gateway
Connecting mAP lite to a switch
Fri Jun 17, 2022 1:49 pm
So i am totally new to networking; just trying to learn the basics with that being side the place where i spent allot of time has a network switch i.e Fiber ISP the modem is directly connected to the switch (Cisco 3850) and my pc is hardwired from pc ethernet jack to the switch.
what i am trying to achieve is wireless so that my pc connected to the internet wirelessly using map lite instead of hardwire can someone please help me to achieve this correctly
jamsden
Re: Connecting mAP lite to a switch
Fri Jun 17, 2022 2:43 pm
I am not an expert, but you should first detect what is in charge of releasing the IP for your network (probably the ISP modem). Then you can configure mAP lite, probably as a Bridge AP, using quick configure. My network is almost the same as yours, and that’s what I did.
gateway
Fri Jun 17, 2022 10:32 pm
thank you, and i found like 4 years old post explaining very similar to what you have explained difference is i just need my own ssid
viewtopic.php?t=136412
holvoetn
Fri Jun 17, 2022 10:42 pm
Be careful with quickset.
Use once on a non- configured device ( or again after clean reset) and then never touch it again.
It is known not to work nicely with a device where other config is done using winbox.
gateway
Fri Jun 17, 2022 10:53 pm
thank you for the headsup i will take that into consideration
gateway
Sat Jun 18, 2022 2:01 am
upon more research i found this link with instructions is this still good?
"Mikrotik mAP Lite as ethernet to Wifi bridge"
https://www.davidthegeek.com/portal/en/ ... ifi-bridge
holvoetn
Sat Jun 18, 2022 8:06 am
Not for the 6.44.3 version, no :lol:
Everything bridged, DHCP on bridge.
Skip the hotspot part of that setup, makes no sense there.
gateway
Sat Jun 18, 2022 9:15 pm
sorry for being so slow will you be ok helping me guide, so under terminal i can post the script starting from line 4 with exeception of line 20 and 21?
holvoetn
Sat Jun 18, 2022 9:20 pm
Start with reset. No config, keep user.
Then paste.
gateway
Sat Jun 18, 2022 10:41 pm
Then paste.
ok thanks i think i got it working will report when i go to work i did the update(v6.49.6 (stable)
, than reset and accidentally i did not keep the user. i for sure will know if things works ok at work, currently at home everything is working great under quick setup its set at ptp bridge ap
Users browsing this forum: Bing [Bot], fxcd, GoogleOther [Bot] and 75 guests
