Pi7er0s
Wifi romaing Hap ac3
Tue Jun 14, 2022 11:21 am
Welcome All,
I would like to ask you guys for the best practices to setup a wifi network with roaming for 3 routers Hap ac3.
The main router (A) works as router connected to ths ISP with DHCP server and WIFI and is located downstair.
2 other routes are located on the first floor opposite sides of the house, connected via POE Router A - port5 -> Router B port 1 and router B port 5 -> routuer C port 1
I would like to setup a wifi network with roaming funcitonality and use DHCP served from router A.
I tried to use a mesh, but for some reason it is working on router B but can't get DHCP when conneting to router C.
(Router B and C doesn't need to use ethernet, it is just for a WIFI)
Apologies if this was covered already, i tried to search it with no luck..
I will be thankful for any suggeestions.
Thanks a lot
Peter
inteq
Re: Wifi romaing Hap ac3
Thu Jun 16, 2022 11:56 am
You have 3 routers in your local network?
Or one router and two APs (or configured as AP)?
Pi7er0s
Thu Jun 16, 2022 12:00 pm
Sorry, i should describe this a bit better.
3 the same devices , 1 configured as a router 2 as APs.
With standard configuration as AP when device is roaming it is disconnecting for a short time, when getting into second AP is requesting an IP etc.
I am not sure how to setup proper roaming between 2 APs.
Ca6ko
Long time Member
Long time Member
Thu Jun 16, 2022 12:13 pm
In the ROS it is called a Capsman. It's not full roaming, it's pseudo roaming, but for 95% of the cases it's what you need.
inteq
Thu Jun 16, 2022 12:19 pm
Mikrotik does NOT (edited) really have proper roaming I am afraid.
Try using capsman on the router and setup the two APs as caps.
Make sure you are not using Access Lists for WiFi with reject based on signal. That will cause disconnects as you describe.
Pi7er0s
Thu Jun 16, 2022 12:23 pm
Perfect, thanks a lot guys.
I will give a try . Hope @inteq solution will work for me 😄
holvoetn
Thu Jun 16, 2022 1:00 pm
Added advice: don't use the wifiwave2 drivers on those AC3 if you plan on using ROS7.
Or capsman will not work anymore.
Most likely the combination will be allowed again in a later version but for now: wifiwave2 = no capsman
Which is a pity since those drivers do improve WIFI performance quite a bit (esp. on 5Ghz)
erlinden
Thu Jun 16, 2022 1:01 pm
Though having some advantages, CAPsMAN will not do anything in regards to roaming.
Can you please share your configs so we can have a look at what can be improved (and make sure there is nothing personal in the exports)?
/export file=anynameyoulike
gotsprings
Thu Jun 16, 2022 1:48 pm
It helps with keeping 2.4 clients connected in noisy environments too.
gotsprings
Thu Jun 16, 2022 1:50 pm
Mikrotik does really have proper roaming I am afraid.
The local radios on the hAP can be part of the caps-managed APs.
The performance of the radios is another thing.
holvoetn
Thu Jun 16, 2022 3:14 pm
Personally I would go for wifiwave2 and drop capsman alltogether.
3 APs (of which one works as router) is easy enough to be setup separately.
gotsprings
Thu Jun 16, 2022 5:57 pm
I think the smart money is on a better WiFi vendor.
holvoetn
Thu Jun 16, 2022 6:00 pm
If you already have the HW, why ?
chechito
Thu Jun 16, 2022 7:34 pm
first thing about roaming, is mostly a client device decision
configuration and design can help to "persuade" or help the client device to take better roaming decision if it wants.
inmost cases the fisical location of access-points can help a lot, but sometimes the idela location is not viable o available so you must try your best.
regulate access-point tx-power can help too
and last but not least use a the same ssid an security settings on all radios but use separate channels that are not being used by neighboring radios
sometimes is better to use a ssid for 2.4ghz radios and another different for 5ghz radios you must try
RSTP is enabled by default in bridges disable it , that sometimes help
protocol-mode=none
if you have windows laptop clients try wifi nic driver updates and advanced settings, intel wifi nics for example have a lot of options to try
at the end if you need a better roaming you must be sure your client devices support "advanced" roaming protocols and go for big vendor wifi solution like aruba ruckus etc
gotsprings
Thu Jun 16, 2022 7:39 pm
Whip out that 2016 iPhone and we will talk about it.
holvoetn
Thu Jun 16, 2022 7:40 pm
Iphone ? Not in my lifetime ...
Android all the way !
:lol:
gotsprings
Thu Jun 16, 2022 7:42 pm
:lol:
Edited
Whip out that 2016 Android phone.
holvoetn
Thu Jun 16, 2022 8:10 pm
How about 2010 Huawei ?
Still works...
chechito
Thu Jun 16, 2022 9:54 pm
don't expect good roaming behavior from such "old" client devices
Users browsing this forum: No registered users and 48 guests
