alberto464
Firewall block SIP
Thu Jun 16, 2022 7:42 pm
Hello, I created some Firewall rules because I noticed that in the CONNECTIONS there are many public IPs pointing to port 5060 and 5061. Once the rule is executed, however, you notice that in the connections the IPs continue to connect and are not dropped.
Here are the rules I created:
add action=add-src-to-address-list address-list=sip_attack address-list-timeout=3h chain=input dst-port=5060 protocol=udp src-address-list=!accesso_consentito
add action=add-src-to-address-list address-list=sip_attack address-list-timeout=3h chain=input dst-port=5060 protocol=tcp src-address-list=!accesso_consentito
add action=add-src-to-address-list address-list=sip_attack address-list-timeout=3h chain=input dst-port=5061 protocol=udp src-address-list=!accesso_consentito
add action=add-src-to-address-list address-list=sip_attack address-list-timeout=3h chain=input dst-port=5061 protocol=tcp src-address-list=!accesso_consentito
add action=drop chain=input src-address-list=sip_attack
Where am I wrong? :(
rextended
Re: Firewall block SIP
Thu Jun 16, 2022 8:10 pm
input is the chain to the CPU, forward is the chain for the NATted or routed devices....
alberto464
Thu Jun 16, 2022 8:54 pm
So do I have to move these rules from "Input" to "Forward"?
rextended
Fri Jun 17, 2022 10:47 am
Yes, if the IP under attack is not the RouterBOARD IP...
And if hardware offload is active between bridge ports, you can not intercept that until you do not also active firewall for bridge,
but that drop prestations.
Is better you do not make visible from outside, the VoIP port open, directly inside the clients...
alberto464
Fri Jun 17, 2022 11:26 am
But if to be safer I go to "Firewall> Service Port" and disable SIP, internal LAN clients such as VoIP phones that still connect to the VoIP server or not because I have disabled the option, I don't understand this thing.
rextended
Fri Jun 17, 2022 1:09 pm
If the internal devices have private IP, no matter,
I write about internal devices with public IP...
alberto464
Fri Jun 17, 2022 1:31 pm
Perfect, thank you!
rextended
Fri Jun 17, 2022 1:32 pm
Have a nice day,
Ciao
Users browsing this forum: bgbgrara, Bing [Bot] and 59 guests
