What interface should ip4 traffic arrive on the router ?
It's not clear to me what interface pppoe-out1 should be ... and that's the one accepting WG in your ip4 firewall rules.
both site is "pppoe-out1"
either I add "in interface" or not, both mikrotik wont connect
however, I have tested between remote PC wireguard to mikrotik wireguard
Remote PC A to Site A WG = Connected
Remote PC B to Site B WG = Connected
both are connected... Mikrotik A WG cannot connect IPv4 endpoint to Mikrotik B WG or vice-versa (A>B, B>A)
Torch showing both is trying to connect, same issue with different port...
PS remove sensitive info from exports. Serial number, pppoe-account names, public key (useless without private key, I know, but no need to test the waters ...)
deleted old one
EDIT:
I see ... sfp, then vlan, then pppoe-out1
Yes, both site using GPON ONU SFP
if IPv6 endpoints can connect both mikrotik, it seem IPv4 FastTrack causing this issue
