mrleamerz
Wireles-WIre + one
Thu Jun 09, 2022 12:34 am
I have installed may of these AWESOME kits they all worked flawless, now I want to do a little but more.. If I have a wireless-wire kit, can I buy another ap and connect it to have 2 ap's talk to the main ap ? ( of course copy information like shared secret password & ssid info.
OR Do i need to buy 3 60g ap's and re configure all 3.
2frogs
Forum Veteran
Forum Veteran
Re: Wireles-WIre + one
Thu Jun 09, 2022 3:02 am
You will need to purchase the AP version.
https://mikrotik.com/product/wap_60g_ap
The kits only have a level 3 license that only allow for them to be stations or an AP for a single station. The AP versions have a level 4 license.
https://wiki.mikrotik.com/wiki/Manual:License
mrleamerz
Thu Jun 09, 2022 4:32 am
Ahh, ok. This makes sense thank you :)
Then i would buy 3 of the AP_60g_ap's put one as main and the other's as clients. Will they do 400m distance still ?
2frogs
Forum Veteran
Forum Veteran
Thu Jun 09, 2022 3:29 pm
You can use the ones from the kit or non-AP versions (as stations) to connect to the AP version. No need to spend extra on those.
mrleamerz
Fri Jun 10, 2022 1:08 am
Confusing, but also trying to order the correct equipment :) Are you saying order one wireless wire kit and a non ap version ?
2frogs
Forum Veteran
Forum Veteran
Fri Jun 10, 2022 1:35 am
No, order one wAP 60G AP (this will be your Main AP in your attached pic.)
Order one Wireless Wire kits to reconfigure as your two clients. Or, in place of the Wireless Wire kit, you can order two wAP 60G. The wAP 60G is the same devices as is in the Wireless Wire kit, but just one. I include this for availability reasons.
mrleamerz
Wed Jul 06, 2022 7:00 am
2frogs,
The 3 pieces you suggested arrived today, took me 3 min to change the config and have them all talking ! Thank you for your help sir !! YOU ROCK !
Users browsing this forum: nagaju and 47 guests
