Support, they recommend to call a Consultant.
add interface=LAN address=192.168.88.1/24
add dst-address=0.0.0.0/0 gateway=x.x.x.x routing-table=WAN2
/ip firewall mangle
add chain=prerouting src-address=192.168.88.20 action=mark-routing new-routing-mark=WAN2
add chain=forward src-address=192.168.88.20 action=log
add chain=input src-address=192.168.88.20 action=log
Strange Works fine on my hex S.hEX S upgraded from 7.2.1 to 7.3 and now /ip/ssh> print throwing out: error - contact MikroTik support and send a supout file (2)
Same when exporting config: #error exporting /ip/ssh
Initially set:
strong-crypto: yes
host-key-size: 4096
Even when reverting to strong-cryto: no and host-key-size: 2048 (default values) - same thing.
On 7.2.1 all smooth.
Have another RB4011 running on 7.3 without any issues and all fine with /ip/ssh settings - so it seems to be a phenomenon on hEX S only.
Hi,"Routing marks now have higher priority", this is my config i hope you can give me some advice
/ip firewall mangle
/routing rule
add action=lookup disabled=no dst-address=0.0.0.0/0 routing-mark=Cloudflare \
table=Balifiber
add disabled=no distance=2 dst-address=0.0.0.0/0 gateway=wireguard1 pref-src=\
0.0.0.0 routing-table=Cloudflare scope=30 suppress-hw-offload=no \
target-scope=10
add check-gateway=ping comment=Balifiber disabled=no distance=1 dst-address=\
0.0.0.0/0 gateway=192.168.254.254 pref-src=0.0.0.0 routing-table=\
Balifiber scope=30 suppress-hw-offload=no target-scope=10
just finished an automated testing on this very topic, and the results look pretty disappointing.SLAAC configuration in CHR works case by case
root@l4s:~# grep -c v6 log.mtikslaactest.10s
500
root@l4s:~# grep v6 log.mtikslaactest.10s | grep -c 'v6 is OK'
132
root@l4s:~# grep v6 log.mtikslaactest.10s | grep -c 'slaac failed'
368
Hi @mrzYes that is exactly how it should work, mangle has the highest priority
* you are marking traffic with "cloudflare"
* and there is a route in the "cloudflare" table
* routing decision picks the forwarding path from the cloudflare table
If you remove the default route from "cloaudflare" table so that nexthop cannot be resolved in that table, then routing decision will move to the next adjustments: route rules.
Another Chateau 5G owner here, I'm not seeing the issues you mention, I'm connecting to 3 UK, bands n78, b28, b3, b1, b20 + b32.Since 7.2.2 my Chateau 5G was losing LTE connection few hours after reboot. Same problem with 7.2.3.
Locking cells, selecting bands or network didn't change the outcome.
With 7.3 the issue is getting worse: without cell lock I noticed a frantic LTE cells switch during operation and again the frequent complete loss of LTE connection.
I tried also a clean installation of RouterOS with netinstall but no way.
Downgrading RouterOS to 7.2.1 restores the situation back to normal
I opened a ticket with support, enabled LTE logging and sent support file.
The support answer is worst than useless, they wrote to check APN and if my data plan is valid....
Anyone with same nightmare?
At least on the CRS328, there's a bug in the software leading to this. 7.4beta2 has the "fix" (disabling a core) and I've been running it for 3 days with no port flaps on SFP+ links. I was having flaps every few minutes ever since 7.x with these devices, which I was able to make better by disabling all disk-activity possible (no more graphing/lease storage/etc) to hourly or so. 7.4beta2 and I've had no flaps since installation. I'm letting it run until next week and if there's still no flaps, then it's "fixed", even if it means a core is disabled. It's absolutely wild it took over 6 months to fix something causing port flaps on many CRS328s (confirmed by many forum members) when it's such an important function of a switch (link stability) but hey, at least it seems better with the beta.i also have RB4011iGS+, CRS328-24P-4S+Cloud Router Switch, CRS112-8P-4S-IN Cloud Router Switch, hEXs RB760iGS, hEX PoE RB960PGS from 7.2.3 to 7.3 is still reporting ports flaps and all of these are work as bridge only but also RB5009UG reporting ports flaps and it's connected with ISP and all other MT device that I mention connected to RB5009UG so I decided to downgrade to 7.2.3
Hi,I probably know what it is, and it's not you, it's RouterOS. I now tested it and it happened between 7.2.1 and 7.2.2. Previously if there were multiple routing tables, local destinations (addresses assigned to router) always had priority and used main routing table, but it doesn't happen anymore. Simplified (incomplete, but shows relevant parts) example:
As said in my posts I also have incompatibility between ww2 on 7.2 and 7.3. As I only have one audience and use it as mainOkay does anyone else have the following issue?
When I add Aud2:WIFi3(backhaul) to the bridge on Aud2, no traffic traverses the backhaul between the two audiences. However, if I just add a DHCP client to the Aud2:WiFi3 interface, it gets a lease just fine. It seems as though Wave 2 has some problems with Bridge->Bridge connections.
Any chance to fix this viewtopic.php?p=938339#p938337 issue introduced in 7.2.2 (7.2.3)? I have open a SUP-81294 but still no relevant reply. Above post explain everything. Thanks for care about this.Version 7.3.1 with two quick fixes has been released!
