Hi everyone,
I'm having a weird issue with IPSEC. Hope someone of you guys can help:
SCENARIO
I am establishing an IPSEC tunnel between two mikrotiks. Both have to wan (fiber) links, so i have created two tunnels, so we have a (manual) fallback in case any of the fibers fail.
For that, i have created two sets of policies and two peers per router.
There are several subnets to be connected, so there are 7 policies per tunnel.
The weird thing is that one of those is automatically marked as invalid for both mikrotiks. They mark it as invalid instantly as soon as i enable it, so i am understanding it is not related to a faulty connection, but to some (misterious) internal calculation of the router that says "i don't like this route". But, why?
This is the regarding data:
ROUTER1 - IPSEC - POLICIES
# PEER TUNNEL SRC-ADDRESS DST-ADDRESS PROTOCOL ACTION LEVEL PH2-COUNT
0 A RW yes 192.168.41.0/24 172.31.0.0/16 all encrypt require 2
1 A RW yes 192.168.41.0/24 192.168.0.0/16 all encrypt require 1
2 A RW yes 10.20.14.0/24 172.31.0.0/16 all encrypt require 1
3 A RW yes 10.20.14.0/24 192.168.0.0/16 all encrypt require 1
4 A RW yes 172.30.100.0/24 172.31.0.0/16 all encrypt require 1
5 A RW yes 172.30.100.0/24 192.168.0.0/16 all encrypt require 1
6 RW yes 10.20.59.0/24 192.168.0.0/16 all encrypt require 0
7 A RW yes 10.20.59.0/24 172.31.0.0/16 all encrypt require 1
8 XI RWC yes 192.168.41.0/24 172.31.0.0/16 all encrypt require 0
9 XI RWC yes 192.168.41.0/24 192.168.0.0/16 all encrypt require 0
10 XI RWC yes 10.20.14.0/24 172.31.0.0/16 all encrypt require 0
11 XI RWC yes 10.20.14.0/24 192.168.0.0/16 all encrypt require 0
12 XI RWC yes 172.30.100.0/24 172.31.0.0/16 all encrypt require 0
13 XI RWC yes 172.30.100.0/24 192.168.0.0/16 all encrypt require 0
14 XI RWC yes 10.20.59.0/24 172.31.0.0/16 all encrypt require 0
15 XI RWC yes 10.20.59.0/24 192.168.0.0/16 all encrypt require 0
16 T * ::/0 ::/0 all
As you can see, policies 0-7 are for the first tunnel, and are active currently. Policies 8 to 15 are for the secind tunnel, and inactive. The problem es policiy 6.
Now the other router:
ROUTER2 - IPSEC - POLICIES
0 XI RWC yes 172.31.0.0/16 192.168.41.0/24 all encrypt require 0
1 XI RWC yes 192.168.0.0/16 192.168.41.0/24 all encrypt require 0
2 XI RWC yes 172.31.0.0/16 10.20.14.0/24 all encrypt require 0
3 XI RWC yes 192.168.0.0/16 10.20.14.0/24 all encrypt require 0
4 XI RWC yes 172.31.0.0/16 172.30.100.0/24 all encrypt require 0
5 XI RWC yes 192.168.0.0/16 172.30.100.0/24 all encrypt require 0
6 XI RWC yes 172.31.0.0/16 10.20.59.0/24 all encrypt require 0
7 XI RWC yes 192.168.0.0/16 10.20.59.0/24 all encrypt require 0
8 A RW yes 172.31.0.0/16 192.168.41.0/24 all encrypt require 2
9 A RW yes 192.168.0.0/16 192.168.41.0/24 all encrypt require 1
10 A RW yes 172.31.0.0/16 10.20.14.0/24 all encrypt require 1
11 A RW yes 192.168.0.0/16 10.20.14.0/24 all encrypt require 1
12 A RW yes 172.31.0.0/16 172.30.100.0/24 all encrypt require 1
13 A RW yes 192.168.0.0/16 172.30.100.0/24 all encrypt require 1
14 I RW yes 192.168.0.0/16 10.20.59.0/24 all encrypt require 0
15 A RW yes 172.31.0.0/16 10.20.59.0/24 all encrypt require 1
As you can see, in Router 2 the offending policy is 14.
If i switch tunnels and let the other one work, the same issue happens. Route from/to 192.168.0.0/16 -- 10.20.59.0/24 is consistently marked as invalid. Everything else works flawlessly but, of course, traffic between these two subnets.
By the way, Router 1 is an RB4011 with Os v6.47.10, and Router2 is a cloud hosted router with Os v6.47.8
I have check -literally- the configs a hundred times. Cannot find anything worng. I can only thing this is a (very) odd issue into the Mkt, But it would be lovely if any of you experienced guys could have a look and help.
Thank you very much in advance.
