Yordan1
Some devices does not get internet from the WiFi
Fri Jun 17, 2022 9:38 pm
Hello.
On my new RB2011 I setup the WiFi out of the ready configuration.
I added it to the Bridge.
The result it:
- Some devices is connecting to it, and having internet, the rest is connecting, but not having internet.
I am not sure where I am doing it wrong.
If You need some sort of scripts or screenshots which would help solving this issue - please tell me ( I am fairy new ).
Thank You in advance guys ! :)
ingdaka
Trainer
Trainer
Re: Some devices does not get internet from the WiFi
Fri Jun 17, 2022 9:48 pm
Type
export hide-sensitive
on terminal and paste config to see it
Yordan1
Fri Jun 17, 2022 10:01 pm
[admin@Pornhub] > export hide-sensitive
# jun/17/2022 21:51:37 by RouterOS 6.48.6
# software id = 0KAJ-N5Z0
# model = RB2011UiAS-2HnD
add admin-mac=DC:2C:6E:71:3E:8B auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] mac-address=91:DE:B0:41:43:95
add comment=defconf name=WAN
add comment=defconf name=LAN
add authentication-types=wpa2-psk eap-methods="" \
    group-key-update=55m mode=dynamic-keys name=UnrealProfile \
    supplicant-identity=""
    group-key-update=55m mode=dynamic-keys name=Yanakievi-Profile \
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-g/n country=bulgaria disabled=no \
    distance=indoors frequency=auto installation=outdoor mode=ap-bridge \
    security-profile=Yanakievi-Profile ssid=Yanakiev wireless-protocol=802.11 \
    wps-mode=disabled
add disabled=no keepalive-frames=disabled mac-address=1E:2C:6E:11:3E:E4 \
    master-interface=wlan1 multicast-buffering=disabled name=UnrealVLAN \
    security-profile=UnrealProfile ssid=Unreal wds-cost-range=0 \
    wds-default-cost=0 wps-mode=disabled
add name=dhcp ranges=192.168.0.2-192.168.0.254
add name=VPN-Pool ranges=192.168.11.2-192.168.11.250
add address-pool=dhcp disabled=no interface=bridge lease-time=2h name=defconf
/ppp profile
add bridge=bridge change-tcp-mss=yes interface-list=LAN local-address=\
    192.168.10.1 name=VPN-Profile only-one=no remote-address=VPN-Pool \
    use-encryption=required use-mpls=yes
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp1
add bridge=bridge interface=UnrealVLAN
/interface pptp-server server
set default-profile=VPN-Profile enabled=yes
add address=192.168.0.1/24 comment=defconf interface=bridge network=192.168.0.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
/ip dhcp-server lease
add address=192.168.0.241 client-id=1:6c:1c:71:fe:6b:d7 comment="CAM - Putia" \
    mac-address=6C:1C:71:FE:6B:D7 server=defconf
add address=192.168.0.2 client-id=1:dc:2c:6e:a6:81:57 comment=\
    "Mikrotik - CAMERI" mac-address=DC:2C:6E:A6:81:57 server=defconf
add address=192.168.0.242 client-id=1:6c:1c:71:fe:21:f8 comment="CAM - Vhod" \
    mac-address=6C:1C:71:FE:21:F8 server=defconf
add address=192.168.0.244 client-id=1:0:18:ae:e4:8b:17 comment=\
    "CAM - Gradina 1" mac-address=00:18:AE:E4:8B:17 server=defconf
add address=192.168.0.4 client-id=1:64:a6:51:75:ca:e7 comment="Yordan - GSM" \
    mac-address=64:A6:51:75:CA:E7 server=defconf
add address=192.168.0.20 client-id=1:c:2c:54:c9:69:8f comment="Temenujka P20" \
    mac-address=0C:2C:54:C9:69:8F server=defconf
add address=192.168.0.11 client-id=1:64:6c:80:57:3d:a1 comment="DELL Laptop" \
    mac-address=64:6C:80:57:3D:A1 server=defconf
add address=192.168.0.250 client-id=1:24:52:6a:db:6c:1c comment=NVR \
    mac-address=24:52:6A:DB:6C:1C server=defconf
add address=192.168.0.247 client-id=1:5c:a6:e6:48:7:cc comment="CAM - Detska" \
    mac-address=5C:A6:E6:48:07:CC server=defconf
add address=192.168.0.246 client-id=1:b4:fb:e3:d6:22:ad comment="CAM - Garaj" \
    mac-address=B4:FB:E3:D6:22:AD server=defconf
add address=192.168.0.210 client-id=1:b4:b0:24:bc:64:20 comment=\
    "PC - Na 1vi etaj" mac-address=B4:B0:24:BC:64:20 server=defconf
add address=192.168.0.50 client-id=1:f4:39:9:25:5b:94 comment=\
    "PC - Na 3ti etaj. Electronic room" mac-address=F4:39:09:25:5B:94 server=\
    defconf
add address=192.168.0.7 client-id=1:14:eb:b6:63:60:4f comment="CAM - Etaj 1" \
    mac-address=14:EB:B6:63:60:4F server=defconf
