Hi.
After updating hapAC3 RouterOS 6 to 7, I can't get to the router. The router works, dhcp ok, masquerade ok, VPNs do not connect, I can not enter it via winbox or via www, after opening the ports that I do not use on the router:
110/tcp closed pop3
139/tcp closed netbios-ssn
143/tcp closed imap
199/tcp closed smux
445/tcp closed microsoft-ds
554/tcp closed rtsp
995/tcp closed pop3s
3389/tcp closed ms-wbt-server
I'm considering a reset but I'm afraid of losing my connection completely.
Anyone have any suggestions?
