I need the DHCP server to connect those devices without static IP, which often change in the network.
Code: Select all
# jun/14/2022 21:23:57 by RouterOS 7.3
/interface lte
set [ find ] allow-roaming=no band="" name=lte1
set [ find default-name=ether1 ] arp=proxy-arp
/interface wireless
set [ find default-name=wlan1 ] ssid=MikroTik
/interface lte apn
set [ find default=yes ] apn=APN authentication=pap ip-type=ipv4 name=LTE use-network-apn=no user=USERNAME
add address=192.168.88.1/24 interface=ether1 network=192.168.88.0
add address=82.134.200.140/24 interface=ether1 network=82.134.200.0
set servers=8.8.8.8
add action=masquerade chain=srcnat comment="" \
out-interface=lte1 src-address=192.168.88.0/24
