Fopwoc
LTE + Ether1 gateway
Fri Jun 17, 2022 2:19 am
Hi all! I have two ISP (one on Ether1 with DHCP on 192.168.8.1) and second on Lte ( DHCP 192.168.8.2)
I want to route all traffic from eth2/eth3/eth4 to ISP1, and all traffic from WI-FI to ISP2
I read some articles about mangle but can't figure out how to use it in my case. Do I need to create separate bridge for Wlan1 and Wlan2? Thanks!
Zacharias
Re: LTE + Ether1 gateway
Fri Jun 17, 2022 9:03 am
First seperate the networks of the two ISPs, as you mention both are on the network 192.168.8.0...
The simplest thing you can do is routing rules... https://help.mikrotik.com/docs/pages/vi ... d=59965508
Fopwoc
Fri Jun 17, 2022 11:00 am
🧐 but I want to keep same local network (for local device discovery)
Fopwoc
Fri Jun 17, 2022 12:01 pm
my current config
# jun/17/2022 11:59:55 by RouterOS 7.3.1
# software id = XXXXXXXX
# model = RBD52G-5HacD2HnD
# serial number = XXXXXXX
add admin-mac=XX:XD:X8:61:1E:X6 auto-mac=no comment=defconf name=bridge
/interface lte
set [ find ] name=lte1
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    disabled=no distance=indoors frequency=auto installation=indoor mode=\
    ap-bridge ssid=MikroTik-611ECA wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto \
    installation=indoor mode=ap-bridge ssid=MikroTik-DADDY wireless-protocol=\
    802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
    dynamic-keys supplicant-identity=MikroTik
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wlan2
add interface=lte1 list=WAN
add interface=ether1 list=WAN
    192.168.88.0
add address=192.168.8.100/24 interface=lte1 network=192.168.8.0
add address=192.168.8.177/24 interface=ether1 network=192.168.8.0
/ip dhcp-client
add add-default-route=no interface=lte1 use-peer-dns=no use-peer-ntp=no
add add-default-route=no interface=ether1 use-peer-dns=no use-peer-ntp=no
    192.168.88.1
set allow-remote-requests=yes servers=1.1.1.1 use-doh-server=\
    https://cloudflare-dns.com/dns-query verify-doh-cert=yes
/ip dns static
add address=1.1.1.1 name=cloudflare-dns.com
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=masquerade chain=srcnat out-interface=lte1
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.8.2 \
    pref-src="" routing-table=main suppress-hw-offload=no
add disabled=no distance=2 dst-address=0.0.0.0/0 gateway=192.168.8.1 \
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=lte1 type=external
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-name=Europe/Kiev
/system routerboard settings
set auto-upgrade=yes
/tool mac-server
/tool mac-server mac-winbox
Fopwoc
Fri Jun 17, 2022 2:25 pm
damn I can't open this link - 50x error :(
Zacharias
Fri Jun 17, 2022 2:30 pm
Fopwoc
Sat Jun 18, 2022 2:33 pm
Could you help? Can't find where is my mistake. All traffic still going to 192.168.8.1 gateway. But I want Wlan2/Wlan1 to 192.168.9.1
# jun/18/2022 14:30:53 by RouterOS 7.3.1
# software id = L3R8-8803
add admin-mac=XXXXXXXXXXX auto-mac=no comment=defconf name=bridge
/interface lte
/interface wireless
    installation=indoor mode=ap-bridge ssid=MikroTik-611ECB \
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
/ip hotspot profile
add address-pool=default-dhcp interface=bridge name=defconf
/routing table
add disabled=no fib name=isp2
    192.168.88.0
/ip dhcp-client
    192.168.88.1
set allow-remote-requests=yes use-doh-server=https://1.1.1.1/dns-query \
    verify-doh-cert=yes
/ip dns static
    invalid
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes \
add disabled=no dst-address=0.0.0.0/0 gateway=192.168.8.1 routing-table=main \
add disabled=no dst-address=0.0.0.0/0 gateway=192.168.9.1 routing-table=isp2 \
/ip upnp
set allow-disable-external-interface=yes enabled=yes
/ip upnp interfaces
add interface=ether1 type=external
    invalid
    icmpv6
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    ipsec-ah
    ipsec-esp
    !LAN
/routing rule
add action=lookup-only-in-table disabled=no dst-address=0.0.0.0/0 interface=\
    wlan2 table=isp2
    wlan1 table=isp2
/tool mac-server
Zacharias
Re: LTE + Ether1 gateway  [SOLVED]
Sun Jun 19, 2022 8:40 pm
The simplest thing you could do is create a second bridge for wlan1 and wlan2, assign an IP address to that bridge ( different from the one used now ), create a DHCP server on that bridge, and then on policy routing rules for that subnet use as table your ISP2 table.
Fopwoc
Wed Jun 22, 2022 8:42 pm
thank you! that's work
Users browsing this forum: No registered users and 60 guests
