gutekpl
Gmail SMTP authentication doesn't work anymore, oauth needed
Thu Jun 09, 2022 10:47 am
As in topic google have just removed support for logging to gmail mailbox just with login and password via smtp. They informed about it twice, and now since two days all my routers stopped sending logs via email. Are there plans to implement oauth on mikrotik devices or we need to move to other mailbox provider?
dadaniel
Re: Gmail SMTP authentication doesn't work anymore, oauth needed
Thu Jun 09, 2022 11:04 am
gutekpl
Thu Jun 09, 2022 11:07 am
The setting you're looking for isn't available in your account.
EDIT. Ok it now appeared as available after enabling two factor authentication. Seems it may be the solution to this.
kevinds
Long time Member
Long time Member
Thu Jun 09, 2022 7:45 pm
Yes, two-factor-authentication is required for app passwords.
k6ccc
Fri Jun 10, 2022 2:02 am
Changed several of my Gmail accounts to 2FA and added app passwords and now working fine on my three MT routers, and a bunch of other devices.
dioeyandika
Fri Jun 10, 2022 4:11 am
wow thanks for this after activating s2fa and app password it work again :)
Znevna
Fri Jun 10, 2022 8:18 am
Weird that something documented works as intended, huh?
robyhr
Fri Jan 19, 2024 7:34 am
I just received mail that app passwords are going away too, and we need to switch to OAuth by the end of the year. Does RouterOS support OAuth now?
kevinds
Long time Member
Long time Member
Fri Jan 19, 2024 7:46 am
Seriously? $*%&$(*@(#$!^*#
Time to stop using Google then I suppose.
nichky
Fri Jan 19, 2024 7:48 am
kevinds
Long time Member
Long time Member
Fri Jan 19, 2024 7:51 am
check this
That isn't OAuth?
anovojr
Fri Jan 19, 2024 7:28 pm
Haven't heard any official word from Mikrotik about OAuth, but it would make sense for them to jump on that bandwagon.
aoakeley
Sat Jan 20, 2024 7:17 am
There are plenty of SMTP Relay services that allow relay over port 25 or 2525 or 587 etc with and without TLS and using a normal username/password. Many of them are even free for small numbers of emails e.g. SMTP2GO free for 1000 emails per month,
I would prefer to see the development team work on more core features of a router than implementing an OAUTH client in RouterOS.
kevinds
Long time Member
Long time Member
Sat Jan 20, 2024 9:01 am
Why?
mhbuzios
Mon Feb 10, 2025 1:41 am
Thanks :D
after enable the 2FA it works!!!
Just one note after you enter https://myaccount.google.com/apppasswords
you have to create the password for use it with your mikrotik gmail account :wink:
