Post the modified configurations.
Open a command line window as wide as your screen permits, run /tool sniffer quick ip-protocol=icmp ip-address=192.168.0.0/16 in it, and try pinging from one Mikrotik to the other's LAN address. You should see the ping requests on the source Mikrotik if they escape the IPsec policy, if they are caught by the policy, they won't be seen. On the destination Mikrotik, you should see the requests if they came via the IPsec tunnel, but not the responses if a policy has caught them.
So it seems to get to the opposite router and possibly to the device on the remote side, its not getting a reply back. Refer sniffer reply
ROUTER1 (192.168.20.1)
Ping to 192.168.60.250 from 192.168.20.254 - ERROR NO REPLY
INTERFACE TIME NUM DIR SRC-MAC DST-MAC VLAN SRC-ADDRESS DST-ADDRESS PROTOCOL SIZE CPU FP
ether3 5.86 1 <- BC:5F:F4:D7:6D:25 2C:C8:1B:78:53:8A 192.168.20.254 192.168.60.250 ip:icmp 74 0 no
bridge 5.86 2 <- BC:5F:F4:D7:6D:25 2C:C8:1B:78:53:8A 192.168.20.254 192.168.60.250 ip:icmp 74 0 no
ether3 10.374 3 <- BC:5F:F4:D7:6D:25 2C:C8:1B:78:53:8A 192.168.20.254 192.168.60.250 ip:icmp 74 0 no
bridge 10.374 4 <- BC:5F:F4:D7:6D:25 2C:C8:1B:78:53:8A 192.168.20.254 192.168.60.250 ip:icmp 74 0 no
ether3 15.376 5 <- BC:5F:F4:D7:6D:25 2C:C8:1B:78:53:8A 192.168.20.254 192.168.60.250 ip:icmp 74 0 no
bridge 15.376 6 <- BC:5F:F4:D7:6D:25 2C:C8:1B:78:53:8A 192.168.20.254 192.168.60.250 ip:icmp 74 0 no
ether3 20.374 7 <- BC:5F:F4:D7:6D:25 2C:C8:1B:78:53:8A 192.168.20.254 192.168.60.250 ip:icmp 74 0 no
bridge 20.374 8 <- BC:5F:F4:D7:6D:25 2C:C8:1B:78:53:8A 192.168.20.254 192.168.60.250 ip:icmp 74 0 no
Ping to 192.168.60.21 from 192.168.20.254 - SUCCESSFUL
ether3 2.051 1 <- BC:5F:F4:D7:6D:25 2C:C8:1B:78:53:8A 192.168.20.254 192.168.60.21 ip:icmp 74 0 no
bridge 2.051 2 <- BC:5F:F4:D7:6D:25 2C:C8:1B:78:53:8A 192.168.20.254 192.168.60.21 ip:icmp 74 0 no
ether1 2.118 3 <- 88:F8:72:22:74:54 2C:C8:1B:78:53:89 192.168.60.21 192.168.20.254 ip:icmp 74 0 no
bridge 2.118 4 -> 2C:C8:1B:78:53:8A BC:5F:F4:D7:6D:25 192.168.60.21 192.168.20.254 ip:icmp 74 0 no
ether3 3.068 5 <- BC:5F:F4:D7:6D:25 2C:C8:1B:78:53:8A 192.168.20.254 192.168.60.21 ip:icmp 74 0 no
bridge 3.068 6 <- BC:5F:F4:D7:6D:25 2C:C8:1B:78:53:8A 192.168.20.254 192.168.60.21 ip:icmp 74 0 no
ether1 3.133 7 <- 88:F8:72:22:74:54 2C:C8:1B:78:53:89 192.168.60.21 192.168.20.254 ip:icmp 74 0 no
bridge 3.133 8 -> 2C:C8:1B:78:53:8A BC:5F:F4:D7:6D:25 192.168.60.21 192.168.20.254 ip:icmp 74 0 no
