pmladenov
CCR2004-16G-2S+PC - No IPsec hardware acceleration?
Sun Jun 12, 2022 4:44 pm
I can't see anything mentioned about "IPsec hardware acceleration" on the specs of new CCR2004-16G-2S+PC (passive cooling) router -> https://mikrotik.com/product/ccr2004_16 ... ifications, there is nothing mentioned about IPSec throughput performance into Test Results either https://mikrotik.com/product/ccr2004_16 ... estresults.
Am I missing something? For instance CCR2004-16G-2S+ does support and there are test results posted https://mikrotik.com/product/ccr2004_16 ... estresults
Both block diagrams are pretty close to each other and the main difference (apart from power supply & fan controller) is that CPU of CCR2004-16G-2S+ looks to be a little bit overclocked to 1.7GHz, compared to 1.2GHz CPU of CCR2004-16G-2S+PC (probably because of heating constrains).
My question is - should I use CCR2004-16G-2S+PC with IPSec and what kind of throughput may I expect (I need it for ~5 site-to-site IPSec tunnels)?
Thanks,
Plamen
zykki
Re: CCR2004-16G-2S+PC - No IPsec hardware acceleration?
Thu Jun 16, 2022 12:11 pm
I would also like to know the answer to this question.
TRNX
Tue Oct 04, 2022 2:15 pm
Hello. I need the same info.
johnson73
Tue Oct 04, 2022 2:51 pm
All CCR models have a hardware accelerator. 5 vpn tunnel without problems.
CSR460
Mon Oct 10, 2022 1:33 am
I sent a email to the sales team, got a response:
Thank You for Your interest in our products!
IPsec test results for CCR2004-16G-2S+PC will be available in the nearest time! Theoretically, the results should be similar to CCR2004-16G-2S+ but due to the lower CPU frequency (limited for cooling reasons) they should be a bit more modest.
I hope this helps!
Best regards,
Aigars Pumpiņš
Users browsing this forum: Bing [Bot], Fi011, Techsystem and 187 guests
