foxman
Hardware Recomendations
Sat Jun 11, 2022 10:50 am
Hi
I need to terminate 400 L2TP tunnels to a Mikrotik. No IPsec encryption. I have tried this with a crs125, it works but the throughput is terrible. What box would be best to achieve this?
rextended
Re: Hardware Recomendations
Sat Jun 11, 2022 12:17 pm
Terminating tunnels is not a switch thing: they are all managed by the CPU.
But I can not suggest to you an appropriate CCR model, because I not have a device that manage directly that ammount of links.
chechito
Sun Jun 12, 2022 5:10 am
which throughput are you needing ?
cfikes
Sun Jun 12, 2022 5:57 am
I'm interested in the network design that uses 400 unencrypted l2tp tunnels.
elbob2002
Sun Jun 12, 2022 10:44 am
Maybe try a CHR on a supported hypervisor? You can add more resources if you find you run out.
ingdaka
Trainer
Trainer
Sun Jun 12, 2022 8:08 pm
I have experience in this! You need CHR with 6 core or an CCR2116. Other versions with RoS 6.x can hande like CC1016 or 1036 but as all is moving to RoS v7, better to get an CCR with 64bit processor
Users browsing this forum: No registered users and 46 guests
