ath
VXLAN ports
Wed Jun 15, 2022 2:15 pm
On which of its ports does a MikroTik router listen for incoming VXLAN connections?
Is there any way to control this?
cfikes
Re: VXLAN ports
Wed Jun 15, 2022 3:00 pm
If you mean UDP port, when the interface is created you specify the port you want.
If you mean physical, it will listen on any IP interface assigned on the router, permitting firewall rules allow for it.
ath
Re: VXLAN ports
Sat Jun 18, 2022 3:47 am
Thanks.
My question was aimed at which physical/virtual ports a router listened on.
I've been trying to configure a router to send and receive VXLAN datagrams over a VRF. I can get it to send, but not receive. I've tried using the mangle to direct incoming datagrams from the VRF to the main routing table, in the expectation that the router would then be able to process them, but this has no effect.
I've fallen back to using a cross-over cable to connect two physical ports, which is a waste of ports, bit it works.
Users browsing this forum: raiser and 20 guests
