pekr
LtAP LR8 - can't see a LoRa card ...
Wed Jun 15, 2022 8:21 am
wanted to do some tests with LoRa, so bought LtAP LR8 LTE Kit. I first could not see a LoRa menu in Winbox, so downloaded extra packages. But even ten, LoRa devices section is just - empty, whereas in many videos, there is a disabled item. I opened the box and can see, there actually is the LTE and LoRa card too. I can see the LTE, but not the LoRa one.
Any tips?
Thanks a lot,
/Petr
Amm0
Re: LtAP LR8 - can't see a LoRa card ...
Wed Jun 15, 2022 5:04 pm
Any tips?
Thanks a lot,
/Petr
Couple of things to try:
Is the USB port set to "miniPCI"?
/system routerboard usb set mode=miniPCIe
Now I don't know the LoRa miniPCIe module requires USB 3.0, if so it have to on the "bottom" miniPCIe slot.
pekr
Thu Jun 16, 2022 8:09 am
Any tips?
Thanks a lot,
/Petr
I tried the above command but console reply is: "expected end of command (line 1 column 29)"
So here's some output from the console:
[admin@MikroTik] > /system resource pci print
 # DEVICE   VENDOR                               NAME                                     IRQ
 0 01:00.0  Atheros Communications Inc.          unknown device (rev: 1)                    4
 1 00:00.0  unknown                              unknown (rev: 1)                           0
 [admin@MikroTik] > /system resource usb print
 # DEVICE VENDOR                       NAME                       SPEED
 0 1-0    Linux 3.3.5 xhci-hcd         xHCI Host Controller       480
 1 2-0    Linux 3.3.5 xhci-hcd         xHCI Host Controller       5000
 2 1-1    MikroTik                     R11e-LTE                   480
[admin@MikroTik] > /system resource print
                   uptime: 22m12s
                  version: 6.49.6 (stable)
               build-time: Apr/07/2022 17:53:31
         factory-software: 6.44.6
              free-memory: 92.5MiB
             total-memory: 128.0MiB
                      cpu: MIPS 1004Kc V2.15
                cpu-count: 4
            cpu-frequency: 880MHz
                 cpu-load: 0%
           free-hdd-space: 4444.0KiB
          total-hdd-space: 16.3MiB
  write-sect-since-reboot: 82
         write-sect-total: 5589
               bad-blocks: 0%
        architecture-name: mmips
               board-name: LtAP LTE kit
                 platform: MikroTik
Based upon the board-name, it almost seems like just an LTE board, but it has a LoRa gateway ID sticker on the rear side. Tried also to completly reset the device, to no avail ....
rextended
Thu Jun 16, 2022 11:42 am
results of this?
/system routerboard print
/system routerboard settings print
/system package print
(do not publish serial number)
pekr
Thu Jun 16, 2022 5:07 pm
I have updated the system to the latest, added iot and lora packages manually, updated the routerboard firmware. Here's the output:
[admin@MikroTik] > /system routerboard print
       routerboard: yes
             model: RBLtAP-2HnD
     serial-number: xxxxxx
     firmware-type: mt7621L
  factory-firmware: 6.47.9
  current-firmware: 6.49.6
  upgrade-firmware: 6.49.6
[admin@MikroTik] > /system routerboard settings print
              auto-upgrade: no
                 baud-rate: 115200
                boot-delay: 2s
            enter-setup-on: any-key
               boot-device: nand-if-fail-then-ethernet
             boot-protocol: bootp
       enable-jumper-reset: yes
       force-backup-booter: no
               silent-boot: no
               disable-pci: no
      protected-routerboot: disabled
      reformat-hold-button: 20s
  reformat-hold-button-max: 10m
                   uptime: 6m21s
              free-memory: 96.3MiB
                cpu-count: 4
                 cpu-load: 0%
           free-hdd-space: 4460.0KiB
  write-sect-since-reboot: 134
         write-sect-total: 3201
               bad-blocks: 0%
                 platform: MikroTik
[admin@MikroTik] > /system package print
Flags: X - disabled
 #   NAME        VERSION        SCHEDULED
 0   routeros-mmips        6.49.6
 1   system        6.49.6
 2 X ipv6        6.49.6
 3   wireless        6.49.6
 4   hotspot        6.49.6
 5   mpls        6.49.6
 6   routing        6.49.6
 7   ppp        6.49.6
 8   dhcp        6.49.6
 9   security        6.49.6
10   advanced-tools        6.49.6
11   gps        6.49.6
12   lora        6.49.6
13   iot        6.49.6
pekr
Re: LtAP LR8 - can't see a LoRa card ...  [SOLVED]
Sun Jun 19, 2022 1:23 pm
Finally can see the card. Went into the System / Routerboard / USB and changed the setting from USB type A to Min iPCIe.
Users browsing this forum: mkx, Sddaw and 172 guests
