yinmeout
Out of my depth!
Tue Jun 14, 2022 9:31 pm
Wondering if some kind soul could offer any assistance to get internet access on my Chataux 5G.
I am able to tracert to internet sites by name, so DNS and routing must be working (nslookup also works). However, unable to get beyond ‘syn sent’ in the firewall connections list. So the actual issue is while IPs seem to work browsing doesn’t. I have no tested any other traffic types yet.
I am not at all familiar with Router_OS I just need a fast cellular connection and I bought this, since it does CAT20. A cabled connection is not possible where we live in the uk.
# jun/14/2022 18:17:19 by RouterOS 7.2.3
# software id = 4EBY-K8H6
# model = D53G-5HacD2HnD
# serial number = <CENSORED>
add admin-mac=18:FD:74:13:93:62 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    disabled=no distance=indoors frequency=auto installation=indoor mode=\
    ap-bridge ssid=WLAN_22 wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX \
    country="united kingdom" disabled=no distance=indoors frequency=auto \
    installation=indoor mode=ap-bridge ssid=WLAN_33 wireless-protocol=\
    802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
add apn=everywhere use-network-apn=yes
/interface lte
set [ find ] allow-roaming=no apn-profiles=everywhere band="" name=lte1 \
    network-mode=lte,5g nr-band=""
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys \
    supplicant-identity=MikroTik
add name=dhcp ranges=192.168.1.10-192.168.1.100
add address-pool=dhcp interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wlan2
/interface detect-internet
set detect-interface-list=all
add comment=defconf interface=lte1 list=WAN
add address=192.168.1.1/24 comment=defconf interface=bridge network=192.168.1.0
/ip dhcp-client
add
add address=192.168.1.0/24 comment=defconf dns-server=192.168.1.1 gateway=\
    192.168.1.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.1.1 comment=defconf name=router.lan
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
    invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
    connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
    out,none out-interface-list=WAN
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    "defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp \
    src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    "defconf: drop every thing else not coming from LAN" in-interface-list=!LAN
    invalid
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" \
    src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" \
    dst-address-list=bad_ipv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 \
    protocol=udp
    ipsec-ah
    ipsec-esp
    "defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys \
    policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    source="\r\
    \n   :if ([system leds settings get all-leds-off] = \"never\") do={\r\
    \n     /system leds settings set all-leds-off=immediate \r\
    \n   } else={\r\
    \n     /system leds settings set all-leds-off=never \r\
    \n   }\r\
    \n "
/tool mac-server
/tool mac-server mac-winbox
Thanks in advance.
Anthony.
yinmeout
Re: Unable to browse internet.
Wed Jun 15, 2022 12:29 am
I apologise for the vague title - wasn’t thinking.
I have spent over 8 hours straight on this and feel sure it’s something simple, but not obvious to me. I have tried adding in various rules and modifying the NAT configuration all with no success. Only ICMP is logged in the log via the fasttrack rule, when I enabled logging on all rules. It seems odd that no LAN packets are being dropped in the logs, which points to a routing problem, but that does look right to me…. any advice welcome.
Sob
Re: Out of my depth!  [SOLVED]
Wed Jun 15, 2022 4:07 am
It looks like all default config, it doesn't block any outgoing traffic. So if traceroute is able to get out, so must tcp for web. You can check lte1 interface using Tools->Torch and you should see outgoing packets there.
yinmeout
Wed Jun 15, 2022 9:09 am
Something simple after all, needed to define the IP Type in the APN settings to exclude V6.
Now working albeit shockingly slow, I’ll start another post for that.
Users browsing this forum: Amazon [Bot] and 53 guests
