gemesif
Mikrotik SMB server – connecting with Windows and Linux client(syllabus)
Sun Jun 12, 2022 6:16 pm
Purpose, to share my experiences about this theme.
Labs environment:
- Mikrotik hAP ac2, RouterOS 6.49.6, with USB stick
- Microsoft Windows 10 Pro
- Ubuntu Linux 20.04 LTS guest, on VirtulBox, bridged WAN interface with Windows
I. Router configurattion
in terminal:
(minimal configuration)
Note: RouterOS only supports SMB v1.0 and v2.002
/ip smb
set enabled=yes
/ip smb shares
add directory=/disk1 name=mikrotikusb
check it:
/ip smb shares print
Flags: X - disabled, I - inactive, * - default
 #    NAME                                                              DIRECTORY                                                             MAX-SESSIONS
 0  * ;;; default share
      pub                                                               /flash/pub        10
 1    mikrotikusb                                                       /disk1        10
/ip smb users print
Flags: * - default, X - disabled
 #    NAME        PASSWORD                                                               READ-ONLY
 0 *  guest        yes
/ip dns static print
Flags: D - dynamic, X - disabled
 #    NAME                          REGEXP                          TYPE     ADDRESS                                                          TTL
 0    ;;; defconf
      router.lan                                                             192.168.88.1                                                     1d
 1    bananapi.lan                                                           192.168.88.182                                                   1d
II. Windows configuration
in cmd prompt:
net use
New connections will be remembered.
Status       Local     Remote                    Network
OK           Y:        \\bananapi.lan\bananapitmp
                                                Microsoft Windows Network
OK           Z:        \\bananapi\bananapi       Microsoft Windows Network
The command completed successfully.
choose free netwotk drive, and
net use X: \\router.lan\mikrotikusb /user:guest /persistent:yes
Enter the password for 'guest' to connect to 'router.lan':
Enter the password for 'guest' - push Enter, guest has't password
net use
OK           X:        \\router.lan\mikrotikusb  Microsoft Windows Network
list mapped drive:
dir X:
    Directory: X:\
Mode                 LastWriteTime         Length Name
-a----     2022. 06. 08.     18:18        6926360 attack.0.txt
-a----     2022. 06. 06.     15:55        8731450 attack.1.txt
III. Linux configuration
in command prompt - bash:
smbclient -U guest //router.lan/mikrotikusb
Enter WORKGROUP\guest's password:
Try "help" to get a list of possible commands.
smb: \>
smb: \> help
?              allinfo        altname        archive        backup
blocksize      cancel         case_sensitive cd             chmod
chown          close          del            deltree        dir
du             echo           exit           get            getfacl
geteas         hardlink       help           history        iosize
lcd            link           lock           lowercase      ls
l              mask           md             mget           mkdir
more           mput           newer          notify         open
posix          posix_encrypt  posix_open     posix_mkdir    posix_rmdir
posix_unlink   posix_whoami   print          prompt         put
pwd            q              queue          quit           readlink
rd             recurse        reget          rename         reput
rm             rmdir          showacls       setea          setmode
scopy          stat           symlink        tar            tarmode
timeout        translate      unlock         volume         vuid
wdel           logon          listconnect    showconnect    tcon
tdis           tid            utimes         logoff         ..
smb: \>
'l' list files:
smb: \> l
  .                                 DAH    12288  Thu Jun  9 21:10:27 2022
  ..                                DAH      440  Tue Jun  7 18:25:27 2022
  attack.0.txt                        A  1157041  Fri Jun 10 12:01:13 2022
  attack.1.txt                        A  8962063  Thu Jun  9 21:10:18 2022
see man smbclient
mount:
man 8 mount.cifs
sudo mount.cifs //router.lan/mikrotikusb /mnt/tmpshare --verbose -o vers=2.0,username=guest,pass=""
or with mount option
sudo mount -t cifs //router.lan/mikrotikusb /mnt/tmpshare --verbose -o vers=2.0,username=guest,pass=""
/etc/fstab
/router.lan/mikrotikusb        /mnt/tmpshare   cifs    vers=2.0,username=guest,pass=,noauto    0 0
Mount 'by hand':
sudo mount -v -a
sudo mount -v /mnt/tmpshare/
sudo mount -v //router.lan/mikrotikusb
Automatic mount on boot or with mount -a, change noauto to auto
Summary
Labs working well.
Further steps suggested; making dedikated user, with password on Mikrotik site.
Users browsing this forum: AndreKR, Bing [Bot], CHUPAPEE, Google [Bot], li77616211 and 192 guests
