chrisc
Mikrotik HA2 strange IP address
Sat Jun 11, 2022 10:35 am
Good day
I have had 2 HA2 routers, one for my own use and one at a CCTV installation
To access these routers, I enter 192.168.88.1 in a web browser
A new ISP supplied a faulty TP-Link router and resisted all attempts to exchange it, so I purchased a new HA2 from a local supplier
This works 100%, the throughput is excellent
It has one anomaly. Windows ipconfig /all shows the router's IP address to be 192.168.101.1, likewise Winbox shows the same. I cannot access the router to set up the wireless credentials, either with a web browser or Winbox
I reset the router according to the instructions (three times) but the IP address won't change
From a phone,. it will connect to the open SSID Mikrotik and also shows 192.168.101.1
All the supplier will say is "that is not right" but offers no other solution. I really have no idea how to resolve this
Thank you!
rextended
Re: Mikrotik HA2 strange IP address
Sat Jun 11, 2022 11:38 am
use netinstall, the vendor or some previous proprietary has changed default configuration.
chrisc
Sat Jun 11, 2022 12:43 pm
Created manual IP address as per guide (192.168.101.1)
Netinstall reports: Cannot open device
I have not come across being unable to access a device where the IP address is known
rextended
Sat Jun 11, 2022 12:50 pm
What guide?
You can click on MAC address.
chrisc
Sat Jun 11, 2022 4:54 pm
The guide was here - https://mikrotik.com/download
1 - Download netinstall and the program
2 - Disconnect LAN
3 - Create static IP address
4 - Connect router
5 - Power down router, hold down reset, power up, wait for light to stop flashing
6 - Run netinstall
That is what the supplier told me as well, but it won't connect. I cannot see where to click the MAC address
In the first post is a screenshot of Winbox
Sob
Sat Jun 11, 2022 5:13 pm
In the first post you already have MAC address in Connect To field. What's missing is Login and Password (default is "admin" and no password).
chrisc
Sat Jun 11, 2022 5:58 pm
Yes I know
I tried combinations of password and no password
Previous HA2s I have used had "admin" for both
I have to keep asking here, as the supplier is unhelpful. He tells me he has not seen this problem before, he just assumed the router was ex factory and said it seemed I did not know what I was doing
Sob
Sat Jun 11, 2022 6:50 pm
And did you see this very detailed guide about Netinstall?
https://help.mikrotik.com/docs/display/ROS/Netinstall
sid5632
Long time Member
Long time Member
Sun Jun 12, 2022 3:34 am
Clearly this device is used and your 'supplier' is trying to palm you off with a used item as a new one. And then they have the cheek to make out all the admin problems are your fault.
Send it back and demand your money back. Is this an 'official' MikroTik distributer?
Might be time for name'n'shame.
Users browsing this forum: karlisi, unhuzpt and 126 guests
