aliaskorea
Auto Gateway Change Scripts that work in ROS v7
Sat Jun 11, 2022 7:12 pm
:if ($bound=1) do={/ip route set [find where dst-address=0.0.0.0/0 routing-table=ISP1 ] gateway=$"gateway-address" }
Hi, This code seems not working ROS v7 but only in v6.xx.
Could you get code that working v7.
This code is 'Auto Gateway Change Scripts'. I found lately.
viewtopic.php?t=173560
viewtopic.php?t=173560#p929446
Maybe there's something I'm missing or I'm not aware of.
Please, reply.
Appreciated.
CCR2004-16G-2S+PC
ROS v7.3.1
Sob
Re: Auto Gateway Change Scripts that work in ROS v7
Sat Jun 11, 2022 7:40 pm
Did you add the route first? This script only updates gateway, doesn't add route if it doesn't exist.
aliaskorea
Sat Jun 11, 2022 8:42 pm
Yes, of course. But at DHCP client renew or release seems not updated.
Does code seems working well? I using 2WAN to 2LAN.
Received two ip is applied to my two NAS.
If it working good, seems i misunderstood about this code algorism.
I'll try again. Thank you.
Sob
Sat Jun 11, 2022 9:31 pm
It depends on what exactly you configured. If you have two DHCP clients, you need two routes, one for each, in different routing tables. Each DHCP client needs script with own routing-table=<name>. And if both gateways have same IP address, you also need to append %etherX to gateway addresses in scripts.
aliaskorea
Sun Jun 12, 2022 2:33 pm
I Understand. Thanks...
hermestcp
Tue Jun 14, 2022 3:24 am
help
How can I add the %ether1 variable to the gateway in the dhcp client script
rextended
Re: Auto Gateway Change Scripts that work in ROS v7  [SOLVED]
Tue Jun 14, 2022 10:09 am
{not tested, just for provide a reply}
:if ($bound=1) do={/ip route set [find where dst-address=0.0.0.0/0 and routing-table="ISP1" ] gateway=( $"gateway-address" . "%ether1" ) }
aliaskorea
Thu Jun 16, 2022 3:07 pm
Thanks. I applied the script now. How should I test to see if the script change?
Just renew menu alone cannot confirm. What the comma mean? between address and ether.
aliaskorea
Thu Jun 16, 2022 3:08 pm
help
%ether1 variable is already added. Thank you!
Users browsing this forum: vaio73 and 40 guests