ether3 4.076 9 <- BC:5F:F4:D7:6D:25 2C:C8:1B:78:53:8A 192.168.20.254 192.168.60.21 ip:icmp 74 0 no
bridge 4.076 10 <- BC:5F:F4:D7:6D:25 2C:C8:1B:78:53:8A 192.168.20.254 192.168.60.21 ip:icmp 74 0 no
ether1 4.15 11 <- 88:F8:72:22:74:54 2C:C8:1B:78:53:89 192.168.60.21 192.168.20.254 ip:icmp 74 0 no
bridge 4.15 12 -> 2C:C8:1B:78:53:8A BC:5F:F4:D7:6D:25 192.168.60.21 192.168.20.254 ip:icmp 74 0 no
ether3 5.082 13 <- BC:5F:F4:D7:6D:25 2C:C8:1B:78:53:8A 192.168.20.254 192.168.60.21 ip:icmp 74 0 no
bridge 5.082 14 <- BC:5F:F4:D7:6D:25 2C:C8:1B:78:53:8A 192.168.20.254 192.168.60.21 ip:icmp 74 0 no
ether1 5.145 15 <- 88:F8:72:22:74:54 2C:C8:1B:78:53:89 192.168.60.21 192.168.20.254 ip:icmp 74 0 no
bridge 5.145 16 -> 2C:C8:1B:78:53:8A BC:5F:F4:D7:6D:25 192.168.60.21 192.168.20.254 ip:icmp 74 0 no
ROUTER2 (192.168.60.1)
bridge 2.652 1 -> 48:8F:5A:35:41:2F 1C:69:7A:02:33:40 192.168.8.101 192.168.60.4 ip:icmp 149 0 no
ether1 4.139 2 <- 24:31:54:16:6A:59 48:8F:5A:35:41:2E 192.168.20.254 192.168.60.250 ip:icmp 74 0 no
bridge 4.139 3 -> 48:8F:5A:35:41:2F 00:01:6C:D6:95:97 192.168.20.254 192.168.60.250 ip:icmp 74 0 no
ether1 8.647 4 <- 24:31:54:16:6A:59 48:8F:5A:35:41:2E 192.168.20.254 192.168.60.250 ip:icmp 74 0 no
bridge 8.647 5 -> 48:8F:5A:35:41:2F 00:01:6C:D6:95:97 192.168.20.254 192.168.60.250 ip:icmp 74 0 no
bridge 12.802 6 -> 48:8F:5A:35:41:2F 1C:69:7A:02:33:40 192.168.8.101 192.168.60.4 ip:icmp 149 0 no
bridge 13.262 7 -> 48:8F:5A:35:41:2F 1C:69:7A:02:B2:86 192.168.8.101 192.168.60.5 ip:icmp 149 0 no
ether1 13.658 8 <- 24:31:54:16:6A:59 48:8F:5A:35:41:2E 192.168.20.254 192.168.60.250 ip:icmp 74 0 no
bridge 13.658 9 -> 48:8F:5A:35:41:2F 00:01:6C:D6:95:97 192.168.20.254 192.168.60.250 ip:icmp 74 0 no
ether1 18.656 10 <- 24:31:54:16:6A:59 48:8F:5A:35:41:2E 192.168.20.254 192.168.60.250 ip:icmp 74 0 no
bridge 18.656 11 -> 48:8F:5A:35:41:2F 00:01:6C:D6:95:97 192.168.20.254 192.168.60.250 ip:icmp 74 0 no
bridge 24.172 12 -> 48:8F:5A:35:41:2F 1C:69:7A:02:B2:86 192.168.8.101 192.168.60.5 ip:icmp 149 0 no
bridge 3.561 1 -> 48:8F:5A:35:41:2F 1C:69:7A:02:33:40 192.168.8.101 192.168.60.4 ip:icmp 149 0 no
ether1 3.754 2 <- 24:31:54:16:6A:59 48:8F:5A:35:41:2E 192.168.20.254 192.168.60.21 ip:icmp 74 0 no
bridge 3.756 3 -> 48:8F:5A:35:41:2F 50:57:9C:62:7E:B1 192.168.20.254 192.168.60.21 ip:icmp 74 0 no
ether2 3.758 4 <- 50:57:9C:62:7E:B1 48:8F:5A:35:41:2F 192.168.60.21 192.168.20.254 ip:icmp 74 0 no
bridge 3.758 5 <- 50:57:9C:62:7E:B1 48:8F:5A:35:41:2F 192.168.60.21 192.168.20.254 ip:icmp 74 0 no