What's new in 7.3.1 (2022-Jun-09 11:58):
*) rb3011 - fixed RB3011 going into a reboot loop when the SFP module is present (introduced in v7.3);
*) wifiwave2 - fixed WPA3-PSK authentication incompatibility with certain vendor and model devices;
but that is not "an issue", it is a change in functionality (albeit badly documented).Any chance to fix this viewtopic.php?p=938339#p938337 issue introduced in 7.2.2 (7.2.3)?
Thanks, I'll do it.@lucasasdelli I think that most likely is a configuration issue on your side, start a new topic with a /export of your configuration.
note that configurations using both "ip route rule" and "mangle mark route" will have to be reworked.
I think it is also related to explanation of issue here above viewtopic.php?p=938339#p938337 .RouterOS versions 7.3 and 7.3.1 are released in the "v7 stable" channel!
Hi, on an RB450G the 7.3 stops icmp management, while keeping routing ok.
After upgrade, no services (ping, winbox, snmp etc) either from outside or from the router itself towards other networks.
Routerboard is 7.3, but even with 7.2.3 was the same.
RouteroS 7.2.3 was fully ok.
Luca
If it was an intention (undocumented), why MikroTik support team does not reply to my opened support ticket with that explanation? For me it still souds like an issue and if not, they should provide a solution while i.e. their documented dualWAN solution https://help.mikrotik.com/docs/pages/vi ... d=26476608 probably does not work now.but that is not "an issue", it is a change in functionality (albeit badly documented).Any chance to fix this viewtopic.php?p=938339#p938337 issue introduced in 7.2.2 (7.2.3)?
you will need to fix that in your configuration, I think.
OK, please provide at least one related to this "change" in RouterOS?There are already other topics that explain the change and how you can alter your configuration.
@strods ... heeding your comment above is vitally important especially for those that do not understand the relationship between the given device hardware and the memory RESOURCES provided.Most of times when we receive such reports simply router/switch have a too complex configuration in order to run RouterOS, process traffic, and do everything that is configured on the device. The beauty of RouterOS is that we do not limit you with random limitations, but at the same time you have to understand that there are as many resources as there are. Please note that v7 requires more RAM than v6 so it is possible that v6 was running fine just below the edge of running out of RAM.
That is likely not realistically possible. Every config item uses memory but it is difficult to specify exactly how much, some of it may be dynamic. And each new version may change the exact numbers so it will cost (waste) a lot of man-hours to keep that table uptodate.IMO, MT needs to provide a Table that spells out the relationship between Memory Resources and functional capabilities
I have this same problem on my RB4011 upgrading from 7.2.3. I tried both 7.3 and 7.3.1 with no luck. DHCP client status on the internet-facing eth1 interface shows "searching...". My cable modem is ARRIS CM8200A.Hiya,
I upgraded both my RB4011 and my parents RB3011 last night from 7.2.3 to 7.3 and the dhcp client no longer receives and address from Virgin media.
I have eth1 as the upstream internet facing interface with dhcp client on it nothing out of the ordinary. I could see traffic on the external interface so as a stop gap I gave them both static IP's and static default routes (the last IP's they had before upgrading) and its working again.
Ideally it would be nice to have dhcp working again for the internet facing interfaces - god knows what must have changed to stop the dhcp working as I've upgraded these things for 3 + years no problems and never had to downgrade.
Cheers!
Jon.
My remote hands couldn't insert a tap
Yes, I've tried that; BUT here's the kicker it did not capture ANY incoming dhcp packets, which I found odd. I asked someone to pull out the backup hex from the closet and wire that up.My remote hands couldn't insert a tap
You don’t need one. RouterOS gives it to you out of the box.
Post a pcap file for one of these failed lease requests, and a solution should follow shortly.
it did not capture ANY incoming dhcp packets…the two switch chips don't pass the dhcp offer packet along to the cpu which is running the packet sniffer.
There is a catch - the sniffer does not show even frames that do get to the CPU if they ingress through a bridge member port which is configured for hardware accelerated bridging (hw=yes). It is not a specialty of 7.3, it has been behaving this way since a long time ago, but I hazily remember it did work as expected (frames for CPU being shown, frames for other Ethernet ports being not) for some time after 6.41 where the "new bridge setup" appeared. No idea whether it is a bug or an intention.it did not capture ANY incoming dhcp packets…the two switch chips don't pass the dhcp offer packet along to the cpu which is running the packet sniffer.
Same issue here. Nest doorbell battery is not answering to dhcp offers by mikrotik with 7.3.0/7.3.1.I get a bunch of these entries for each of the Nest Cams
dhcp,warning DeviceName offering lease 192.168.1.x for xx:xx:xx:xx:xx:x without success
Detect Internet feature is still brokenThere are no changes since rc2.
Chaosphere64 - Yes, you are correct. We have just reproduced the problem and we will try to resolve it as soon as possible.
lyubomirtraykov - Have you reported this to support@mikrotik.com? If not, then open a new ticket and provide supout file from your router.
No they have asked me to upgrade to a more powerful device. So I bought an RB5009. Also rb3011 started to perform worse than HAP AC^2 for the exact same config.RB3011 still suffers from a massive performance penalty with v7 compared to v6 (other devices are fine).