add address=192.168.0.0/24 comment=defconf gateway=192.168.0.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.0.1 comment=defconf name=router.lan
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
    invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
    connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
    out,none out-interface-list=WAN
add action=accept chain=dstnat dst-address=192.168.0.50 dst-port=80 protocol=\
    tcp src-port=80
add action=accept chain=dstnat dst-address=192.168.0.50 dst-port=443 protocol=\
    tcp src-port=443
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api-ssl disabled=yes
/lcd interface pages
set 0 interfaces=sfp1,ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8
/ppp secret
add name=YordanVPNService profile=VPN-Profile
/system clock
set time-zone-name=Europe/Sofia
/system identity
set name=Pornhub
/system package update
set channel=long-term
/tool mac-server
/tool mac-server mac-winbox
sindy
Sat Jun 18, 2022 3:09 pm
There's nothing visibly wrong with your configuration, there are just slightly unusual things.
Does the issue affect only clients connected to the additional SSID (i.e. to the virtual interface UnrealVLAN) or also clients connected to the master interface?
Yordan1
Sat Jun 18, 2022 7:08 pm
it does affects on both interfaces.
sindy
Sat Jun 18, 2022 7:13 pm
Did you anonymize the MAC address of ether1 before posting or is it really set to 91:DE:B0:41:43:95? If it is, why?
Yordan1
Sat Jun 18, 2022 7:31 pm
yes, silly me. I realize it but too late.
Yordan1
Sat Jun 18, 2022 7:33 pm
Not much is changed actually excep the names of the Wifi and VLAN and the failed address try
the rest is intact.
( just didnt wanna show some names which is a bit.. awfully looking )
sindy
Sat Jun 18, 2022 7:43 pm
An answer "yes" to "A or B, if B, why?" is hard to understand 🙂. The thing is that the first byte of a MAC address must normally not be odd (as an opposite of even, not as a synonym of strange) because that's a multicast address indicator. So I suppose you had to set a MAC address of your previous equipment to get your public IP from your ISP, but the MAC address is a normal one, with the LSB of the first byte equal to 0.
OK, so what do the devices that report no internet have in common? If you don't specify a DNS server on the /ip dhcp-server network row, Mikrotik tells its DHCP clients to use the DNS servers it uses itself, and yours gets the server addresses via DHCP from the ISP. So you may try to add dns-server=192.168.0.1 to that row and let the client devices re-request their IP configuration, but it's kind of cargo cult advice - I've got no real arguments why this should have an impact, it's just that many devices detect internet availability by sending DNS requests. And my speculation is that if they get (a) public IP of the DNS server(s), they may behave different in some regard.
Yordan1
Sat Jun 18, 2022 9:38 pm
<3 Gonna try this!
Yet, I just notice something which I havent noticed before. Some of the devices, even those connected trough cables is not getting the router as a gateway..
sindy
Sat Jun 18, 2022 10:31 pm
That sounds as if one of the devices connected to the LAN acted as another DHCP server.
Yordan1
Sat Jun 18, 2022 10:52 pm
None other, they just getting IP from the router, but somewhat the gateway ( and probably the dns ) is missing. If I put their gateways manually it works.
Yordan1
Sat Jun 18, 2022 11:10 pm
Here a screenshot, what's hapening if I left the Network Card without manually seted up IP/GW/DNS, but instead let it on DHCP :
sindy
Re: Some devices does not get internet from the WiFi  [SOLVED]
Sat Jun 18, 2022 11:13 pm
That screenshot clearly states that DHCP server's address is 192.168.0.2, whereas the Mikrotik has 192.168.0.1. So look what has 192.168.0.2 in your network.
Yordan1
Sun Jun 19, 2022 12:44 am
I feel as dumb as rock opposing You.
You are correct.
One mikrotik which I am using to empower the cameras in a Switch configuration ( the 0.2 IP ) had a leftovers from it's previous life as a DHCP server..
Cant thank you enough !
Users browsing this forum: jason9456402, PhillipPer, Sailwebwifi, Semrush [Bot], tangent and 52 guests
