nemke
upgrade v6 to v7 ltap mini
Tue Jun 07, 2022 5:28 pm
Hello
I have Ltap mini and from some reson he won't upgrade to v7. I try directy over terminal
channel: upgrade
installed-version: 6.49.6
latest-version: 7.3
status: New version is available
system pachage update downaload
system reboot
from winbox using system/package also to drag and drop mipsbe v7.3 packet and after reboot he is still on 6.49.6. Try to change Channel to "update" and "testing" and "delevopment" but still nothing. What I missing ?
rextended
Re: upgrade v6 to v5 ltap mini
Tue Jun 07, 2022 6:22 pm
something wrong on the topic title.....
Sob
Tue Jun 07, 2022 8:18 pm
Something in log perhaps?
nemke
Wed Jun 08, 2022 12:56 am
23:53:07 system,error broken package advanced-tools-7.3-mipsbe.npk
23:53:07 system,error broken package ppp-7.3-mipsbe.npk
23:53:07 system,error broken package routing-7.3-mipsbe.npk
23:53:07 system,error broken package mpls-7.3-mipsbe.npk
23:53:07 system,error broken package security-7.3-mipsbe.npk
23:53:07 system,error broken package wireless-7.3-mipsbe.npk
23:53:07 system,error broken package dhcp-7.3-mipsbe.npk
23:53:07 system,error broken package hotspot-7.3-mipsbe.npk
23:53:07 system,info installed system-7.3
23:53:07 system,info installed lora-7.3
23:53:07 system,info installed gps-7.3
23:53:07 system,error not enough space for upgrade
23:53:07 system,info router rebooted
How can be broken I try drag and drop and also direct download over ssh ?
rextended
Re: upgrade v6 to v7 ltap mini  [SOLVED]
Wed Jun 08, 2022 12:59 am
broken because are not downloadable and do not exist single packages,
but at the end the problem is this:
You created the problem by installing single packages instead of leaving the single package as default.
nemke
Wed Jun 08, 2022 6:23 pm
I solve problem by uninstall packet by packet, and reboot. After that drag and drop v7.3 packet to router and reboot. After that add lora and gps packets.
Just, security,system, ppp,advanced-tools, dhcp I left on router before drag and drop v7.3 packet.
Users browsing this forum: Ahrefs [Bot] and 164 guests