Will that ever get fixed?
This has been a bit of a long running thing, the RB3011 on paper is quite a capable unit and under 6.x it seemed that way, 7.x downloading 100mbit with 10 firewall rules pegs both cores to 60% usage, i've never seen it drop below 8% at idle.. I have an RB750gr3 on the shelf presently doing nothing but that manages workloads so much betterNo they have asked me to upgrade to a more powerful device. So I bought an RB5009. Also rb3011 started to perform worse than HAP AC^2 for the exact same config.RB3011 still suffers from a massive performance penalty with v7 compared to v6 (other devices are fine).
Strangely my RB3011's have been flawless for the past 6 or so years. Even on v7 I am able to pull a full gigabit through it with an extensive firewall ruleset.This has been a bit of a long running thing, the RB3011 on paper is quite a capable unit and under 6.x it seemed that way, 7.x downloading 100mbit with 10 firewall rules pegs both cores to 60% usage, i've never seen it drop below 8% at idle.. I have an RB750gr3 on the shelf presently doing nothing but that manages workloads so much better
I do feel that the RB3011 is the Windows ME of the Mikrotik world.. looks ok on surface, questionable performance under the hood. added to this the interface flapping issue which wasn't ever completely resolved but could be mitigated if you keep all your inter vlan traffic on the same switch.
I'll be replacing mine and putting the purchase of it down to a bad decision on my part, I am more than happy with my other Mikrotik devices, I have just never had so many issues upgrading and stability issues as I have with the RB3011, I am surprised that it is still sold.
[rchan@SS-CRT] > /ip settings/print
ip-forward: yes
send-redirects: yes
accept-source-route: no
accept-redirects: no
secure-redirects: yes
rp-filter: loose
tcp-syncookies: no
max-neighbor-entries: 8192
arp-timeout: 30s
icmp-rate-limit: 10
icmp-rate-mask: 0x1818
route-cache: yes
allow-fast-path: yes
ipv4-fast-path-active: no
ipv4-fast-path-packets: 0
ipv4-fast-path-bytes: 0
ipv4-fasttrack-active: no
ipv4-fasttrack-packets: 0
ipv4-fasttrack-bytes: 0
[rchan@SS-CRT] > /ip firewall/filter/print
Flags: X - disabled, I - invalid; D - dynamic
[rchan@SS-CRT] > /ip firewall/nat/print
[rchan@SS-CRT] > /ip firewall/raw/print
uptime: 1d15h55m27s
version: 7.3.1 (stable)
build-time: Jun/09/2022 08:58:15
factory-software: 6.44beta41
free-memory: 14.9GiB
total-memory: 15.8GiB
cpu: tilegx
cpu-count: 72
cpu-frequency: 1000MHz
cpu-load: 0%
free-hdd-space: 81.3MiB
total-hdd-space: 128.0MiB
architecture-name: tile
board-name: CCR1072-1G-8S+
platform: MikroTik
[rchan@SS-CRT] >
Paste From : https://wiki.mikrotik.com/wiki/Manual:Fast_Path (including the spelling mistakes)I notice that ipv4-fast-path is not working on v7.3 whilst the same config with v6.48.6 fast-path is working as expected, there were no firewall rules in this machine just BGP and OSPF, is this expected because route cache is no longer available it v7?
Code: Select all[rchan@SS-CRT] > /ip settings/print ip-forward: yes send-redirects: yes accept-source-route: no accept-redirects: no secure-redirects: yes rp-filter: loose tcp-syncookies: no max-neighbor-entries: 8192 arp-timeout: 30s icmp-rate-limit: 10 icmp-rate-mask: 0x1818 route-cache: yes allow-fast-path: yes ipv4-fast-path-active: no ipv4-fast-path-packets: 0 ipv4-fast-path-bytes: 0 ipv4-fasttrack-active: no ipv4-fasttrack-packets: 0 ipv4-fasttrack-bytes: 0 [rchan@SS-CRT] > /ip firewall/filter/print Flags: X - disabled, I - invalid; D - dynamic [rchan@SS-CRT] > /ip firewall/nat/print Flags: X - disabled, I - invalid; D - dynamic [rchan@SS-CRT] > /ip firewall/raw/print Flags: X - disabled, I - invalid; D - dynamic uptime: 1d15h55m27s version: 7.3.1 (stable) build-time: Jun/09/2022 08:58:15 factory-software: 6.44beta41 free-memory: 14.9GiB total-memory: 15.8GiB cpu: tilegx cpu-count: 72 cpu-frequency: 1000MHz cpu-load: 0% free-hdd-space: 81.3MiB total-hdd-space: 128.0MiB architecture-name: tile board-name: CCR1072-1G-8S+ platform: MikroTik [rchan@SS-CRT] >
I upgraded my CRS309 with 7.3 hoping, blindly, that this change here
l3hw-offload on main table only
Would fix the issue where when its enabled it breaks VRF completely. This did not fix the issue and it still remains. FYI if anyone has similar problems.
