Nothing but maybe somewhat brief, which the follow-up question indicated, hence the more exhaustive answer. Simple as that.
Thanks a lot ,
Actually of course I know for sure that Mikrotik supports keep alive option like Cisco
The thing is we trying to make the time shorter for example in Cisco we are using
keep alive 5 4
every five seconds for 4 times and if there is no response that mean the Tunnel is down
This is why we are thinking to replace Cisco routers with Mikroik models that supports faster reaction for example
keep alive 2 2 = every two seconds for two times and so on
Best Regards
