aglabs
Container: Way to specify working directory for remote registry work?
Fri Jun 17, 2022 11:24 pm
Is there a way to define a path to work out of for image extraction?
Issue I am facing on CCR2116 is all remote registry pulls are done to internal storage, then container extracted to m.2 drive. This results in image unable to complete download due to "not enough disk space to download layer" error. Is there a way i can specify a path on m.2 drive to use for image download/extraction?
I am speaking to instructions under a) get an image from an external library
antonsb
Re: Container: Way to specify working directory for remote registry work?  [SOLVED]
Sat Jun 18, 2022 10:19 pm
currently you can follow instructions b and c. Next releases will make pull directory configurable.
aglabs
Sun Jun 19, 2022 7:43 pm
Good to hear. Thanks for the quick answer.
Users browsing this forum: No registered users and 27 guests