0 AsH 0.0.0.0/0 172.19.0.9 1
DAcH 172.19.0.0/24 MainGateway 0
DAcH 192.168.15.0/24 Management 0
DAcH 192.168.50.0/24 HomeWired 0
DAcH 192.168.51.0/24 HomeWiFi 0
DAcH 192.168.52.0/24 Server 0
DAcH 192.168.53.0/24 Storage 0
1 AsH 0.0.0.0/0 172.19.80.9@iotnet 1
DAcH 172.19.80.0/24 IoTGateway@iotnet 0
DAcH 192.168.80.0/24 IoTDevices@iotnet 0
2 AsH 0.0.0.0/0 172.19.81.9@guestnet 1
DAcH 172.19.81.0/24 GuestGateway@guestnet 0
DAcH 192.168.81.0/24 GuestWiFi@guestnet 0
3 AsH 0.0.0.0/0 172.19.82.9@securenet 1
DAcH 172.19.82.0/24 SecureGateway@securenet 0
DAcH 192.168.82.0/24 Security@securenet 0
Having ssh problem on RB5009 and 7.3.1.
Brand new RB5009, came with 7.1.x, upgraded to 7.3.1, did most of the configuration in Wnbox and Wnbox Terminal. Only encountered this error when configuring /ip/ssh.
/ip/ssh print results in "error - contact MikroTik support and send a supout file (2)"
MMM MMM KKK TTTTTTTTTTT KKK
MMMM MMMM KKK TTTTTTTTTTT KKK
MMM MMMM MMM III KKK KKK RRRRRR OOOOOO TTT III KKK KKK
MMM MM MMM III KKKKK RRR RRR OOO OOO TTT III KKKKK
MMM MMM III KKK KKK RRRRRR OOO OOO TTT III KKK KKK
MMM MMM III KKK KKK RRR RRR OOOOOO TTT III KKK KKK
MikroTik RouterOS 7.3.1 (c) 1999-2022 https://www.mikrotik.com/
Press F1 for help
Change your password
new password> ********
repeat new password> ********
Password changed
[admin@MikroTik] > /ip/ssh/print
forwarding-enabled: no
always-allow-password-login: no
strong-crypto: no
allow-none-crypto: no
host-key-size: 2048
[admin@MikroTik] > /ip/ssh/set strong-crypto=yes
[admin@MikroTik] > /ip/ssh/regenerate-host-key
This will regenerate current SSH host keys, yes? [y/N]:
N
action cancelled
[admin@MikroTik] >
[rchan@SS-CRT] > /routing/stats/memory/print
error - contact MikroTik support and send a supout file (3)
[rchan@SS-CRT] >
IPv4 fast path is automatically used if following conditions are met:
firewal rules are not configured;
firewall address lists are not configured;
Traffic flow is disabled /ip traffic-flow enabled=no restriction removed in 6.33;
Simple and queue trees with parent=global are not configured;
no mesh, metarouter interface configuration;
sniffer, torch and traffic generator is not running;
connection tracking is not active;
ip accounting is disabled (/ip accounting enabled=no);
VRFs are not set (/ip route vrf is empty);
Hotspot is not used (/ip hostspot has no interfaces);
IpSec policies are not configured (ROS v6.8);
no active mac-ping, mac-telnet or mac-winbox sessions restriction removed in 6.33;
/tool mac-scan is not actively used;
/tool ip-scan is not actively used;
route cache must be enabled
[rchan@SS-CRT] > /ip firewall/connection/tracking/print
enabled: no
tcp-syn-sent-timeout: 0ms
tcp-syn-received-timeout: 0ms
tcp-established-timeout: 0ms
tcp-fin-wait-timeout: 0ms
tcp-close-wait-timeout: 0ms
tcp-last-ack-timeout: 0ms
tcp-time-wait-timeout: 0ms
tcp-close-timeout: 0ms
tcp-max-retrans-timeout: 0ms
tcp-unacked-timeout: 0ms
loose-tcp-tracking: no
udp-timeout: 0ms
udp-stream-timeout: 0ms
icmp-timeout: 0ms
generic-timeout: 0ms
max-entries: 1048576
total-entries: 0
[rchan@SS-CRT] >
same....7.3 upgrade still breaks x86-64 installation to bootloop state... Very bad...
Had finally time to check this, indeed switching frame types to admit-only-untagged-and-priority-tagged from admit-only-vlan-tagged solved it!Nothings should have changed, however in versions since 7.1beta to 7.2.1 (those I checked) worked incorrectly. Setup: audience running wifiwave2 drivers, configured something like this:Can you give more information how VLAN tagging works on 7.3 (versus 7.2/7.1/7.0)?
didn't work, wifi interface had to be set with "frame-types=admit-only-vlan-tagged" ... which is obviously wrong as wireless interface nominally doesn't know anything about VLAN tags (wifiwave2 driver doesn't offer the "vlan-mode=... vlan-id=..." properties). This was fixed with 7.2.3 (possibly with 7.2.2, but that release broke wifiwave2 driver completely).Code: Select all/interface bridge add name=bridge frame-types=admit-only-vlan-tagged vlan-filtering=yes /interface bridge port add bridge=bridge frame-types=admit-only-vlan-tagged interface=ether1 add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged interface=wifi1 pvid=42 # the 2GHz radio /interface bridge vlan add bridge=bridge tagged=ether1 untagged=wifi1 vlan-ids=42
Adding some outputs to reflect my not understanding of what that change is supposed to do. I enabled l3hw-offload after upgrading to 7.3.1 and as you can see in the output here routes that are tied to another routing table still have the offload enabled on it despite what the change says.
