santong7
Many links Down on cap 5GHz RBwAPG-5HacT2HnD
Thu Jun 16, 2022 12:30 pm
Dear community,
I have RBwAPG-5HacT2HnD RB750Gr3 and for wireless, I use the new Cap XL connected to 750Gr3 via switch (not direct).
In the past, I used the wAP AC (old revision).
I have multiple links down on the 5GHz interface and fewer on the 2.4GHz interface.
The same was also when I used the wAP AC with the same conf and connection.
As you see in the photos
5GHz interface
2.4GHz
Also the capsman code
/caps-man channel
add band=2ghz-b/g/n frequency=2412 name=CH1
add band=2ghz-b/g/n frequency=2417 name=CH2
add band=2ghz-b/g/n frequency=2422 name=CH3
add band=2ghz-b/g/n frequency=2427 name=CH4
add band=2ghz-b/g/n frequency=2432 name=CH5
add band=2ghz-b/g/n frequency=2437 name=CH6
add band=2ghz-b/g/n frequency=2442 name=CH7
add band=2ghz-b/g/n frequency=2447 name=CH8
add band=2ghz-b/g/n frequency=2452 name=CH9
add band=2ghz-b/g/n frequency=2457 name=CH10
add band=2ghz-b/g/n frequency=2462 name=CH11
add band=2ghz-b/g/n frequency=2467 name=CH12
add band=2ghz-b/g/n frequency=2472 name=CH13
add band=5ghz-a/n/ac frequency=5180 name=CH36
add band=5ghz-a/n/ac frequency=5200 name=CH40
add band=5ghz-a/n/ac frequency=5220 name=CH44
add band=5ghz-a/n/ac frequency=5240 name=CH48
add band=5ghz-a/n/ac frequency=5260 name=CH52
add band=5ghz-a/n/ac frequency=5280 name=CH56
add band=5ghz-a/n/ac frequency=5300 name=CH60
add band=5ghz-a/n/ac frequency=5320 name=CH64
add band=5ghz-a/n/ac frequency=5500 name=CH100
add band=5ghz-a/n/ac frequency=5520 name=CH104
add band=5ghz-a/n/ac frequency=5540 name=CH108
add band=5ghz-a/n/ac frequency=5560 name=CH112
add band=5ghz-a/n/ac frequency=5580 name=CH116
add band=5ghz-a/n/ac frequency=5600 name=CH120
add band=5ghz-a/n/ac frequency=5620 name=CH124
add band=5ghz-a/n/ac frequency=5640 name=CH128
add band=5ghz-a/n/ac frequency=5660 name=CH132
add band=5ghz-a/n/ac frequency=5680 name=CH136
add band=5ghz-a/n/ac frequency=5700 name=CH140
add band=5ghz-a/n/ac frequency=5745 name=CH149
add band=5ghz-a/n/ac frequency=5765 name=CH153
add band=5ghz-a/n/ac frequency=5785 name=CH157
add band=5ghz-a/n/ac frequency=5805 name=CH161
add band=5ghz-a/n/ac frequency=5825 name=CH165
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm group-key-update=4h \
    name=security1
/caps-man access-list
add action=accept allow-signal-out-of-range=10s disabled=yes signal-range=\
    -80..-10 ssid-regexp=""
add action=reject allow-signal-out-of-range=10s disabled=yes signal-range=\
    -120..-81 ssid-regexp=""
/caps-man configuration
add channel=CH1 channel.band=2ghz-g/n country=greece datapath.bridge=bridge1 \
    .client-to-client-forwarding=yes .local-forwarding=yes installation=any \
    mode=ap name=home security=security1 ssid=Home
add channel=CH36 channel.band=5ghz-onlyac .skip-dfs-channels=yes country=\
    greece datapath.bridge=bridge1 .client-to-client-forwarding=yes \
    .local-forwarding=yes installation=any mode=ap name=homeac security=\
    security1 ssid=HomeAC
/caps-man interface
add configuration=home disabled=no l2mtu=1600 mac-address=DC:2C:6E:1B:31:8C \
    master-interface=none name=CAP-XL-1 radio-mac=DC:2C:6E:1B:31:8C \
    radio-name=DC2C6E1B318C
add configuration=homeac disabled=no l2mtu=1600 mac-address=DC:2C:6E:1B:31:8D \
    master-interface=none name=CAP-XL-2 radio-mac=DC:2C:6E:1B:31:8D \
    radio-name=DC2C6E1B318D
/caps-man manager
set ca-certificate=auto certificate=auto enabled=yes package-path=/disk1/pub
/caps-man manager interface
add disabled=no forbid=yes interface=ether1-WAN
/caps-man provisioning
add action=create-enabled hw-supported-modes=gn master-configuration=home \
    name-format=identity
add action=create-enabled hw-supported-modes=ac master-configuration=homeac \
I have also tried to use with capsman forwarding, with same results, and also directly connected to the 750Gr3 port.
Still same.
Any workaround ?
Could that be related to noise from other devices such as a dect device?
I am not using certificates for capsman
Ca6ko
Long time Member
Long time Member
Re: Many links Down on cap 5GHz RBwAPG-5HacT2HnD
Fri Jun 17, 2022 10:42 am
What are you confused about? This parameter shows how many times no clients have been connected to the access point.
Users browsing this forum: donkeyKong and 32 guests
