starcow
MikroTik router RB2011UIAS-2HND-IN to slow
Fri Jun 10, 2022 5:29 pm
My MikroTik router RB2011UIAS-2HND-IN barely manages 400Mbit/s on a 1GBit/s line over ethernet cable. Today I had installed a Firtzbox router for comparison. This creates almost 1000Mbit/s.
Are there any configurations that could be changed to achieve similar results? Is this limitation normal for this model series?
Many thanks, starcow
onnoossendrijver
Re: MikroTik router RB2011UIAS-2HND-IN to slow
Fri Jun 10, 2022 5:46 pm
Do you have fasttrack configured?
Also.. The RB2011 is not the fastest router anymore.. Consider upgrading to a 4011 or 5009.
starcow
Fri Jun 10, 2022 5:51 pm
I don't know that. What is fasttrack and where can I turn it on?
Cheers, starcow
Sob
Fri Jun 10, 2022 5:53 pm
starcow
Mon Jun 13, 2022 1:13 pm
Super thank you! The setting helped!
Users browsing this forum: flyr, lurker888 and 25 guests