Code: Select all0 AsH 0.0.0.0/0 172.19.0.9 1 DAcH 172.19.0.0/24 MainGateway 0 DAcH 192.168.15.0/24 Management 0 DAcH 192.168.50.0/24 HomeWired 0 DAcH 192.168.51.0/24 HomeWiFi 0 DAcH 192.168.52.0/24 Server 0 DAcH 192.168.53.0/24 Storage 0 1 AsH 0.0.0.0/0 172.19.80.9@iotnet 1 DAcH 172.19.80.0/24 IoTGateway@iotnet 0 DAcH 192.168.80.0/24 IoTDevices@iotnet 0 2 AsH 0.0.0.0/0 172.19.81.9@guestnet 1 DAcH 172.19.81.0/24 GuestGateway@guestnet 0 DAcH 192.168.81.0/24 GuestWiFi@guestnet 0 3 AsH 0.0.0.0/0 172.19.82.9@securenet 1 DAcH 172.19.82.0/24 SecureGateway@securenet 0 DAcH 192.168.82.0/24 Security@securenet 0
You are given the option to suppress offload on configured routes, but not connected ones. So I'm unclear what this new feature is supposed to do?
/ip/route add dst-address=10.0.0.0/8 gateway=192.168.1.1 routing-table=intranet
/interface/ethernet/switch/rule add dst-address=10.0.0.0/8 ports=sfp-sfpplus1,sfp-sfpplus2 redirect-to-cpu=yes switch=switch1
To use user-manager on a 16MB flash device, you have to be masochist...Not so pleasant experience with upgrade 6.49.6 to 7.3.1 Needed all trust in Mikrotik to continu till success.
Wanted to test the current state of the User Manager V5 as wifi Radius server. AP's that make the connection are hAP ac2 and wAP ac.
And you do something with routing marks, right? If so, then it's this. And it looks like the change was intentional, so you'll have to change your mangle rules to not mark traffic to router (e.g. using dst-address-type=!local).Couldn't connect to ac3 after some time after upgrade.
The same situation was when I've tried upgrade from 7.2.1 to 7.2.3.
I have the same problem on Virgin Media in Modem Mode. I can sometimes get an ip if I take the VM router out of modem mode.I have this same problem on my RB4011 upgrading from 7.2.3. I tried both 7.3 and 7.3.1 with no luck. DHCP client status on the internet-facing eth1 interface shows "searching...". My cable modem is ARRIS CM8200A.Hiya,
Cheers!
Jon.
While I agree in principle, this kind of response is pointless and over-used. It certainly doesn't help the poster's situation any. And it doesn't help that MikroTik is pushing all these releases out as "stable." Of course by now, most of us know better, but when MikroTik's team come on the forum and tell us "It works fine in our network," out of desperation we sometimes jump the gun.If you don't want to go out of business probably you should've made some tests with these upgrades on equipment that wasn't "live".
What issue was fixed that pushed admins to upgrade to v7 their core networking equipment?But if a vendor's support tells him that the next version of software will fix the problem they're having, and they do what the vendor says, and it breaks everything[...]
I have all my production devices (over 4000) on 6.46.8 long-term (2020 Oct 29), from border router to AP of end user (the AP of end users are not counted, and not updated, except for exploits),
and I have just one RB5006 device with 7.2.3 (netinstalled), obviously v7, and actually I have no one single problem with that version.
Just from the last week I'm mass updating by hand, on terminal, near 500 devices with 6.48.6 long-term (2021 Dec 03).
But before do such upgrade, I wait near 1 year and do, near everyday, tests, read forum and study the impact of that change...
Indeed that should have been the approach I took. My confidence in Mikrotik was far too high, and I was driven by past incidences of hacks via Winbox a few years ago, to a place where I thought I should keep up with the latest stable updates for security reasons.
That said, has anybody been able to downgrade to 6.x from 7.x? When I tried it on some fortunately surplus bench devices I turned them into door stops. Can't even get them to go through the net boot process.
i did, i downgraded my test unit at work which had a 7.2.1 stable at the time to lts 6.48.6, it's a rb2011. I just put the downgrade file in files list and wrote in terminal:That said, has anybody been able to downgrade to 6.x from 7.x? When I tried it on some fortunately surplus bench devices I turned them into door stops. Can't even get them to go through the net boot process.
When I get the office connected to the network again, hopefully tomorrow, I'll post some of that stuff.While I agree in principle, this kind of response is pointless and over-used. It certainly doesn't help the poster's situation any. And it doesn't help that MikroTik is pushing all these releases out as "stable." Of course by now, most of us know better, but when MikroTik's team come on the forum and tell us "It works fine in our network," out of desperation we sometimes jump the gun.If you don't want to go out of business probably you should've made some tests with these upgrades on equipment that wasn't "live".
Likewise, it is one thing when you are testing two or three devices on a bench. But just because the devices pass the bench test doesn't mean the deployment will work in the real world. You can't simulate everything, and it's nigh impossible to simulate how 100 different devices will work with each other.
