OlofL
routeros 7.3.1 - ip ssh not working
Fri Jun 10, 2022 5:18 pm
after upgrading to 7.3.1
ip ssh is not working...
I tried:
[*] change any options and press apply
[*] press "regenerate host key"
[*] import ssh pubkey to user
[*] upgrade to 7.4beta, downgrade again
[*] export ssh-host-key
[*] export host priv+pub files from another mikrotik and import to this one
I get these errors
Couldn't perform action - feature is not implemented (2)
or
error - contact MikroTik support and send a supout file (2)
or
#error exporting /ip/ssh
Belyache
Re: routeros 7.3.1 - ip ssh not working
Sat Jun 11, 2022 12:44 am
I am also seeing the same issue. Mine is a Hex Lite, RB 750r2. Also on 7.3.1.
Exporting the key gives the same error.
Also, no SSH access at this point.
Glenn
loloski
Sat Jun 11, 2022 1:45 am
for tile architecture it's working
[rchan@SS-BRAS01] /ip/ssh> /ip/ssh/regenerate-host-key
This will regenerate current SSH host keys, yes? [y/N]:
y
[rchan@SS-BRAS01] /ip/ssh> y
06:43:32 echo: ssh,critical SSH host key regenerated!
[rchan@SS-BRAS01] /ip/ssh> /system/resource/print
             uptime: 8h34m26s
            version: 7.3.1 (stable)
         build-time: Jun/09/2022 08:58:15
   factory-software: 6.45.9
        free-memory: 7.4GiB
       total-memory: 7.9GiB
                cpu: tilegx
          cpu-count: 36
      cpu-frequency: 1200MHz
           cpu-load: 0%
     free-hdd-space: 859.1MiB
    total-hdd-space: 1024.0MiB
  architecture-name: tile
         board-name: CCR1036-8G-2S+
           platform: MikroTik
Cray
Sat Jun 11, 2022 12:19 pm
I can confirm that this issue exists also with RBLtAP-2HnD (LtAP LTE6 kit) (mmips) and RouterOS 7.3.1
Cray
Sat Jun 11, 2022 12:33 pm
I just created support ticket (/w supout.rif, screenshots) from our testing unit.
Waiting for MikroTik support to respond.
twamuc
Sun Jun 12, 2022 1:39 am
Same for RB760iGS (hEX S) on 7.3 and 7.3.1 - raised a ticket 3 days ago but no success yet...
soonwai
Sun Jun 12, 2022 9:14 am
I seem to have the same problem on RB5009 and 7.3.1.
Brand new RB5009, came with 7.1.x, upgraded to 7.3.1, did most of the configuration in Wnbox and Wnbox Terminal. Only encountered this error when configuring /ip/ssh.
/ip/ssh print results in "error - contact MikroTik support and send a supout file (2)"
Found the problem. Here's how to replicate it.
(from "/system/reset-configuration no-defaults=yes")
1. /ip/ssh/set strong-crypto=yes
2. /ip/ssh/regenerate-host-key
3. reply n
(seems fine if Y to regenerate-host-key)
  MMM      MMM       KKK                          TTTTTTTTTTT      KKK
  MMMM    MMMM       KKK                          TTTTTTTTTTT      KKK
  MMM MMMM MMM  III  KKK  KKK  RRRRRR     OOOOOO      TTT     III  KKK  KKK
  MMM  MM  MMM  III  KKKKK     RRR  RRR  OOO  OOO     TTT     III  KKKKK
  MMM      MMM  III  KKK KKK   RRRRRR    OOO  OOO     TTT     III  KKK KKK
  MMM      MMM  III  KKK  KKK  RRR  RRR   OOOOOO      TTT     III  KKK  KKK
  MikroTik RouterOS 7.3.1 (c) 1999-2022       https://www.mikrotik.com/
Press F1 for help
Change your password
new password> ********
repeat new password> ********
Password changed
[admin@MikroTik] > /ip/ssh/print
           forwarding-enabled: no
  always-allow-password-login: no
                strong-crypto: no
            allow-none-crypto: no
                host-key-size: 2048
[admin@MikroTik] > /ip/ssh/set strong-crypto=yes
[admin@MikroTik] > /ip/ssh/regenerate-host-key
N
action cancelled
[admin@MikroTik] >
Cray
Thu Jun 16, 2022 10:35 am
FYI
I've tested a debug/development firmware for mmips devices that fixes SSH service issues.
Mikrotik Support has informed me, that their proposed fix will be included in the upcoming releases:
Great, glad to hear that. We will finish up the fix and will include it in the upcoming RouterOS releases.
So, help is coming. We'll just have to wait a little while :-D
soonwai
Thu Jun 16, 2022 11:26 am
^^^ Same here. Test version fixes the problem.
strods
Mon Jun 20, 2022 2:05 pm
This problem should be resolved in v7.4beta4. Please test and see if the fix is working properly for you.
e17
Tue Jul 26, 2022 9:47 pm
MIPSBE version was also affected. Upgrading to the now-current v7.4rc2 solved the problem.
mkx
Wed Jul 27, 2022 12:27 pm
Since a few days ago, now current is 7.4 (release version).
Users browsing this forum: No registered users and 63 guests
