tomasmato
configuration is exported without passwords
Sun Jun 12, 2022 11:54 am
Hello, I upgraded to Mikrotik version 7 and I have a problem that when I export the configuration (new terminal - export file), my passwords are not exported at all (for example PPP passwords, WireGuard keys, RoMON password, etc.).
Does anyone please know what this could be, or how to export the configuration with passwords?
Thank you all in advance.
holvoetn
Re: configuration is exported without passwords
Sun Jun 12, 2022 12:05 pm
Use show-sensitive
Default on ros7 = hide
tomasmato
Sun Jun 12, 2022 12:38 pm
And how can I set show-sensitive? Under which tab can I find it or which command should I enter in the terminal?
Thank you for your reply in advance.
holvoetn
Sun Jun 12, 2022 12:59 pm
Use tab to see possible options for a command
In your case it would be
/export show-sensitive=yes file=<anynameyouwish>
I'm not 100% sure if verbose also needs to be used to have really all.
rextended
Sun Jun 12, 2022 4:03 pm
"/export show-sensitive" without =yes
holvoetn
Re: configuration is exported without passwords  [SOLVED]
Sun Jun 12, 2022 5:19 pm
Ah yes, was responding from memory.
Tab would have shown it ;)
tomasmato
Mon Jun 13, 2022 12:52 am
It works great, thank you very much.
Users browsing this forum: 5h4k4, Google [Bot], holvoetn, intania, ips, mkx, pajapatak and 54 guests