Additionally, many ISP's and small businesses who base their networks on MikroTik are a one-man show and simply don't have the resources to spend hours (or days/weeks) testing every corner case.
As for me, I'm running 7.2.x or 7.3 on my arm64 CCR devices (because I don't have a choice) and testing v7 features on a couple of CHR's, RB4011's and hAP AC3's. All other production routers or switches are running 6.47/8/9.x and all radios are on 6.49.x.
To @npyoung, post your OSPF configs (namely filters and redistribution settings). I found a few combinations that would take the network down when ROS7 devices connected.
And for those devices it needs to be added through extra packages.zerotier is only available for arm devices.
Well it seems the User Manager is not the problem.To use user-manager on a 16MB flash device, you have to be masochist...Not so pleasant experience with upgrade 6.49.6 to 7.3.1 Needed all trust in Mikrotik to continu till success.
It makes little sense to release MMIPS or others, since it will not be easy to find any programs that run on MMIPs. Certainly not Pihole or other common docker containers will work there.Container feature is not available on every architecture. Will be available on architecture such as MMIPS or mipsbe ? Or actual available architectures list is definitive ?
Only x86, arm and arm64
Isn't that just "architectures supported by dockerhub"?
$ docker buildx ls
...linux/amd64, linux/arm64, linux/riscv64, linux/ppc64le, linux/s390x, linux/386, linux/arm/v7, linux/arm/v6
Yes. Dockerd and associated utilities can be installed and/or built anywhere a recent enough working Linux is available.Isn't that just "architectures supported by dockerhub"?
When you compile your own binaries, you could use any architecture, of course easiest is to use the architectures supported by gcc.
I thought it was process-based only.
the issue of storage size is completely orthogonal to processor architecture.
This ospf warning is what I see in the router logs again and again, multiple devices.When I get the office connected to the network again, hopefully tomorrow, I'll post some of that stuff.
/interface ethernet switch set 0 l3-hw-offloading=yes
/interface/ethernet/switch/port export verbose
What is beefier than AWS Graviton? Graviton2/3? We already have a server-grade CPU in a short depth pizza box with NVME slot in CRS2XXX line. That should be good enough for majority of workloads that do not require storage redundancy.Still, this'll sort itself out. I fully expect we'll get beefier ARM routers and switches meant to run containers, eventually.
i agree, remember this is a network equipment in first place, container support is a complementary featureWhat is beefier than AWS Graviton? Graviton2/3? We already have a server-grade CPU in a short depth pizza box with NVME slot in CRS2XXX line. That should be good enough for majority of workloads that do not require storage redundancy.Still, this'll sort itself out. I fully expect we'll get beefier ARM routers and switches meant to run containers, eventually.
*) bridge - added more details for loop detection warning;
*) bridge - fixed TCP, UDP port parsing for loop detect warning;
If most of the forwarding is done by switch hardware (L3HW), having spare CPU resources and RAM for containers is really nice to have. It is saving space and electricity for both home lab racks, and especially racks in POPs, where space is at a premium.
7.1.1 reboot without reason today, lost routing table :D Cant add dst routes and gateway.....backup restore ;) please.....same....7.3 upgrade still breaks x86-64 installation to bootloop state... Very bad...
Cant upgrade x86. System go off. When trying to start it says :
Starting.....
soscket: Address family not supported by protocol
startind devices....
CHR can run only on x86_64
heh i try donwload iso and install .... same thing.
7.1.1 > 7.2.1
7.1.1 > 7.3.1
Dell R420 without virtualization. Trying to install 7.1.1+ from iso x86. Instalation pass but cant run system. Cant upgrade 7.1.1 to 7.2 or 7.2.1 or whatever...... System not running after reboot. 7.1.1 working but sometimes reboot without reason....
You clearly have no exposure to costs of colo space in space constrained edge POPs. Ask your CDN operator about costs of 1U to familiarize yourself with the subject.and a few bucks for another 1U of rack space?
We clearly have pretty different views on how to properly run network (a small ISP network none the less). IMO if one depends on running some essential service (such as DNS or just anything else for that matter) inside a container on a core router or switch (yeah, many switches CRS3xx and newer can do L3HW as well, but that still doesn't make them routers), then it's time to reconsider business model. If such service is run in edge POPs, then I understand even less.You clearly have no exposure to costs of colo space in space constrained edge POPs. Ask your CDN operator about costs of 1U to familiarize yourself with the subject.and a few bucks for another 1U of rack space?
It's not exactly obvious but you have to do it in two steps.How to check BGP advertisement in ROS v7.
dump.ADV is not working. When i try to dump-saved-advertisement 0 save-to="bgp-view1.pcap"
No such file is saved or created in router. Please Help
/routing/bgp/connection/set output.keep-sent-attributes=yes bgp-conn-1
/routing/bgp/session/print
/routing/bgp/session/dump-saved-advertisements save-to=bgp-advertisements.pcap 0
/routing/stats/pcap/print
Tried but not exactly working...
1.2. Find BGP session number withCode: Select all/routing/bgp/connection/set output.keep-sent-attributes=yes bgp-conn-1
to use below (0 for example)Code: Select all/routing/bgp/session/print
3.You can also view the output withCode: Select all/routing/bgp/session/dump-saved-advertisements save-to=bgp-advertisements.pcap 0
although it's a big buggy and doesn't display IPv6 addresses very well.Code: Select all/routing/stats/pcap/print
@stroebs
They added this to 7.4beta5: *) dhcpv4-server - placed option 53 as the first one in the packet;
Hopefully this will fix our issue. Thanks for your work on this.