ether1 4.787 6 <- 24:31:54:16:6A:59 48:8F:5A:35:41:2E 192.168.20.254 192.168.60.21 ip:icmp 74 0 no
bridge 4.787 7 -> 48:8F:5A:35:41:2F 50:57:9C:62:7E:B1 192.168.20.254 192.168.60.21 ip:icmp 74 0 no
ether2 4.79 8 <- 50:57:9C:62:7E:B1 48:8F:5A:35:41:2F 192.168.60.21 192.168.20.254 ip:icmp 74 0 no
bridge 4.79 9 <- 50:57:9C:62:7E:B1 48:8F:5A:35:41:2F 192.168.60.21 192.168.20.254 ip:icmp 74 0 no
ether1 5.793 10 <- 24:31:54:16:6A:59 48:8F:5A:35:41:2E 192.168.20.254 192.168.60.21 ip:icmp 74 0 no
bridge 5.793 11 -> 48:8F:5A:35:41:2F 50:57:9C:62:7E:B1 192.168.20.254 192.168.60.21 ip:icmp 74 0 no
ether2 5.797 12 <- 50:57:9C:62:7E:B1 48:8F:5A:35:41:2F 192.168.60.21 192.168.20.254 ip:icmp 74 0 no
bridge 5.797 13 <- 50:57:9C:62:7E:B1 48:8F:5A:35:41:2F 192.168.60.21 192.168.20.254 ip:icmp 74 0 no
ether1 6.793 14 <- 24:31:54:16:6A:59 48:8F:5A:35:41:2E 192.168.20.254 192.168.60.21 ip:icmp 74 0 no
bridge 6.793 15 -> 48:8F:5A:35:41:2F 50:57:9C:62:7E:B1 192.168.20.254 192.168.60.21 ip:icmp 74 0 no
ether2 6.796 16 <- 50:57:9C:62:7E:B1 48:8F:5A:35:41:2F 192.168.60.21 192.168.20.254 ip:icmp 74 0 no
bridge 6.796 17 <- 50:57:9C:62:7E:B1 48:8F:5A:35:41:2F 192.168.60.21 192.168.20.254 ip:icmp 74 0 no
bridge 13.811 18 -> 48:8F:5A:35:41:2F 1C:69:7A:02:33:40 192.168.8.101 192.168.60.4 ip:icmp 149 0 no
Ping to 192.168.60.250 from 192.168.60.1 - SUCCESSFUL
bridge 2.851 3 <- 00:01:6C:D6:95:97 48:8F:5A:35:41:2F 192.168.60.250 192.168.60.1 ip:icmp 70 0 no
bridge 3.855 4 -> 48:8F:5A:35:41:2F 00:01:6C:D6:95:97 192.168.60.1 192.168.60.250 ip:icmp 70 0 no
ether2 3.856 5 <- 00:01:6C:D6:95:97 48:8F:5A:35:41:2F 192.168.60.250 192.168.60.1 ip:icmp 70 0 no
bridge 3.856 6 <- 00:01:6C:D6:95:97 48:8F:5A:35:41:2F 192.168.60.250 192.168.60.1 ip:icmp 70 0 no
bridge 4.861 7 -> 48:8F:5A:35:41:2F 00:01:6C:D6:95:97 192.168.60.1 192.168.60.250 ip:icmp 70 0 no
ether2 4.861 8 <- 00:01:6C:D6:95:97 48:8F:5A:35:41:2F 192.168.60.250 192.168.60.1 ip:icmp 70 0 no
bridge 4.861 9 <- 00:01:6C:D6:95:97 48:8F:5A:35:41:2F 192.168.60.250 192.168.60.1 ip:icmp 70 0 no
bridge 5.864 10 -> 48:8F:5A:35:41:2F 00:01:6C:D6:95:97 192.168.60.1 192.168.60.250 ip:icmp 70 0 no
ether2 5.864 11 <- 00:01:6C:D6:95:97 48:8F:5A:35:41:2F 192.168.60.250 192.168.60.1 ip:icmp 70 0 no
bridge 5.864 12 <- 00:01:6C:D6:95:97 48:8F:5A:35:41:2F 192.168.60.250 192.168.60.1 ip:icmp 70 0 no
bridge 6.868 13 -> 48:8F:5A:35:41:2F 00:01:6C:D6:95:97 192.168.60.1 192.168.60.250 ip:icmp 70 0 no
ether2 6.868 14 <- 00:01:6C:D6:95:97 48:8F:5A:35:41:2F 192.168.60.250 192.168.60.1 ip:icmp 70 0 no
Thanks for your assistance.
