captainhachiman
CCR2004-1G-2XS-PCIe Not Showing Up in lspci
Thu Jun 16, 2022 7:28 am
Hi, I just got my card after waiting 2 months. However after plugging it into my motherboard I find that it is not detected by the OS. Nothing at all about it shows up in lspci (not even an unknown device). I've upgraded the kernel to 5.18.4 and the motherboard is A88XM-PLUS with the latest BIOS firmware. Would be grateful if anyone can help me :)
antonsb
Re: CCR2004-1G-2XS-PCIe Not Showing Up in lspci
Thu Jun 16, 2022 11:13 am
CCR2004-1G-2XS-PCIe is istalled in first PCIe3.0 slot?
rextended
Thu Jun 16, 2022 11:29 am
Not only must be on the 1st PCIe slot (PCIEX16_1), that is it the unique slot that support the PCIe 3.0, if is supported from the processor,
but also the processor must be a FM2+ that support the PCIe 3.0,
or the motherboard do not support at all the PICe 3.0....
psannz
Thu Jun 16, 2022 12:33 pm
What CPU are you using?
Did you try to rescan the PCIe devices after Linux booted? The card needs some time to boot ROS on itself.
Regarding BIOS settings:
  • is Fastboot disabled?
  • Is Option ROM Messages set to "Force BIOS"?
  • You may alse have better success by setting the POST Delay Time to 30s just to give the card enough time to boot up itself, so that Linux will actually be able to see and interact with it.
captainhachiman
Thu Jun 16, 2022 2:18 pm
The CPU is A10-7850K (FM2+, said to support PCI-e 3.0). I've made sure that:
- fastboot is disabled
- all other PCI-e cards are removed and CCR2004 is installed on the slot that is nearest to the CPU (There's a large "PCI-e 3.0" printed there on the motherboard)
- Option ROM Messages is set to "Force BIOS"
- set the POST Delay to 10s (the largest I can set on this motherboard)
- "echo "1" > /sys/bus/pci/rescan" is tried
However when running lspci I still get nothing about my Mikrotik card. Any ideas?
Last edited by captainhachiman on Fri Jun 17, 2022 11:57 am, edited 1 time in total.
psannz
Thu Jun 16, 2022 7:20 pm
but did you run it with root rights? Try again, with a "sudo" in front of it ;)
captainhachiman
Thu Jun 16, 2022 7:25 pm
Yes I did try that, and I also tried running that after sudo su, but it is still not detected.
herger
Thu Jun 16, 2022 8:07 pm
Did you try connecting to the CCR (via ethernet)? What does ROS say about the state of the pcie interfaces? had some bad luck with recent ROSv7 on mine, try latest 7.3.1.
captainhachiman
Thu Jun 16, 2022 8:24 pm
rextended
Fri Jun 17, 2022 10:49 am
please paste this on terminal and post the results:
/sys routerboard print
/sys routerboard settings print
/sys resource print
/sys package print
/export show-sensitive
(remember to remove serial number and private info, CENSORING that, and not removing that line/settings from export)
captainhachiman
Fri Jun 17, 2022 12:10 pm
terminal code
[admin@MikroTik] > /sys routerboard print
       routerboard: yes
             model: CCR2004-1G-2XS-PCIe
     serial-number: [CENSORED]
     firmware-type: al64
  factory-firmware: 7.1.4
  current-firmware: 7.1.4
  upgrade-firmware: 7.3.1
[admin@MikroTik] > /sys routerboard settings print
              auto-upgrade: no
               boot-device: nand-if-fail-then-ethernet
             boot-protocol: bootp
       force-backup-booter: no
               silent-boot: no
      protected-routerboot: disabled
      reformat-hold-button: 20s
  reformat-hold-button-max: 10m
[admin@MikroTik] > /sys resource/ print
                   uptime: 6h2m49s
                  version: 7.3.1 (stable)
               build-time: Jun/09/2022 08:58:15
         factory-software: 7.1.4
              free-memory: 3847.1MiB
             total-memory: 4032.0MiB
                      cpu: ARM64
                cpu-count: 4
                 cpu-load: 0%
           free-hdd-space: 105.8MiB
          total-hdd-space: 129.0MiB
  write-sect-since-reboot: 88
         write-sect-total: 262
               bad-blocks: 0.2%
        architecture-name: arm64
               board-name: CCR2004-1G-2XS-PCIe
                 platform: MikroTik
[admin@MikroTik] > /sys package print
Columns: NAME, VERSION
# NAME      VERSION
0 routeros  7.3.1
# jan/02/1970 06:03:19 by RouterOS 7.3.1
# software id = [CENSORED]
# model = CCR2004-1G-2XS-PCIe
# serial number = [CENSORED]
add name=bridge1
add name=WAN
add name=LAN
add name=dhcp ranges=192.168.1.3-192.168.1.254
add name=dhcp_pool1 ranges=192.168.1.100-192.168.1.254
add address-pool=dhcp_pool1 interface=bridge1 name=dhcp1
/port
set 0 name=serial0
set 1 name=serial1
add bridge=bridge1 interface=ether-pcie2
add bridge=bridge1 interface=ether-pcie3
add bridge=bridge1 interface=ether-pcie4
add bridge=bridge1 interface=sfp28-2
add bridge=bridge1 interface=sfp28-1
/interface detect-internet
set detect-interface-list=all
add interface=ether-pcie1 list=WAN
add address=192.168.1.1/24 interface=bridge1 network=192.168.1.0
add address=192.168.0.99/24 interface=ether1 network=192.168.0.0
/ip arp
add address=192.168.0.99 interface=ether1
/ip dhcp-client
add address=0.0.0.0/24 gateway=0.0.0.0 netmask=24
add address=192.168.1.0/24 dns-server=9.9.9.9 gateway=192.168.1.1 netmask=24
rextended
Fri Jun 17, 2022 1:15 pm
Ok, first try to update RouteBOARD "BIOS" (RouterBOOT) on System / Routerboard...
After update, completely power off the mainboard, wait 10/20 sec and power it up again...
On the remaining parts, I do not see anything strange...
captainhachiman
Fri Jun 17, 2022 2:14 pm
Upgraded but it's still not showing up in lspci after rescanning. It's really strange.
rextended
Fri Jun 17, 2022 3:59 pm
You can try on another PCIe 3.0 motherboard?
captainhachiman
Fri Jun 17, 2022 4:41 pm
Seems to be the time for me to upgrade my machine lol :lol:
Thanks for your help, I'll do that but probably after some time.
chechito
Fri Jun 17, 2022 5:51 pm
is nice to see that ccr2004-pcie works well independently from PC recognize it or not
i think even in that condition it can be useful in some scenarios
rextended
Fri Jun 17, 2022 7:11 pm
Yes, you can just power it the board with some PCIe bus adapter already used for data mining on GPU cards, and, regardless if connected or not to one motherboard, works.
technick
Mon Jun 27, 2022 1:35 am
OP, if it makes you feel better, I have a nearly full server rack with no servers supporting POST delay, or seeing the passthrough devices of the CCR PCIe device!
Linux, BSD, Windows, they all show non-configurable errored devices. Even 3 last gen (DDR4/i7/AM3) desktop/workstation systems that have no support for the PCIe passthrough.
In my experience so far, the ports also need a physical+configured+enabled connection before they appear in winbox (or on the web config) as enabled for passthrough.
Users browsing this forum: Bing [Bot], GoogleOther [Bot] and 32 guests