Regarding the Nest cam issue when upgrading to 7.3.x, this is what I found:
The DHCP Offer has re-ordered options compared to 7.2.x.
7.2.1 DHCP Offer:
7.3.1 DHCP Offer:
You will notice that the options are now in numerically sorted order in 7.3.x, which dhcpcd-5.5.6 (which is in use on Nest hardware, and clearly a ludicrously old version) does not seem to support.
How do I open a ticket with Mikrotik? Has anyone had any success with the DHCP-Client Issue? I am no longer able to pull an IP address from my ISP on the WAN Interface.
i have 7.3.1 installed on a RB760iGS but it is like i lost all the info on the SFP module (...)
I confirmed this a reproducible SFP bug/issue on both RB760iGS and RB760iGS r2 running default configuration with both UF-RJ45-1G and UF-SM-1G-S in addition to the Mikrotik module:Don't know if this is a bug or I'm missing something but after v7 my Hex S refuses to show any information for the SFP module which I'm using on it. (...)
[admin@MikroTik] > /system/routerboard/ print
routerboard: yes
board-name: hEX S
model: RB760iGS
revision: r2
serial-number: <>
firmware-type: mt7621L
factory-firmware: 6.47.10
current-firmware: 7.3.1
upgrade-firmware: 7.3.
[admin@MikroTik] > /interface/ethernet/ monitor sfp1 once
status: link-ok
auto-negotiation: done
rate: 1Gbps
full-duplex: yes
tx-flow-control: no
rx-flow-control: no
advertising: 10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
link-partner-advertising: 10M-half,10M-full
sfp-module-present: yes
sfp-rx-loss: no
sfp-type: (unknown)
eeprom-checksum: good
eeprom: 0000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
status: no-link
sfp-rx-loss: yes
sfp-type: (unknown)
I can confirm.Hello guys,
Don't know if this is a bug or I'm missing something but after v7 my Hex S refuses to show any information for the SFP module which I'm using on it. Even posted a separate topic in the forum, but it seems no one knows anything for this. I've tested on 7;7.1;7.2;7.3 and the problem is the same. It is really strange moreover that it's a MT SFP ->S-85DLC05D.
Updated from 7.0.4 to 7.3.1 today but am still seeing intermittent interface flapping when connected to an AVM Fritz!Box Cable Modem from Vodafone Germany.*) ccr - improved interface link stability on CCR2004-16G-2S+PC;
that's right, but if I configure 192.168.169/23 it gives me errorCould be by-product of wrongly configured address ... it should be 192.168.169.0/23
Which is correct. It is an error.that's right, but if I configure 192.168.169/23 it gives me errorCould be by-product of wrongly configured address ... it should be 192.168.169.0/23
Perfect, so even if I use the DHCP only for IP 192.168.169.0, I must always put 192.168.168.0 as initial.Which is correct. It is an error.
You need 4 octets for a subnet and then netmask.
As initial ... what ? Address ? If using /23 netmask, you need to use 192.168.168.0 as basis, yes.Perfect, so even if I use the DHCP only for IP 192.168.169.0, I must always put 192.168.168.0 as initial.Which is correct. It is an error.
Can you confirm?
Can you confirm?
set interface=<LAN interface> address=192.168.168.230/23
/ip dhcp-server pool
add name=default addresses=192.168.169.50-192.168.169-199
add name=staticDHCP addresses=192.168.168.1-192.168.168.255
add address=192.168.169.48/28 dns-server=1.1.1.1 gateway=192.168.168.230 netmask=23
add address=192.168.168.0/24 dns-server=192.168.168.230 gateway=192.168.168.230 netmask=23 ntp-server=132.163.97.2,132.163.96.5
add address-pool=default interface=<LAN interface> name=default
/ip dhcp-server lease
address=192.168.168.25 client-id=1:aa:bb:cc:dd:ee:ff mac-address=aa:bb:cc:dd:ee:ff server=default
Honestly, I don't like working with the subnets too, but the customer who mounted new devices, he needed other IP addresses and therefore I had to change all the IP addresses of the network equipment.Perfect, so even if I use the DHCP only for IP 192.168.169.0, I must always put 192.168.168.0 as initial.
Can you confirm?
No, as I explained: DHCP network address/mask has to cover the whole IP address range, assigned to DHCP server. If your address range is 192.168.169.50-192.168.169.199, then you can use DHCP network address 192.168.169.0/24. Or 192.168.169.0/23 or 192.168.168.0/23 (these define the same IP address space).
If, OTOH, DHCP address range was 192.168.169.49-192.168.169.63, you could set DHCP address to 192.168.169.48/28.
