7zki
RB4011 after upgrade from 7.1 to v7.3.1 cannot ping and into winbox.
Sun Jun 12, 2022 6:55 am
Hello everyone.
I have a RB4011iGS+5HacQ2HnD-IN. I did upgrade in the winbox from 7.1 to v7.3.1, after reboot it cannot ping and cannot into webfig or winbox. But Other parts work fine, Why is this?
Sob
Re: RB4011 after upgrade from 7.1 to v7.3.1 cannot ping and into winbox.
Sun Jun 12, 2022 7:05 pm
Do you have multi WAN or VPN and use mangle roules to direct traffic certain way? If so, you're hit by unexpected change in priority of marked packets. See e.g. this thread: viewtopic.php?t=186638
Hopefully you didn't disable WinBox connection to MAC address, so use that to get back, and they you'll need to change mangle rules to exclude local destinations (dst-address-type=!local).
7zki
Mon Jun 13, 2022 8:19 am
yes, I have two WAN and use mangle roules, but i disable WinBox connection to MAC address, can i connect it with console interface?
Zacharias
Mon Jun 13, 2022 8:41 pm
If you can't connect through IP or MAC you can always use a console cable yes...
7zki
Wed Jun 15, 2022 3:32 pm
Thank you, I used console cable to connect to the router, after fixing mangle rule router the router works find.
Users browsing this forum: Renfrew and 162 guests
