satman1w
10 GB fiber problem
Tue Jun 14, 2022 2:36 pm
I have RB4011iGS+ with sfpplus interfaceon one, and CRS305-1G-4S+ with 4 sfpplus interfaces on the other side.
Between them there are two Finisar FTLX8571D3BCL sfp modules (all info I can get says that it is 10G capable) and HP 3PAR 10G 10m (pn 850-200029) blue fiber cable with llc connectors, which is also declared to be 10GB capable.
Bandvwidth test between routers peaks with 2GB for a second or two and settles at slightly above 1GB at the best !
Can anyone tell what could be the problem?
regards
rextended
Re: 10 GB fiber problem  [SOLVED]
Tue Jun 14, 2022 3:51 pm
The problem is bandwidth test, consume both CPU.
Use another method with two device that generate traffic on both side, and CPU is not involved.
satman1w
Fri Jun 17, 2022 4:23 pm
I knew that, but somehow I expected more than 1 Gbit. Especially confusing was the fact that the throughput was exactly 1 Gbit so I suspected that something is wrong with router, switch, cable... etc.
Anyway I have just setup two older supermicro servers (x8STI) with ubuntu 22..., Mellanox 10 Gb interfaces, Chelsio SFP-s and voila 10 Gbit (allmost) transfer is achieved.
So, you were right... regards
ingdaka
Trainer
Trainer
Fri Jun 17, 2022 9:55 pm
Also please be in mind that not both devices are Routers, CRS305-1G-4S+IN is a switch with L3 capabilities!
chechito
Fri Jun 17, 2022 9:56 pm
try
traffic-generator tool
satman1w
Sat Jun 18, 2022 12:29 am
ok, and how does this fact affect the problem i have described?
satman1w
Sat Jun 18, 2022 12:30 am
try
on linux?
adcre
Mon Jun 20, 2022 1:30 pm
Hi
iperf / iperf3 could help you with linux test. Use enought threads.
Best Regards,
Diego
satman1w
Mon Jun 20, 2022 3:26 pm
Hi
iperf / iperf3
.this is exactly what I have used... 👍
Users browsing this forum: No registered users and 58 guests