This concept then extends to this kind of setup:
The last configuration stance sets static DHCP lease for device with MAC address as set ... that device will always receive same IP address (as set by configuration command), but will also receive slightly different set of other DHCP options - different DNS server IP address and additional option - NTP server addresses.Code: Select all/ip address set interface=<LAN interface> address=192.168.168.230/23 /ip dhcp-server pool add name=default addresses=192.168.169.50-192.168.169-199 add name=staticDHCP addresses=192.168.168.1-192.168.168.255 /ip dhcp-server network add address=192.168.169.48/28 dns-server=1.1.1.1 gateway=192.168.168.230 netmask=23 add address=192.168.168.0/24 dns-server=192.168.168.230 gateway=192.168.168.230 netmask=23 ntp-server=132.163.97.2,132.163.96.5 /ip dhcp-server add address-pool=default interface=<LAN interface> name=default /ip dhcp-server lease address=192.168.168.25 client-id=1:aa:bb:cc:dd:ee:ff mac-address=aa:bb:cc:dd:ee:ff server=default
However: if you go into trouble of setting DHCP address to anything different than your LAN address space, you may run into some obscure problems. Such as: assign static DHCP lease for a particular device and address falls outside all of DHCP network addresses ... in which case you'll suffer of the same problem as you described in original post. To avoid such problems, it's safest to set DHCP address in line of router's IP settings ... in your case this means DHCP address = 192.68.168.0/23.
again. but another reboot set back to normal....cant open routing table in console too.. its freeze
I have the same problem with Movistar, RIP is properly configured.Are you upgrading from 6.x version? did you configure the RIP instance?
1 0.000000 0.0.0.0 255.255.255.255 DHCP 389 DHCP Discover - Transaction ID 0x6fa6c077
2 1.001661 0.0.0.0 255.255.255.255 DHCP 389 DHCP Discover - Transaction ID 0x8cff4cc2
3 2.000925 0.0.0.0 255.255.255.255 DHCP 389 DHCP Discover - Transaction ID 0x8cff4cc2
4 4.693813 0.0.0.0 255.255.255.255 DHCP 389 DHCP Discover - Transaction ID 0x8cff4cc2
5 9.314733 0.0.0.0 255.255.255.255 DHCP 389 DHCP Discover - Transaction ID 0x8cff4cc2
11 150.913015 0.0.0.0 255.255.255.255 DHCP 389 DHCP Discover - Transaction ID 0x8e80d2ed
12 150.934217 10.29.96.1 255.255.255.255 DHCP 438 DHCP Offer - Transaction ID 0x8e80d2ed
13 150.934221 0.0.0.0 255.255.255.255 DHCP 389 DHCP Request - Transaction ID 0x8e80d2ed
15 165.933313 0.0.0.0 255.255.255.255 DHCP 389 DHCP Request - Transaction ID 0x8e80d2ed
by the way, was you able to make work Movistar's IPTV on fusion contract with Mikrotik?Upgraded multiple devices inc CCR1009 / CRS317 / RB4011 / RB3011 / wAP AC all OK.
I've tested on 7.4rc2 and here it worksI have the same problem with Movistar, RIP is properly configured.
I was working for me on 7.x for long period (various versions) and recently, on 7.3.1 I guess, get broken
What is even funny -
with default DHCP client configuration in tcpdump:but, if I've remove hostname from dhcp client options, it will have Offer in response with proposed IP address, but still not completes:Code: Select all1 0.000000 0.0.0.0 255.255.255.255 DHCP 389 DHCP Discover - Transaction ID 0x6fa6c077 2 1.001661 0.0.0.0 255.255.255.255 DHCP 389 DHCP Discover - Transaction ID 0x8cff4cc2 3 2.000925 0.0.0.0 255.255.255.255 DHCP 389 DHCP Discover - Transaction ID 0x8cff4cc2 4 4.693813 0.0.0.0 255.255.255.255 DHCP 389 DHCP Discover - Transaction ID 0x8cff4cc2 5 9.314733 0.0.0.0 255.255.255.255 DHCP 389 DHCP Discover - Transaction ID 0x8cff4cc2
(offer even have client IP address, but it does not work)
Code: Select all11 150.913015 0.0.0.0 255.255.255.255 DHCP 389 DHCP Discover - Transaction ID 0x8e80d2ed 12 150.934217 10.29.96.1 255.255.255.255 DHCP 438 DHCP Offer - Transaction ID 0x8e80d2ed 13 150.934221 0.0.0.0 255.255.255.255 DHCP 389 DHCP Request - Transaction ID 0x8e80d2ed 15 165.933313 0.0.0.0 255.255.255.255 DHCP 389 DHCP Request - Transaction ID 0x8e80d2ed
That is correct, RB760iGS does not support L3 hardware offload. It is a bug that it is shown as a clickable option, that will likely be removed in future versions.On RB760iGS L3 hardware offload seems to not be working.
It works for me on 7.3.1 without any issue.Hey is SSTP broken in version OS V7 ? As it works perfect in version 6 but not in version 7 Certs chain to root problem
ROS7 doesn't do too well on devices with low resources.So i want to know maybe someone have answer is it a common problem for my device and i should never upgrade it at all from version 6 to 7 or maybe it just such a bad fw and i shoul wait for another one? Thank you all!
Thank you, for answer!ROS7 doesn't do too well on devices with low resources.So i want to know maybe someone have answer is it a common problem for my device and i should never upgrade it at all from version 6 to 7 or maybe it just such a bad fw and i shoul wait for another one? Thank you all!
Like hap lite.
Best to stick with ROS6 for that device.
